Old 11-11-2014, 03:11 PM   #1
suburban99
suburban99's Avatar
5.3 exhaust manifold questions
62 C10 frame, 78 c10 front end:
Looks to me like the stock 5.3 exhaust manifolds are too wide for the 62 c10 frame? I just removed the 5.3 from the donor and set the y-pipe into the frame of the 62. Do I need to use different exhaust manifolds? Or trim frame?
Anyone done it to a 62? I believe the frames on 61-63 are different from 64-66?
suburban99 is offline   Reply With Quote
Old 11-11-2014, 04:10 PM   #2
NEWFISHER
NEWFISHER's Avatar
Re: 5.3 exhaust manifold questions
In the engine and drivetrain area there is a sub forum for LSX swaps. I believe from what I have read, the Trailblazer SS or Hummer H3 manifolds will work. Doug Thorley has a header that works too ( Shorty and mid, don't use the long) if you want to spend a few bucks more.
GOD BLESS AMERICA!
NEWFISHER is offline   Reply With Quote
Old 11-11-2014, 04:47 PM   #3
Mathew21
Mathew21's Avatar
http://67-72chevytrucks.com/vboard/s...archid=4551758
It only has original paint once
Mathew21 is offline   Reply With Quote
Old 11-11-2014, 06:14 PM   #4
NEWFISHER
NEWFISHER's Avatar
Originally Posted by Mathew21 View Post
your linky -no-worky
GOD BLESS AMERICA!
Old 11-11-2014, 06:49 PM   #5
Clyde65
Clyde65's Avatar
here is the link to the LSx group.
http://67-72chevytrucks.com/vboard/f...play.php?f=206
as stated before, TBSS and Hummer mani's work best because they hug the block so well. I have Sanderson Shorty headers and I like them. there is also Doug Thorley long tubes also.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 11-12-2014, 12:54 AM   #6
Captainfab
60-66 Nut
The '60-'62 have the X-member frames. The '63 was the first year of the ladder type frame. The frame shouldn't make much difference in what exhaust manifold to use. Where you may have issues is with the exhaust from the manifolds back.
