![]() Join Date: Jul 2010
What clutch master-cylinder are you guys using for T56 trans
I am finally at the point where I can install my clutch system. Here is a master-cylinder I am looking at purchasing from EBay.
http://cgi.ebay.com/ws/eBayISAPI.dll...tchlink:top:en. Anyone using this setup? Can you post pictures? If not, what are you using, and can you post pics. Thanks,
Mark 1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20" My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609. My first start up http://youtu.be/R899YQ1OcjU |
60-66 Nut
Re: What clutch master-cylinder are you guys using for T56 trans
Within a couple weeks I should have my brake booster bracket with the hydraulic clutch conversion for the '67-'72's done. It will be basically the same as what I currently make for the '60-'62's. There is a link to the for sale thread in my sig line.
#4 | |
http://www.customclassictrucks.com/t...t/viewall.html "To actuate the hydraulic throwout bearing on our Tremec, we’ll be using a Wilwood ¾-inch bore master cylinder (260-10282) coupled with their new billet reservoir (260- 12696)." |
I will look tonight, I kept the box I believe incase I needed a new one later. It is a "cheapy" from Orielly
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
#6 | |||
I used on of CaptainFabs hydraulic kits on my 63. Great product. I have a novak kit installed on the bellhousing.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
Location: Sunny, Florida, some might call it South Alabama
Yeah Capt I'll be home on the 10th and can't wait to install your bracket
Just sold my C10...sad day... Looking for a 1972 Blazer to hopefully fill the hole in my heart. |
#9 | ||
I am also about to begin my t56 install and will be looking for master cyl ideas.
I am going to do a T56 swap this winter. I was thinking of trying to use the factory master cylinder from a 98-02 Camaro. I am not sure yet if it would work, the hose might not be long enough and it mounts on a angle.
Has anybody ever tried this before? I hate to start something and have nothing but trouble. Thanks, Joe |
like you said, it mounts on that angle, which sucks.
i've been squirreling parts for my 6mt swap and i'm gonna run with a tilton 7/8" mc |
Any updates on some installs ? I really like the wilwood in the first post but seems kinda pricey.
I decided since I had to pull the body off to do my suspension install that I would go ahead and clean the frame up. I'm about to start putting everything back together. So in the next few weeks I hope to have installed pics
#15 |
What master are you using ?
#16 |
I ended up finding a master cylinder at an off-road shop here in Vegas. It's made by JAMAR and was $100. I liked that it's all aluminum and black (no plastic). It should look good in my engine compartment
#17 |
Engine compartment pic
#18 |
That looks nice. Do you have a part number for it ? Hard to tell in the picture how you are mounting it to the firewall. I'm assuming your not running a booster.
#19 |
When I get home I will check my receipt for part #. I'm using this master cylinder for my clutch so no booster.
#20 |
Sorry. I'm on the hunt for a brake master and just got confused.
