Old 11-12-2014, 12:30 PM   #51
77K10Silverado
77K10Silverado's Avatar
Re: 1977 K10 Silverado Longbox
Originally Posted by Greenlee View Post
Nice work! What size are your new BFG's? I think that's one of the few tires you can still get in a 32x11.00x15. I would like to get some for my truck.
In your first set of pictures is your gauge bezel faded or scratched up? The reason I ask is I have a pretty decent one hanging in my garage that I have no use for. I no longer have the truck I was going to put it in.
Greenlee, the tires are 31/10.50/15 pictured. I now wish I would have gone with the 32's. I wanted the tall skinny look but I'm convinced that's not possible with the 15x8 rallies. I would need to get into a 16 inch wheel to achieve it and my theme here is to keep Ol' Blueberry stock/restore.
I have since picked a used one and buffed it out. The one pictured is the old, ill post the new tomorrow. I actually went through the cluster and installed a new wiring circuit and leds. I just didnt document very well so I never posted on it.. But yeah it was plum ruined! Thanks for the offer kind sir!
77K10Silverado is offline   Reply With Quote
Old 11-12-2014, 11:28 PM   #52
Greenlee
Greenlee's Avatar
I was just looking on 4 Wheel Parts website and you can get those tires in a 33x10.50. That might help with the tall skinny look. I have 31's on my truck also and would like to go with something a little bigger.
Those printed circuits are a pain. The laminate on mine was coming a part in one area. I just tried to be careful with it when putting the cluster back in. So far everything still works.
Greenlee is offline   Reply With Quote
Old 11-13-2014, 09:36 AM   #53
77K10Silverado
I think if I went with the 33/10.50 I would have to get into a small lift.. No sure that's what I want to do as of now. But your right, that would get it taller!
Here's a pic of the LEDs. Not a great pic but they do help light it up. Not able to dim is the downside.
Old 11-14-2014, 12:29 AM   #54
Greenlee
Greenlee's Avatar
That looks great! The bezel looks good too. I did the LED's also. What a difference it makes!
I'm with you on keeping it mostly stock with no lift. I have read here on the forum that 33's will fit using the stock wheels without a lift. However, I'm thinking they might rub offroad? Most 33's are 12.50 on the width. You can get the BFG's in 33x10.50 so they might have a better chance of fitting with no rubbing.
Your truck remind me of a 76' 2wd long bed I had. It was the same 2 tone colors as yours, but repainted solid blue just like yours.
Old 12-07-2014, 06:19 PM   #55
Eraser475
Eraser475's Avatar
Anything done to this beauty lately?
Dad's: 1973 Chevy C-60 Grain Truck 366 Big Block
Dad's: 1982 Chevy Silverado 6.2L Diesel K-10
Dad's: 1987 Chevy Silverado TBI 350 R-10
Dad's: 2007 GMC Sierra Classic 2500HD SLT
Mine: 1982 Chevy Silverado 6.2L Diesel K-10
Eraser475 is offline   Reply With Quote
Old 12-07-2014, 07:16 PM   #56
rusty76
rusty76's Avatar
Looking good. I recognize your inspiration truck. I'm pretty sure I know where it is. Cool truck. I've looked at it several times while passing by. Clean looking for sure.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 12-22-2014, 11:54 AM   #57
77K10Silverado
Did a few things this weekend. I needed to get to the gas tank to replace restore. That's next on the list. Prob go ahead and redo all lines while the beds off.
Old 12-22-2014, 12:01 PM   #58
77K10Silverado
Old 12-22-2014, 06:29 PM   #59
rusty76
rusty76's Avatar
How hard was it to replace the pins and bushings? That's something I get to look forward to on my '76.
My build thread
Crossmembers CC
Old 12-22-2014, 08:47 PM   #60
77K10Silverado
Rusty76... It was a breeze. Took about 20 -30 mins. I used a jack with a 2 ft piece of railroad tie to support the door. Penetrating oil, a socket and wrench. Hammer to knock the pin up and out. Screwdriver to knock out one of the stubborn bushings. When tapping back in the new bushings, do it gingerly cause they break. Good luck with it!
Old 12-22-2014, 09:42 PM   #61
rusty76
rusty76's Avatar
Thanks. It's coming all in due time. I've got a ways but still I like to do my homework.. Thanks.
My build thread
Crossmembers CC
Old 12-30-2014, 09:29 PM   #62
77K10Silverado
Ok so while I have the bed off, a few things need to be addressed. Dropped the tank to fix the original problem. Gas was leaking out every time I filled up. Filler hoses were rotten. I order a new sending unit lock rig and gasket. Also ordered strap pads and paint for the tank once I get it clean up and sanded. It looks spotless inside, and it's original with USS stamp. I plan on powder coating the straps along with new hardware. I also ordered a can of Chassis Saver in the vintage flat black. Time to get to work!
Old 12-30-2014, 09:33 PM   #63
77K10Silverado
Old 12-30-2014, 09:58 PM   #64
73Super8
73Super8's Avatar
Wheel and tire combo is stunning! Lookin good.
1973 K10 Super 8 http://67-72chevytrucks.com/vboard/s...d.php?t=645525 Sold
1988 S10 http://www.s10forum.com/forum/f135/p...-papaw-470214/
2010 Nissan Frontier 4wd DD
2008 Ford Escape Limited Awd Momma's Ride
1978 C20 Farm truck Sold
73Super8 is offline   Reply With Quote
Old 12-31-2014, 09:05 PM   #65
rusty76
rusty76's Avatar
You're digging in. Going in deep now!
My build thread
Crossmembers CC
Old 01-01-2015, 10:56 AM   #66
77K10Silverado
I just want it right because I don't plan on selling! Check out that crazy hitch someone welded to the frame and cut that huge hole in the crossmember to run it through... That ****s coming OFF!
Old 01-05-2015, 02:06 PM   #67
Jaredchevyk20
looks awesome!!
Jaredchevyk20 is offline   Reply With Quote
Old 01-09-2015, 09:30 AM   #68
77K10Silverado
Been super cold to get a lot done.. Blasted tank and straps and primed. Gonna try Chassis Saver Black on the straps and Silver on the tank. New hoses and fuel pump arrived. Also found a rust free filler neck at the yard and wire wheeled it clean! Ill Chassis Save it as well.
Old 01-09-2015, 12:12 PM   #69
Jaysonb
Jaysonb's Avatar
I enjoy your updates. Your doing a great job!! Love the truck.
Jaysonb is offline   Reply With Quote
Old 01-09-2015, 12:36 PM   #70
bowtieguy79
Ephesians 2:8
bowtieguy79's Avatar
Nice work! looks like this will be a nice functioning rig!
bowtieguy79 is offline   Reply With Quote
Old 01-09-2015, 07:01 PM   #71
rusty76
rusty76's Avatar
Looking good dude!
My build thread
Crossmembers CC
Old 01-10-2015, 07:32 PM   #72
y5mgisi
Second Chance Program
y5mgisi's Avatar
I too enjoy following along even if i dont post up much.
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 01-13-2015, 01:15 PM   #73
77K10Silverado
Thanks guys!!! I'll try and get some pics up later this week. I've been in the bed with the flu for a week..
Old 01-13-2015, 09:23 PM   #74
TheBlueBomber
TheBlueBomber's Avatar
Looks great man! Definitely is giving me motivation to work on mine. SUBSCRIBED
Austin
1996 Chevrolet K1500 Silverado
1979 Chevrolet K10 Scottsdale - Carolina K10 -
My 4.8L Twin turbo build - Project Short Stroke -
Instagram - TheBlueBomber1996
TheBlueBomber is offline   Reply With Quote
Old 01-13-2015, 09:24 PM   #75
TheBlueBomber
Get better soon. The flu is never fun.
Austin
