Old 11-17-2014, 02:17 AM   #1
nolimitssjca
Radiator Core Support Removal
I am replacing the engine in my son's 70 pickup. I want to remove everything in front of the engine to make it easy to pull. I have removed everything except the core support. It seems to be loose but resists coming out. It seems like it should slide out the front after all bolts are removed. Does it require the fenders to come out?
nolimitssjca is offline   Reply With Quote
Old 11-17-2014, 06:39 AM   #2
In The Ten Ring
Re: Radiator Core Support Removal
Bump as I'd like to know this too.
In The Ten Ring is offline   Reply With Quote
Old 11-17-2014, 08:01 AM   #3
jjzepplin
jjzepplin's Avatar
You don't have to take the fenders off all the way but they do have to be real loose as the support sits somewhat inside the fenders, It easier to though. Make sure you take out the frame mounting bolts under the radiator too.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 11-17-2014, 11:28 AM   #4
Saclandman
Saclandman's Avatar
It's also bolted to the inner fenders.
Rich J.
1967 Chevy C20 Longbed Stepside w/283 and 4spdSOLD
2002 Chevy Tahoe 4X4 5.3L SOLD
2015 Chevy Silverado Crew 4X4 5.3L
Saclandman is offline   Reply With Quote
Old 11-17-2014, 01:07 PM   #5
specialtyretail
So,, what else you got???
specialtyretail's Avatar
We have found it is usually just as easy to slip the whole front cap off as an assembly.
Our paypal is specialtyretail@yahoo.com Please DO NOTsend paypal funds as a gift, right is right. Thanks....
Sorry, we CANNOT ship larger parts. Thanks.
specialtyretail is offline   Reply With Quote
Old 11-17-2014, 05:13 PM   #6
nolimitssjca
I was hoping to avoid alignment issues and keep the clip on. With the grime rusty frame mounts I found, it needs to come out and get some love. Looks like I'm going to loosen a couple of fenders. Thanks gang.
core support
