Old 12-02-2014, 09:16 AM   #1
papsoldblue72
papsoldblue72's Avatar
Question lowering....
Has anyone on here cut coils to lower there truck??? Why is my truck lower in the rear than it is in the front??? Is that common on these trucks?? I have coils on the front and leafs on the rear.... I don't have the money for buying a big fancy four link air ride set up on the rear right now so I'm just gonna heat the springs on the back and cut the coils on the front or heat them also....
It's been a long time coming... It's time to get it done..
papsoldblue72 is offline   Reply With Quote
Old 12-02-2014, 09:57 AM   #2
1stchevy
1stchevy's Avatar
Re: lowering....
Cut the front coils do not heat them, and take a little off at a time.
1stchevy is offline   Reply With Quote
Old 12-02-2014, 09:58 AM   #3
67swb72klb
67swb72klb's Avatar
Re: lowering....
you can cut a coil out of the front with a cutoff wheel for around a 2" drop
but heat will ruin a spring don't do it
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 12-02-2014, 11:47 PM   #4
papsoldblue72
Re: lowering....
Okay so if I cut one whole coil off the front springs it should lower it about 2-3 inches.... Will it make it ride rough???
Old 12-02-2014, 11:55 PM   #5
thepenguin99
Re: lowering....
My truck has a coil cut out of the front springs and I don't find it to be a rough ride.
thepenguin99 is offline   Reply With Quote
Old 12-03-2014, 12:01 AM   #6
YBNORML
YBNORML's Avatar
Re: lowering....
Like stated above, cutting one coil will give you approx 2" of drop. I have done this many times on several different vehicles and noticed no real change in ride. Cutting much more will change the ride though. And not for the better.
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
coil, lowered, slammed, springs, static drop
