11-27-2014, 11:33 PM | #76 |
Loves all GMC trucks
Re: 72 K30 Build
Late to this build but I'm in for the rest!
Mike If your helping someone and expecting something in return... your doing business not kindness! |
11-28-2014, 02:30 AM | #77 |
Re: 72 K30 Build
Not sure about the K30, but my K20 didn't have enough room to install the HEI, the engine being in the rear frame mounting holes, so i went with a Mallory Unilite, its the size of the stock distributor.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
11-29-2014, 03:00 PM | #78 |
Re: 72 K30 Build
Your right on time Mike just getting started.
I'm thinking this might be the same deal.
Brett 67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594 72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.) 72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614 YouTube: https://www.youtube.com/@6dee7-7dee2 |
11-29-2014, 04:46 PM | #79 |
Re: 72 K30 Build
Subscribing to add ideas for another dream of mine!
Name: Les ---------------------- Couple 80s Couple 70s One 68 |
12-03-2014, 12:19 AM | #80 |
Re: 72 K30 Build
I thought there was a really good chance we were going to have to cut out the floor of this cab to clear the transmission, again due to 4x4 engine set back. The body is siting roughly 2” off the top of the K3500 frame rails and that is giving us plenty of clearance for this step even with the low floor. The RV cab we are planning on using is a high hump but I didn’t want to use it for this phase of the mockup because we need to repair the pass thru. It would really be a shame to tweak it trying to lift it by the roof when I have this other cab available. Also another shot of how close the pan is to the front crossmember. I'm kind of wondering if the square body big block pan is shallower than this 72 oil pan?
Brett 67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594 72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.) 72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614 YouTube: https://www.youtube.com/@6dee7-7dee2 Last edited by 7dee2; 12-03-2014 at 12:37 AM. |
12-03-2014, 12:33 AM | #81 |
Re: 72 K30 Build
So little to no gap in the wheel well and again inner fenders look like they were made for this frame! Tire does sit a little forward in the opening (1.5" or so) but we can live with that. Also not a lot of frame rail exposed under the cab. Trying to build the truck so it looks like it came that way from the factory.
12-03-2014, 12:35 AM | #82 |
Re: 72 K30 Build
Wow! Looky there! You're probably going to have that thing on the road before I figure out what I'm going to do with my flywheel and clutch!
12-03-2014, 12:41 AM | #83 |
Re: 72 K30 Build
My old school build will be easy compared to your high tech stuff Mike!
12-03-2014, 01:04 AM | #84 |
Re: 72 K30 Build
It's the old school stuff that's holding me up
12-05-2014, 05:34 PM | #85 |
Re: 72 K30 Build
So the next item up is to start repairing the pass thru on the RV cab. First off we need to find a new storage spot for my mirror collection and misc. stuff.
12-05-2014, 05:42 PM | #86 |
Re: 72 K30 Build
Here are some shots of what we are starting with.
12-06-2014, 12:00 AM | #87 |
Re: 72 K30 Build
The part i have been waiting for huh?
12-06-2014, 12:57 PM | #88 |
Re: 72 K30 Build
Yep, time to see if we can save the RV cab.
12-08-2014, 11:41 AM | #89 |
Re: 72 K30 Build
Patch panels acquired earlier from budnikguy. http://67-72chevytrucks.com/vboard/s...5&postcount=15
12-10-2014, 06:39 PM | #90 |
Re: 72 K30 Build
Let’s see how bad this is. Those camper guys had some big stones to do this to a new truck back in the day!! Last pic we had to grind the carriage bolt heads off to get the angle iron frame out.
12-10-2014, 06:46 PM | #91 |
Re: 72 K30 Build
They left some of the inner roof skin and just rolled it back.
12-10-2014, 06:51 PM | #92 |
Re: 72 K30 Build
They cut and crushed the inner back panel.
12-10-2014, 06:59 PM | #93 |
Re: 72 K30 Build
Last shots of the carnage!
12-10-2014, 08:20 PM | #94 |
6>8 Plugless........
Re: 72 K30 Build
I think I'd just cut it past all the damage and weld you patches in instead of trying to straighten their mess out.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
12-10-2014, 08:50 PM | #95 |
Re: 72 K30 Build
^^ x2!
12-12-2014, 05:56 PM | #96 |
SWB 4x4 Collector
Re: 72 K30 Build
You should be fine.....it don't look that bad. Trevor
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
12-13-2014, 12:01 PM | #97 | |
Re: 72 K30 Build
Good that's what I thought also. If I had your skills Trevor it would already be done. One of my friends told me to slap my patch panels on there with screws and silicone! (He was kidding I think?)
12-15-2014, 01:36 PM | #98 |
Re: 72 K30 Build
Another suggestion was using a flange type of repair rather than a butt weld. I thought that was a pretty good idea as it is a little more forgiving when or if you cut your patch short. Might even make the repair stronger with a flange? Picked up this pneumatic punch/flange tool from HF and started to play around with it.
12-15-2014, 03:07 PM | #99 |
Re: 72 K30 Build
I just had an idea but keep in mind i'm not a body man and never used it...
When i was getting ready to do my gas door my uncle also recommended using a flanging tool, but he also recommended using automotive body adhesive like is used in the newer body repair, i don't know anything about it but think its probably a 2 part epoxy? Maybe there is just too muck area to assemble and squeeze into place tho not sure. Then how to squeeze it all into place? Cleco's perhaps? http://search.eastwood.com/search?p=...d&w=Cleco&rk=3 Ether way i like the flanging idea and agree i think it will be helpful to keep it ridged.
12-15-2014, 05:22 PM | #100 |
Re: 72 K30 Build
I bought the same flange tool from HF as well. it worked good for punching hole to spot weld parts together. my builder trims the part about 1/2" bigger and steps a flange in it makes for a stronger joint and you don't have the warping issues from but welding sheet metal together.
Tags |
72chevy, dually, flatbed, k30, motorhome |
