12-29-2014, 05:28 PM | #1 |
Charcoal Canister Removal Question
Can any one explain the charcoal canister removal procedure. I know you will need a vented gas cap, but what about the vacuum ports on the carb. I read the canister goes bad over time, can you substitute one from a later model GM truck ? This is all aimed at eliminating a vacuum leak on my 350 with factory intake and original Quadrajet......
71 C-20 07 Magnum RT AWD |
12-29-2014, 07:52 PM | #2 |
Re: Charcoal Canister Removal Question
Isn't the canister just a controlled "leak" anyway, and won't a vented tank condense more moisture into the fuel than a closed system? Inquiring minds want to know, so those of you with knowledge please share.....
12-29-2014, 11:22 PM | #3 |
My dad's truck ran just fine for 20 years with the canister unplugged and the hose simply taped shut.
12-30-2014, 01:00 AM | #4 |
Agreed, 3 trucks I've had with canisters were disconnected long before I got them, never an issue. Honestly couldn't even tell you what it was for up until a couple of years ago.
-Sterling GIG EM' AGGIES!!!! WHOOOOOOP!!!!! "Whether you think you can or think you can't, you're Right." -Henry Ford 1972 chevy lwb 1934 ford p/u |
12-30-2014, 09:54 AM | #5 |
If you just disconect the hoses to the canister no vented cap is required
12-30-2014, 10:33 AM | #6 |
Canister purge is not such a bad thing. I would buy a new canister and be done with it.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
