Closed Thread
Old 01-06-2015, 01:09 AM   #1551
mattwhiteyanks1
Re: What did you do to your truck today? Chapter II
Mocked up some motor mounts for my 70 swb 5.3/4l80-e project
mattwhiteyanks1 is offline
Old 01-06-2015, 01:54 AM   #1552
real69ss
real69ss's Avatar
Apparently I had two wires make contact on my starter while driving to work, the back fire was so loud that Patton would have been impressed, melt my battery cable, kill my (Optima) battery and .......
These are the mufflers that included with LMC's "Complete V8 high performance dual exhaust system...." . Great kit, could use a little bit better instructions, and the fit is a little bit tight on a lowered truck.
So I ......
And all is good !
1968 C/10 short bed
1969 SS 396 Camaro
"there's no replacement for displacement"
real69ss is offline
Old 01-06-2015, 02:07 AM   #1553
Churchill
Churchill's Avatar
pulled the edge of the rubber flooring on the passenger side and saw some crud . wiped it out with my key. tapped the floor in that spot a couple times and made a pinhole of daylight through my floor I though my floors were solid
Churchill is offline
Old 01-06-2015, 08:28 AM   #1554
outdoorsman310
outdoorsman310's Avatar
those new mufflers should hold up to many backfires!
outdoorsman310 is offline
Old 01-06-2015, 11:58 AM   #1555
texasld
texasld's Avatar
Originally Posted by DeadheadNM View Post
Got my NOS tailgate hinges powder coated...
Did you do them yourself?
1969 C10 SWB 5.3L LS, 4l60e, 2/4 drop (In Progress)
2015 GMC 2500 Duramax (Daily Driver)
1999 Jeep TJ
2010 Harley Street Glide
Check Out My Build!: http://67-72chevytrucks.com/vboard/s...d.php?t=617981
texasld is offline
Old 01-06-2015, 11:59 AM   #1556
texasld
texasld's Avatar
Are you making your own?
1999 Jeep TJ
texasld is offline
Old 01-06-2015, 01:56 PM   #1557
bonnieclyde100
Originally Posted by magwakeenercew2jh View Post
I taught myself that I have not learned a damned thing about building these trucks in all my 68 years.
On my way to take care of the chickens this morning ("Yes, dear." "I'm glad you want to have eight chickens just like your old Italian neighbor
did when you were a kid." "I'm sure that you *will* do all the work."), I passed RAT siting and waiting for the rest of the stuff that's coming
(white face overlays) in order to install a slick amp:volt gauge kit from Forum Member, Forum Merchant, and all around good guy Tom at:
http://www.classicgaugeandcluster.com/
I remembered that I'd been head-scratching over the dash lights going dark a couple of months after installing the LCDs. Since I don't drive
much in the dark, I'd forgotten that I need to address that. And, since I want to pull the dash and bezel to install the kit from Tom, and I'd
already checked the fuse block on the chance that...well you know...fuses.
So, off with the dash grommet retainer, parking brake assy., undo the screws, push the light switch button under the dash to pull the "switch mast",
unscrew the ww and faux choke knobs, unbolt the under-dash steering column yoke, unscrew the phillips that hold the bezel on....clip the lines to
the non-GM tach. Unbolted the oil pressure gauge line, and the speedo cable.
Replaced a bulb that was burned out (one of the orig. that I couldn't reach when I installed the LCDs).
No dash lights (juice is there at the connector, 'cause the turn signals, etc. work). Brand new M&H harness. Pretty.
Got on the ground with a flashlight and peered at the fuses again. Pulled the 3A cluster fuse. Looked good. "WAIT!!!" "LOOK!!" "Hold it up to the light!"
"It's ever so slightly blown." Which means, it's blown.
Glad I waited to multi task to pull the dash, (the amp gauge:volt gauge conversion from Tom), or I'd really be pissed at myself.
do yo have any pics of you building that console for the screen? ihave one and i am looking for ideas. i was even thinking of putting mine in the sun visor but i like your idea also.
bonnieclyde100 is offline
Old 01-06-2015, 02:28 PM   #1558
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Not a bunch of pics of this. But here's one:
Here's a parts list:
About ten feet of 4 7/8" (or whatever it is) left over flooring material...any floor installation place has a bunch of 18" scraps.
A yard of carpet that matches your interior to your liking (mine was under $20 from the dollar store...I got about 2.5 yds) ...
...the stuff I had was left over from the tank cover and kick and lower door panels.
Some heavy poster board or cardboard for templates.
A hundred different (in different sizes) wood and sheet metal screws.
About twenty feet of 1 x 2 scrap wood. Maybe twenty feet of 1 x 1 if you want to rip the the 1 x 1.
Four 1/2" "L" brackets (with the legs about 1-1/2" on each side) to hold the cabinet to the floor on the bottom, and screw
(or bolt) through to the existing holes under the a/c or heater controls on the under side of the dash.
Some spray glue to attach the carpet to the outside of the box. Some Elmer's wood glue to stiffen up the wood support
joints inside the box.
Some kind of clamps to help you hold everything in place while you glue/screw..... Unless you have six hands.
After I did the interior bracket for the radio, I cut the hole in the face plate (made of 2 sections of the floor material glued together),
I covered the face with some faux-carbon fiber material. I had to attach blocks inside the at the corners of the box to screw the face on.
I wanted/needed access for the electronics installation and for playing with it, if necessary, down the road.
For me, it was about thirty bucks and a few days of work. Would be less if I don't count the carpet. In actuality, it really only cost me the
gas to get to a friends house to snag some scrap bracing wood. But, I already had all the stuff laying around.
This one's not for everyone. But it serves my purposes pretty well.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 01-06-2015, 03:51 PM   #1559
bonnieclyde100
thanks that will help
Old 01-06-2015, 09:13 PM   #1560
jethro5333
Smile Re: What did you do to your truck today? Chapter II
got the Flowmasters installed today. tomorrow put the bed back on and get ready for paint.
jethro5333 is offline
Old 01-07-2015, 02:29 AM   #1561
mattwhiteyanks1
Yeah, I know they make tons of kits but, it's just as easy for me to fab some up. I'd rather know I have everything where I want it, as opposed to it sitting where somebody else thinks it should be.
Old 01-07-2015, 03:03 PM   #1562
texasld
texasld's Avatar
Cool! Make sure you post some pictures! Have you been posting in the LS Swappers thread?
1999 Jeep TJ
texasld is offline
Old 01-07-2015, 07:25 PM   #1563
mattwhiteyanks1
No, but I'd like to. I'm not sure how to move my post into certain sections or categories. I'd like to move my build thread into the build thread.
Old 01-07-2015, 10:10 PM   #1564
joeydurango
joeydurango's Avatar
Aligned my '72 today. The alignment shop got two tries first... but apparently this truck "isn't in the computer" (go figure) and after I told them how to measure for toe, then received it back toed 3/16" OUTWARD, I just said screw it and did it myself. I guess the old saw about doing it yourself is true...
Now the truck is toed factory 1/8" in and drives better than ever.
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER
1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD
1976 Trans Am | 400/4-spd | SOLD
1976 Trans Am | 455/4-spd | TOTALED
joeydurango is offline
Old 01-07-2015, 10:52 PM   #1565
Possmguts
Possmguts's Avatar
Just spent the day cleaning bolts and painting them.... Not much else to do right now till the ole lady stops spending my parts money on un-necessary crap like food, and gas, and kids schooling and stuff like that. Work is slow right now.... Story of my life, when i have time I have no money and when I have money I have no time.... Life, go figure....
"Hey... its only time and money right? Just do it."
67 Short Bed under major construction
http://67-72chevytrucks.com/vboard/s...=651356&page=8
Possmguts is offline
Old 01-08-2015, 12:06 AM   #1566
texasld
texasld's Avatar
Same for me. This is how I battle it, though. Lots of work and no time? Buy parts. Lots of time and no work? Install said parts! works every time!
1999 Jeep TJ
texasld is offline
Old 01-08-2015, 09:58 AM   #1567
Possmguts
Possmguts's Avatar
Ive had over 1000 bucks of body parts and patches sitting in my LMC shopping cart for 3 weeks or so now.... It will be the first sizable purchase. Ive done smaller stuff that has to sit until its time for them. You know, the stuff you see for a great deal but are nowhere near ready for buy you couldnt pass up.
Old 01-08-2015, 05:30 PM   #1568
R.L.
R.L.'s Avatar
Yesterday I installed a vacuum gauge, today I replaced the heater core I broke while routing the vacuum line for the gauge. I guess I stepped on the hose while I was under the hood. Go figure the coldest day of the year too.
R.L. is offline
Old 01-08-2015, 07:48 PM   #1569
Steeveedee
Who Changed This?
Steeveedee's Avatar
Attachment 1345409
Attachment 1345410
So I ......
Attachment 1345411
And all is good !
Those blowed up real good! Nice looking new mufflers.
All I did today was drive mine for the first time in a few weeks. Too much going on, and I'm retired!
~Steven
Simi Valley, CA
Steeveedee is offline
Old 01-08-2015, 09:09 PM   #1570
gutterworks129
I cleaned and prepped/painted this engine that was in a barn for 8yrs in VA. I bought a project truck that the guy gave up on 8yrs ago.
gutterworks129 is offline
Old 01-08-2015, 10:05 PM   #1571
ole dollor
ole dollor's Avatar
[QUOTE=gutterworks129;6991609]I cleaned and prepped/painted this engine that was in a barn for 8yrs in VA. I bought a project truck that the guy gave up on 8yrs ago
very nice clean up and paint job, and welcome to the forum from Texas, we like lots of pic's keep them coming...
ole dollor is offline
Old 01-09-2015, 09:14 AM   #1572
jethro5333
got the bed back on. that was a neat trick by myself! as soon as it warms up a bit, I'll get some paint on it.
Old 01-09-2015, 11:02 AM   #1573
texasld
texasld's Avatar
Brazed a 3/8" hose barb in my factory rad for my LS Steam port.
Name:  Barb installed.jpg
1999 Jeep TJ
texasld is offline
Old 01-09-2015, 11:47 AM   #1574
CST10
CST10's Avatar
Put an ol school stagger tall fat/small skinny tire combo on ol Owen and painted the wheels white.
MyToys:
Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles.
Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop.
Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ.
Member of the Louisiana Classic Truck Club, LCTC
Member of the Louisiana C10 Club
Member of the Baton Rouge Drifters Car Club
CST10 is offline
Old 01-09-2015, 11:48 AM   #1575
CST10
CST10's Avatar
Gave me the rake I wanted to.
MyToys:
CST10 is offline
Closed Thread
