01-03-2015, 05:16 PM | #26 |
Re: I'm COLD. NEED HEAT. GOING MAD
I've trout fished (and salmon) all over the world, and I will got there again!
1963 Chevrolet C-10 "Ginger" 1970 C-30 Dump Truck "Scarlet" 2019 Chevy Silverado 2500 Z71 LTZ 1947 Indian Chief Roadmaster with Sidecar. 2012 Indian Chief Serial #002 of 110 built in '12 2016 Indian Chief Roadmaster |
01-03-2015, 06:52 PM | #27 |
Check out ecklers.com they have a great sale on a heater core til 5th of Jan. I ordered one for 10 bucks. It is alum but can't beat under 20 bucks shipped.
01-03-2015, 08:52 PM | #28 | ||
, B) may capture more cold air in the process anyway, and most importantly C) if the problem is the water pump, or some other cooling system component, modifying the heater box would be redundant. Let us know what the result is of changing the heater core.
Craigerrr My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709 |
01-03-2015, 09:05 PM | #29 |
I got a radiator core from autozone a couple of years ago (2008??) and it was a copper core.. Not sure if they still have them or not. also mine was with A/C.
My project has the heater off of the firewall (there is a giant hole there now) and electric radiator fans. Driving it around so far I have to crack the windows in 40* weather when i have the fans on because there is so much warm air coming off of the radiator through the firewall
-- Josh Instagram: @americanmusc1e OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread 1999 4wd OBS Tahoe - daily. DM me if you can't see photos i posted |
01-06-2015, 04:02 PM | #30 |
crgrs, you're absolutely right. I really should get the pump checked. It's at least 11 years old, and the truck did sit for a long while. I'll have to get a pump installed in the next few weeks.
I've been sick, and still haven't gotten the heater core installed, but I will hopefully do that in the next few days. (head colds suck...)
2013 Malibu LTZ 1996 C1500 4.3/5spd 2wd |
01-06-2015, 04:10 PM | #31 |
Hope you get to feeling better, bad flu out this way , no Zombie sitings yet! 8 people dead from the flu in NC.
01-06-2015, 05:45 PM | #32 |
Wow, that sucks. Lets pray it's not Captain Tripps...
01-06-2015, 06:20 PM | #33 |
My truck was a home to gophers for many years. They had completely taken all the seat material apart and packed it into the heater ducting all the way into the heater box and fan. I cleaned it all up and put in new ducting. Can't say the heat is that good though. Certainly not quite as good as in other vehicles I've had of the same vintage but still tolerable. Also the heat control levers were off or broken so had to get those working. Do your levers work and is it blowing lots of air where it is asked for?
01-06-2015, 06:43 PM | #34 |
vince,
I pulled the airbox apart, cleaned it, cleaned the core, replaced the blower motor, cleaned the plenum box, and made sure the two flaps both work. I can select between windshield defrost, and floor. The hot/cold flap works. The only issue here is not enough heat coming from the airbox. Don't get me wrong, It's relatively warm, just not warm enough. I get 50 degree air when the temp outside is about 40. I have to run the truck for about 15 minutes to get the coolant warm, and then turn on the fan to get any effect out of the windshield defroster.
01-06-2015, 07:30 PM | #35 |
Like jtrichard said "some pics of how your hoses are ran" from the water pump to the heater box under the hood and back would be good. I had this issue when I was 15 years old with heat in an old Nova, I had put the TStat in upside down causing it to run hot along with no heat. My Dad laughed his ass off at me for a week or so.
01-06-2015, 07:35 PM | #36 |
i asked for pics because i have seen them hooked up totally wrong and NO hot water was going through the core
01-06-2015, 07:42 PM | #37 |
01-06-2015, 08:07 PM | #38 |
I noticed a good question that I don't believe was asked previously...
Vince1 asked if the blower was blowing air where it is asked for. Are you getting strong air flow from the fan? Still think you need to look at the water pump, but just wanted to clarify that the fan is blowing ample air.
01-06-2015, 09:17 PM | #39 |
Yes, the blower works very well. I tried posting photos, but i cant seem to get them to upload.
01-07-2015, 03:31 AM | #40 |
Lets see if this works. Posting fro my phone.
01-07-2015, 04:07 AM | #41 |
Well, I went to post the ones you sent and lo & behold! I'm digging the skull on the air cleaner! The hoses look right to me, but it's 0305 here and 9 degrees, and I ain't going outside to check! My memory ain't what it once was. I think it happened in '69, or it could've been '72?
01-07-2015, 07:11 AM | #42 |
I had the same problem with my other c10. Once I lit the truck on fire the heat problem went away but I started to have other problems. Fortunately however, my thermostat seems to be working perfectly!!
01-07-2015, 10:24 AM | #43 |
You know what they say; light a fire for a man, he'll be warm for a night. Light a man on fire, he'll be warm for the rest of his life.
01-07-2015, 11:20 AM | #44 | |
That skull was painted about 15 years ago, when I was 15, and was originally done for my dad's Monte carlo. His carb and transmission found their way into my truck, so I figured it to be only proper to clean it up and put it on my truck. Here's a better view of it.
2013 Malibu LTZ 1996 C1500 4.3/5spd 2wd Last edited by Figuarus; 01-07-2015 at 11:22 AM. Reason: I cannot word this early in the morning |
01-07-2015, 11:57 AM | #45 |
Never Ending Projects
Hoses look correct. On the 3/4" hose, when the truck is at operating temp, is this hose the same temp as the upper radiator hose? They should feel the same, almost too hot to touch. If they are, does the 5/8" hose feel only slightly cooler or does it seem a lot colder? This will tell you if you are getting heat in and out of the lines.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
01-07-2015, 12:39 PM | #46 |
the 3/4 definitely gets hot, and isn't QUITE as hot as the radiator hose, but it's pretty damn hot. (I have a metal flex hose on the upper line @ the radiator.)
01-09-2015, 04:25 PM | #47 |
Ok, i pulled the core, inspected it, cleaned it out and re-installed it. Same issue.
Someone mentioned water pump, but i got to thinking that if the water pump was bad, I would be overheating, but have no flow to the core. I'm leaning towards a restriction, but I don't think it's in the core. I'm wondering if there is something at the pump itself, or in the manifold.
01-09-2015, 06:23 PM | #48 | |
1964 Bare to the Bones |
01-09-2015, 08:19 PM | #49 |
dissimilar metals tend to cause fierce corrosion. maybe the nipple n tee coming off the water pump are restricted? could you take the hose off and shove a screwdriver in there to see if it is clear?
01-09-2015, 08:53 PM | #50 |
there a few ways to positively identify what is wrong .. first , it looks like you have your hoses right , second once it is fully warmed up , you should feel both sides of the heater core where they go into the core ,if both are not scorchin hot , then it is your heater core , if one is cooler , then you can be sure your core is plugged....
Tags |
blower, core, heater, heating, radiator |
