01-02-2015, 11:49 AM | #1 |
6.0/4l80 first start
https://m.youtube.com/watch?v=wRPogy...ature=youtu.be
First start of my swap. It's a LQ4 with a set of 241 heads and a ls3 cam and valve springs. |
01-02-2015, 12:28 PM | #2 |
Re: 6.0/4l80 first start
Engine bay pic
01-02-2015, 03:54 PM | #3 |
Boosted Member
Hell yea! Nice work. Needs moar cam.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
01-02-2015, 04:15 PM | #4 |
No it needs a pair of these!
01-02-2015, 05:10 PM | #5 |
Boosted Member
Why can't you have both? They work pretty well together
01-02-2015, 05:24 PM | #6 |
Money that's a rebuilt 6.0 and a gm reman 4l80. Eventually I wanna boost it but I didn't want the truck sitting for months or years waiting to do it all. I like driving that thing and it would kill me to just have it sit.
01-02-2015, 05:44 PM | #7 |
Boosted Member
Well there you go.
01-03-2015, 12:26 PM | #8 |
Awesome, congrats. That must have been a great feeling.
01-07-2015, 04:02 AM | #9 |
hell yeah!!!! sounds awesome man congrats elimontfort !!! .. what did you use for headers? and mufflers? motor mounts? give us the details man come on..post more video of that bad a$$ !
01-07-2015, 10:30 AM | #10 |
L92 it's a lq4 with cathedral heads, a ls6 cam and valve springs. I used cpps swap kit. It came with the Doug thorley headers. I couldn't use the crossmember out of the kit it was too wide for some reason it stuck out past the frame rails by almost a inch. So I used my 700r4 crossmember from bowtie Overdrives it worked fine on the 4l80 and gave me more room for the exhaust. I'm not sure what mufflers I'm gonna run I have a set of 40 series flowmasters but I think I wanna switch but not sure yet. Still have a bug to work out on the motor my ltfts for bank two are way too high almost on the 23 range and I'm getting a p0174 code for bank 2 lean. I know it's not a vaccum leak so I'm gonna swap the injectors over this weekend to see if it moves. I'm also waiting for my aluminum drive shaft to get made then I can do some donuts.
01-07-2015, 12:59 PM | #11 |
Pic of the truck. And I realized I put ls3 cams and head in the first post it's ls6 junk in there!
01-07-2015, 01:13 PM | #12 |
Nice. Cool truck. I can't wait to get my 6.0/4l80 running in my truck but I first have to learn how to make decisions
Ryan 1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840 1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628 1967/71 Blue SWB C10..SOLD 1977 SWB K10..my grandpa's.....never should have sold |
01-07-2015, 01:27 PM | #13 |
I finally said f it and did it. I ordered the motor and trans sept 16th got it oct 29th and fired it up jan 1st. It wasn't that bad but some things I wish I had done different. I highly recommend pulling the front clip to install the engine and trans together. I have a 4 inch drop and couldn't get it in so I had to break it apart. The trans is HEAVY and TALL and doing it on the ground was a pain by myself even with a trans jack. I like your stepper slowcpe. I wasn't a fan of them but they are growing on me. if my bed was trashed I would probably convert it but its in really good condition.
01-07-2015, 03:15 PM | #14 | |
Once I actually pulled a front clip and learned how ridiculously easy it was I will never install another engine without pulling it again.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy Last edited by tinydb84; 01-07-2015 at 03:15 PM. Reason: add more |
01-07-2015, 03:26 PM | #15 |
Boosted Member
Yup. Front clip comes off every time the engine comes out. WAY easier to work on stuff that way.
01-07-2015, 04:42 PM | #16 |
meowMEOWmeowMEOW
IF someone would make a flip-nose front clip for the 64-66 that actually was any good, I'd be on one in a second. I love being all steel, but if I could dump 150lbs off the nose AND make it easier to work on....whooo I'd be all over that.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
01-07-2015, 05:27 PM | #17 |
I guess I'll have to plan on pulling the front end off my truck when I put an LS in it. I wonder if it's ever been off...
1973 C20, 350/350 |
01-07-2015, 06:46 PM | #18 |
Yeah we ended up pulling the whole front clip to get the 6cyl out. Just made things easier but now turned my truck into a full frame off. My front clip was a bit of a pain to get off due to rusty bolts, but if I put fresh ones in, it would probably be a piece of cake the next time.
Thanks elimontfort
01-07-2015, 08:46 PM | #19 |
meowMEOWmeowMEOW
Did you pull each peice off, or just pull the clip as an assembly? Its the difference between a 30 minute process and 2hour process lol.
01-07-2015, 10:52 PM | #20 |
Can it seriously be done in half an hour? If so, is that true for square bodies as well?
1973 C20, 350/350 |
01-07-2015, 10:58 PM | #21 | |
I had my radiator out and fender wells out. Might have been less than half an hour to be honest. You need a second person (or two) to lift it off. It is much easier if your wheels are off to.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
01-07-2015, 11:53 PM | #22 |
Whoa! man she looks really nice really like her stance. Cant even imagine what you feel gripping the steering wheel knowing you got LQ4 lionheart in your truck. Actually got my 77 after i couldnt find a c10 like your body style. Congrats man nice truck and really dig the 6.0 swap. thanks for the informative reply.take it easy
01-07-2015, 11:56 PM | #23 |
I guess I'll have to try that when I do an LS swap. Of course, first I have to find somewhere to do it, no garage for now
1973 C20, 350/350 |
01-08-2015, 10:51 AM | #24 |
Awesome!!!!! Can't wait to start mine!!!
01-08-2015, 11:29 AM | #25 | |
Boosted Member
