#51 | |
![]() Join Date: Jul 2014
Re: 1977 K10 Silverado Longbox
I have since picked a used one and buffed it out. The one pictured is the old, ill post the new tomorrow. I actually went through the cluster and installed a new wiring circuit and leds. I just didnt document very well so I never posted on it.. But yeah it was plum ruined! Thanks for the offer kind sir! |
#52 |
I was just looking on 4 Wheel Parts website and you can get those tires in a 33x10.50. That might help with the tall skinny look. I have 31's on my truck also and would like to go with something a little bigger.
Those printed circuits are a pain. The laminate on mine was coming a part in one area. I just tried to be careful with it when putting the cluster back in. So far everything still works. |
#53 |
I think if I went with the 33/10.50 I would have to get into a small lift.. No sure that's what I want to do as of now. But your right, that would get it taller!
Here's a pic of the LEDs. Not a great pic but they do help light it up. Not able to dim is the downside. |
#54 |
That looks great!
![]() I'm with you on keeping it mostly stock with no lift. I have read here on the forum that 33's will fit using the stock wheels without a lift. However, I'm thinking they might rub offroad? Most 33's are 12.50 on the width. You can get the BFG's in 33x10.50 so they might have a better chance of fitting with no rubbing. Your truck remind me of a 76' 2wd long bed I had. It was the same 2 tone colors as yours, but repainted solid blue just like yours. |
#55 |
Anything done to this beauty lately?
Dad's: 1973 Chevy C-60 Grain Truck 366 Big Block Dad's: 1982 Chevy Silverado 6.2L Diesel K-10 Dad's: 1987 Chevy Silverado TBI 350 R-10 Dad's: 2007 GMC Sierra Classic 2500HD SLT Mine: 1982 Chevy Silverado 6.2L Diesel K-10 |
#56 |
Looking good. I recognize your inspiration truck. I'm pretty sure I know where it is. Cool truck. I've looked at it several times while passing by. Clean looking for sure.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
#57 |
Did a few things this weekend. I needed to get to the gas tank to replace restore. That's next on the list. Prob go ahead and redo all lines while the beds off.
#58 |
#59 |
How hard was it to replace the pins and bushings? That's something I get to look forward to on my '76.
#60 |
Rusty76... It was a breeze. Took about 20 -30 mins. I used a jack with a 2 ft piece of railroad tie to support the door. Penetrating oil, a socket and wrench. Hammer to knock the pin up and out. Screwdriver to knock out one of the stubborn bushings. When tapping back in the new bushings, do it gingerly cause they break. Good luck with it!
#61 |
Thanks. It's coming all in due time. I've got a ways but still I like to do my homework.. Thanks.
#62 |
Ok so while I have the bed off, a few things need to be addressed. Dropped the tank to fix the original problem. Gas was leaking out every time I filled up. Filler hoses were rotten. I order a new sending unit lock rig and gasket. Also ordered strap pads and paint for the tank once I get it clean up and sanded. It looks spotless inside, and it's original with USS stamp. I plan on powder coating the straps along with new hardware. I also ordered a can of Chassis Saver in the vintage flat black. Time to get to work!
#63 |
#64 |
Wheel and tire combo is stunning! Lookin good.
1973 K10 Super 8 http://67-72chevytrucks.com/vboard/s...d.php?t=645525 Sold ![]() 1988 S10 http://www.s10forum.com/forum/f135/p...-papaw-470214/ 2010 Nissan Frontier 4wd DD 2008 Ford Escape Limited Awd Momma's Ride 1978 C20 Farm truck Sold |
#65 |
You're digging in. Going in deep now!
#66 |
I just want it right because I don't plan on selling! Check out that crazy hitch someone welded to the frame and cut that huge hole in the crossmember to run it through... That ****s coming OFF!
#67 |
looks awesome!!
#68 |
Been super cold to get a lot done.. Blasted tank and straps and primed. Gonna try Chassis Saver Black on the straps and Silver on the tank. New hoses and fuel pump arrived. Also found a rust free filler neck at the yard and wire wheeled it clean! Ill Chassis Save it as well.
#69 |
I enjoy your updates. Your doing a great job!! Love the truck.
#70 |
Ephesians 2:8
Nice work! looks like this will be a nice functioning rig!
72 Suburban making it mine My 79 C10 story 79 C10 LS swap 94 LS swapped Daily Driver Tahoe Limited Instagram - @piersonclassics 83 K20 Farm Truck Build |
#71 |
Looking good dude!
#72 |
Second Chance Program
I too enjoy following along even if i dont post up much.
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt. 77 C20 crew cab Silverado. 396/th400. In work. |
#73 |
Thanks guys!!! I'll try and get some pics up later this week. I've been in the bed with the flu for a week..
#74 |
Looks great man! Definitely is giving me motivation to work on mine. SUBSCRIBED
Austin 1996 Chevrolet K1500 Silverado ![]() 1979 Chevrolet K10 Scottsdale - Carolina K10 - My 4.8L Twin turbo build - Project Short Stroke - Instagram - TheBlueBomber1996 |
#75 |
Get better soon. The flu is never fun.
