Old 01-11-2015, 02:00 AM   #2701
trkfrk
trkfrk's Avatar
Re: Project "What was I Thinking" 68 SWB
Looking good Keith I can't wait to see some red..
Mark
1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20"
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609.
My first start up http://youtu.be/R899YQ1OcjU
trkfrk is offline   Reply With Quote
Old 01-11-2015, 11:43 AM   #2702
Bhelton
Bhelton's Avatar
Going to be slick!
Bhelton is offline   Reply With Quote
Old 01-11-2015, 12:27 PM   #2703
jlsanborn
jlsanborn's Avatar
Nice job man, keep on rockin!
'77 K30 3+3 - "The Crummy"
http://67-72chevytrucks.com/vboard/s...d.php?t=640134
'67 C10 L/SWB - Soon to be daily driver!
http://67-72chevytrucks.com/vboard/s...d.php?t=471776
jlsanborn is offline   Reply With Quote
Old 01-11-2015, 02:48 PM   #2704
mx289
mx289's Avatar
Looks good Keith.
Tom
71 K2500
71 K5 Jimmy
mx289 is offline   Reply With Quote
Old 01-11-2015, 03:09 PM   #2705
RRR18
RRR18's Avatar
I'm in for following you also Keith.
'67 BAD IDEA
Follow on Instagram https://www.instagram.com/rtimes3c10/
Ryan
RRR18 is offline   Reply With Quote
Old 01-13-2015, 09:54 AM   #2706
knomadd
knomadd's Avatar
Everything's looking good!
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 01-13-2015, 12:54 PM   #2707
Bennett68C10
Bennett68C10's Avatar
Originally Posted by kxmotox247 View Post
looks great! Can't wait to see some paint on it.
Originally Posted by zicc1835 View Post
really looking goooood.... maybe early spring .... i bet we see some color ....
Originally Posted by mcbassin View Post
Very nice work Keith
Originally Posted by Bhelton View Post
Going to be slick!
Originally Posted by mx289 View Post
Looks good Keith.
Thanks guys, I still have alot of blocking left to do on the cab and haven't had much time lately so my timetable on getting some paint laid down has been pushed back again. At the rate I work, ill be lucky to have paint on this cab by the spring I'm not too concerned about it though, i've stopped driving myself crazy with a deadline to get the truck done. I now have the idea it will get done when it gets done as long as it is done right.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 01-13-2015, 01:27 PM   #2708
KMC3420
KMC3420's Avatar
Hey Keith, love the progress. You will get it done all in good timing, rushing things always ends up messing something up anyways. I was curious about your paint scheme as I am going with red on mine as well. On the front end are you going to run trim across the front of the hood and on the front of the fenders, if not, where are you going to stop/start with the white red? I have already welded up the trim holes on my 68 fenders. Just wondering what your plans are.
Keagan
68 SWB C-10 original 350 A/C 503 Mean Green
KMC3420 is offline   Reply With Quote
Old 01-14-2015, 10:39 AM   #2709
knomadd
knomadd's Avatar
Originally Posted by Bennett68C10 View Post
...I now have the idea it will get done when it gets done as long as it is done right.
This is probably the best way to do it. I know some guys need a deadline for motivation, so it would work for them, but you might be like me. I don't need the added pressure to rush through it and cut corners to have an end result that will produce regrets for not doing a better job before paint. I'm sure you'll be happier with the end result knowing you did the best you can, without rushing it.
-Duane
Old 01-17-2015, 10:35 AM   #2710
JakeDW
JakeDW's Avatar
Just read through this for the first time really nice work truck is gona look great.I vote keep the big block put a roller set up in it and fuel inject it.
Jake
JakeDW is offline   Reply With Quote
Old 01-19-2015, 06:05 AM   #2711
Bennett68C10
Thanks, your right if I rush it I'm bound to mess it up and then I won't be happy with the final product. I plan on running the front trim and having the paint line under the trim so it covers it. That's how my truck was originally.
Yeah having the deadline was driving me nuts, like you said the added pressure to get it done within a given amount of time was mentally exhausting. I'm going on my 6th year and it's still not done so I decided to throw deadlines out the window. I'll be happy when it's finally done but only if it's done right and is exactly how I want it.
Jake
Thanks Jake, unfortunately the big block is leaving, I'm going to pick something up today to take it's place
Keith
66 Suburban
IG: bennett68c10
Old 01-19-2015, 09:25 PM   #2712
Bennett68C10
Picked up the new power plant today, an LQ9 out of 2005 Escalade with 90k on the clock. It is a complete dropout, included everything front accessories, computer, uncut harness, maf, peddle etc. I couldn't pass it up, it is a very clean motor Doesn't look like much now but it will when I'm done with it.
Keith
66 Suburban
IG: bennett68c10
Old 01-19-2015, 09:26 PM   #2713
Bennett68C10
Keith
66 Suburban
IG: bennett68c10
Old 01-19-2015, 09:28 PM   #2714
Bennett68C10
One more
Keith
66 Suburban
IG: bennett68c10
Old 01-19-2015, 09:32 PM   #2715
boostedc10
boostedc10's Avatar
Nice score Keith! Perfect motor for some boost
Brandon
Instagram: DRVFSTR
Current Project: Beatrix - 1967 SWB LQ4/78mm Turbo/4L80e/ on bags
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=634691
boostedc10 is offline   Reply With Quote
Old 01-19-2015, 09:38 PM   #2716
Bennett68C10
Thanks, maybe someday plans for now are to cam it, make it look nice and stuff it in the frame.
Keith
66 Suburban
IG: bennett68c10
Old 01-19-2015, 09:41 PM   #2717
trkfrk
trkfrk's Avatar
That motor is going to put your build over the top... What trans are you planning on using Keith..
Mark
Old 01-19-2015, 10:05 PM   #2718
boostedc10
boostedc10's Avatar
Hopefully a 4l80e Can't wait to catch up to you my friend!
Brandon
Instagram: DRVFSTR
Old 01-20-2015, 04:43 PM   #2719
slowcpe
slowcpe's Avatar
Sweet!!!
Ryan
1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840
1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628
1967/71 Blue SWB C10..SOLD
1977 SWB K10..my grandpa's.....never should have sold
slowcpe is offline   Reply With Quote
Old 01-20-2015, 11:38 PM   #2720
Bennett68C10
Thanks Mark, the bar has been set high with these Red trucks on the forum I just don't want to disappoint I'm not sure about the transmission yet. I want to run a 4L80E but im afraid with my dropmember it won't fit with the cab on. I already have a high hump but I know with the extreme dropmember the cab needs to be modified to fit, I'm just not sure about the Touring that I have. At this point in the build I really don't want to hack up the cab.
If I can fit the 4l80e then I'll definitely go with that, if not then it will probably get a built 4l70e and hope to god I don't grenade it. I'm not interested in cutting the cab up at this point to fit it. Your not going to have to try to hard to catch me, I have been spinning my wheels with bodywork for the past 2 know months.
Originally Posted by slowcpe View Post
Sweet!!!
Thanks, now just need to figure out what can I want to run
Keith
66 Suburban
IG: bennett68c10
Old 01-21-2015, 01:45 PM   #2721
mcbassin
Still Learning
mcbassin's Avatar
Way to go Keith! Awesome score. You will not be disappointed, I have no doubt about that.
Old 01-21-2015, 02:06 PM   #2722
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
Nice score on the 6.0L!!
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 01-21-2015, 07:44 PM   #2723
Bennett68C10
Thanks Mike, your right I don't think I'll be disappointed. I just hope I don't get overwhelmed with the electronics. Good news for me is I can lean on all you guys that have already done this swap before. I'm sure I'll have questions.
Thanks Buck, I'm pretty excited, I can't wait to tear into it and make it look how I want it too.
Keith
66 Suburban
IG: bennett68c10
Old 01-21-2015, 07:46 PM   #2724
Bennett68C10
Pic of the valve cover off, this was definitely a well taken care of motor. Very Clean
Keith
66 Suburban
IG: bennett68c10
Old 01-21-2015, 08:40 PM   #2725
raull
raull's Avatar
hey bud sorry ive been away a bid, great progress but I see u set your self back a little by going with ls , cant go wrong with that, im glad I did
check out my build thread
71 c/10 step side 5.3 twin turbo
http://67-72chevytrucks.com/vboard/s...d.php?t=485320
raul
raull is offline   Reply With Quote
bbc, dropmember, intro wheels, porterbuilt
