01-13-2015, 12:52 AM | #1 |
new to the forum
building a 60 gmc suburban, and have ready many of your useful advice. I am adding a 350 and have read the one very detailed installation instructions using the 67 to 72 motor mounts. I am wondering if anyone has any other options. attached are pictures of my project. |
01-13-2015, 01:28 AM | #2 | |
Re: new to the forum
01-13-2015, 01:44 AM | #3 |
60-66 Nut
Welcome to the forum
I am not aware of any other engine mounts that will fit correctly without spacers on top of the frame, aside from the factory '67-'72 small block mounts. That is unless you can find a set of original '60-'62 V8, auto trans engine mounts. Those are difficult to find and $$$$$ when you do.
01-13-2015, 02:24 AM | #4 |
Welcome! Cool project.
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! |
01-13-2015, 11:39 PM | #5 | |
01-14-2015, 12:02 AM | #6 |
Hi & welcome.
I don't know that I can answer your question here, but based on my own experience maybe I can give a couple of pointers. I bought a project, 64 body on a 61 chassis. All parts in boxes in the back. Learned the hard way that there is a big difference between the 60-62 and later chassis. Sadly parts availability for the early, torsion bar chassis is limited. The big difference is that the frame rails are wider apart on the earlier frame. On my rig a prior owner grabbed a bunch of parts off a later truck chassis including the entire front suspension with coils & five lug disc brakes. Also rear axles, etc. This was a good set up and easy to modify. Hope that all helps as I learned the hard way! Scottie Last edited by ogsRULE; 01-14-2015 at 12:50 PM. |
01-14-2015, 01:44 AM | #7 | ||
60-66 Nut
Why not just use the '67-'72 small block engine mounts and brackets? In the '60-'62's with a small block and a manual trans, the engine mount was a horseshoe style mount at the front. If the truck had an auto trans (powerglide) the engine had side mounts. All 283 blocks from '57 (?) to '67 had side mount provisions
The '60-'62's had the torsion bar front suspension and the X-member frame. 1963 was the first year of the better (IMO) frame with coil springs all around Quote:
01-14-2015, 03:10 AM | #8 |
i flip ur pic for better viewing
01-14-2015, 12:57 PM | #9 |
You're right, I had the year off by one and now edited. Although I'm not sure the better/worse discussion leads too far...BUT.....In terms of the better starting place given coil front end and parts availability I completely agree 63-66 is a much better call. I did read somewhere that the later chassis was less rigid. That's FWW! It might be a useful point for a 4x4. Scottie.
01-14-2015, 01:01 PM | #10 |
welcome to the party and liking the space in that garage =0)
dont want to hear excuses, i want to hear solution(s) |
01-15-2015, 12:18 AM | #11 |
yeah but I really want to keep the torsion bar suspension (because it is only those 3 years) gonna check out the 67 to 72 mounts and see where they leads me.
01-15-2015, 12:19 AM | #12 |
thanks long time coming
