Old 01-03-2015, 01:55 AM   #551
naphtali5725
naphtali5725's Avatar
Re: My new project 86 Silverado
Originally Posted by 77BBGMC View Post
Good luck with after market parts, I've bought a few interior pieces from a couple different distributors and so far haven't been happy with fit and finish (except for inner fenders). You would think somebody would make quality aftermarket parts for these pickups, especially for the common items. Watch ebay and craiglist for NOS and you can get lucky sometimes but for the most part prices have gone crazy...supply and demand.
I agree, and thanks for responding… since I am building a street machine, and not a show type truck, or back to original etc. I will not be needing any interior trim items, no headliner and what not(I have a custom aluminum dash) just odds and ends stuff… was looking for another option to LMC…
anyone else?
My build thread...
http://67-72chevytrucks.com/vboard/s...d.php?t=515829
Disabled Veteran
82nd Airborne Division
Operations: Desert Shield, Desert Storm, and Uphold Democracy
naphtali5725 is offline   Reply With Quote
Old 01-03-2015, 12:32 PM   #552
NONHOG
NONHOG's Avatar
Check out the vendor board here. Wes and Frank come to mind.
"I feel the need for speed!"... as soon as I am done with my nap.
NONHOG is offline   Reply With Quote
Old 01-03-2015, 01:24 PM   #553
naphtali5725
thanks!
My build thread...
Disabled Veteran
Old 01-10-2015, 12:33 AM   #554
naphtali5725
will be going Thursday to pick up my engine, will post pics then, been a long time, and i'm glad it's finally built and paid for LOL...
My build thread...
Disabled Veteran
Old 01-15-2015, 05:52 PM   #555
naphtali5725
picked up my engine today!!! will post pics tomorrow...
My build thread...
Disabled Veteran
Old 01-16-2015, 11:44 AM   #556
naphtali5725
here it is, nothing fancy, stock colors for 1976, some cheesy chrome was supplied by the builder, i'll leave it
it's what's inside that counts LOL
will have an Edelbrock RPM intake and headers, I know a guy on another board that has a 87 swb wilh the same setup as mine, and I forget what headers will fit, but I have the email…
Oldsmobile 455…
specs...
Block bored .030 over
Honed with torque plates
Decked .010
Mains align honed
Crank turned/polished .010/.010, straightened
Factory rods reworked, ARP bolts
Factory cast high compression pistons advertised as 10.25:1 - .010 in the hole
Hastings moly rings
Clevite main/rod bearings
Melling high volume oil pump/pickup/drive rod
Rotating assembly balanced with dampener and flex plate installed
Clevite cam bearings
Bullet hyd flat tappet cam - .512 lift 230/284 duration on both int/ex on a 110 LS
Matching valve springs 110lbs closed, 285lbs open
Cloyes true double roller timing set
J-heads reworked (bowl hog, not ported) milled .022, new 2.07 int and 1.68 exhaust valves
New lifters/pushrods/rocker arms
Stock 4 barrel intake
Modified 800cfm Quadrajet, 76 main jets - 48 primary rods - DB secondary rods
All Felpro gaskets
My build thread...
Disabled Veteran
Old 01-16-2015, 01:22 PM   #557
NONHOG
NONHOG's Avatar
Look at all that torque!
Old 01-16-2015, 07:26 PM   #558
naphtali5725
looks so tiny in the picture… but 460+ cubes makes for serious torque… should be a blast to drive
i have another cool Olds build going on now as well… from an Olds builder in Florida...
Olds 455… specs…
Block bored .025 over for a Pontiac Icon piston
Scat 7.00" H Beam rods
"N" crank
Balanced
ARP main studs
Align honed
Square decked
Bored and honed
Block dressed and relieved
Federal Mogul Main brgs
Clevite rod Brgs
Durabond Cam bearings
Mahle Moly Top ring set - file fit.
Cloyes Billet timing set.
waiting on reworked C-heads and a Performer Intake from an Olds builder in
Ohio… will decide on a Hyd roller cam soon...
My build thread...
Disabled Veteran
Old 01-25-2015, 10:24 AM   #559
naphtali5725
touched base with Jim Lehart, progress coming along on my 461 Pontiac... maybe 2 more months..
I should do a poll to see which one, the Olds or Pontiac gets installed...
My build thread...
Disabled Veteran
Old 01-25-2015, 12:52 PM   #560
NONHOG
NONHOG's Avatar
I'm biased, so I vote Olds! Also its been done several times. Not sure how well the Poncho fits? (mounts and exhaust?) Either way looks like fun!
Old 01-25-2015, 11:57 PM   #561
naphtali5725
i really need another project for one of these motors, but i just can't decide on what...
wish I had kept my 67 step side... maybe i need another one lol
My build thread...
Disabled Veteran
Old 02-05-2015, 08:02 AM   #562
naphtali5725
been cold here for days and days... waiting on motor mounts to come for my 455... using Olds 403 mounts from a 78 Trans Am so I can use the standard Chevy frame side mounts...
like these...
My build thread...
Disabled Veteran
Old 02-17-2015, 01:43 AM   #563
naphtali5725
got the motor mounts for my engine... have to go back to Florida, my Dad's recovering from some surgery... will install and hook it up as soon as i'm back mid March
Going to be buying my gauge kit in the next couple of weeks, it's about the only electrical left that i need to get, then i can start wiring the truck...
My build thread...
Disabled Veteran
Old 02-17-2015, 12:35 PM   #564
naphtali5725
the weather is not motivating me at all...
My build thread...
Disabled Veteran
Old 02-21-2015, 08:03 PM   #565
Hankster
Hankster's Avatar
Poor truck. I hate snow.
Current Build
89 s10 ecsb 2wd 4.3/700r4 50k OG Miles
Instagram- shaggin_s10
'86 Chevrolet C10 Custom Deluxe - Gen V 454 - 4l80e - welded 12 bolt
(Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=611611 ) SOLD
Hankster is offline   Reply With Quote
Old 02-21-2015, 11:36 PM   #566
jpnh
jpnh's Avatar
X2-
jpnh is offline   Reply With Quote
Old 02-24-2015, 11:29 AM   #567
naphtali5725
gonna get a lot of work done today... yeah right
got 6" of snow last night...
my 40 foot waterfall...
My build thread...
Disabled Veteran
Old 02-24-2015, 11:31 AM   #568
rs74
rs74's Avatar
I hear ya. -1 here right now.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 02-24-2015, 01:45 PM   #569
naphtali5725
got my engine side mounts today... from firebird central.com
My build thread...
Disabled Veteran
Old 02-26-2015, 05:56 PM   #570
Hankster
Hankster's Avatar
Sweet! Thanks for Serving btw!
Current Build
Old 02-26-2015, 06:06 PM   #571
naphtali5725
thanks, it was a privilege
My build thread...
Disabled Veteran
Old 02-26-2015, 06:13 PM   #572
Hankster
Hankster's Avatar
My dad was with the 75th Regiment and Airborne qualified.
Current Build
Old 02-26-2015, 06:19 PM   #573
naphtali5725
yeah the ranger regiment, all are paratroopers, all of us dumb grunts jumped together LOL
504th for me in bragg
tell him thanks for his service
My build thread...
Disabled Veteran
Old 03-02-2015, 06:49 PM   #574
naphtali5725
after checking over my engine, the builder did not know a few Oldsmobile specific things... in the left rear of the engine, there is a 29/32" plug for the oil galley, behind that plug is the actual oil galley threaded pipe plug, well for the Olds engines, that galley pipe plug is supposed to have a .040 hole in it to oil the distributor gear...
so i have to pop that 29/32 freeze plug out and replace the galley pipe plug with the right one with the .040 hole in it... i already have them to replace, but is a bummer... delays delays grrrrrr
My build thread...
Disabled Veteran
Old 03-04-2015, 03:25 PM   #575
Hankster
Hankster's Avatar
Thank you, sir! And atleast you have the parts already. lol
Current Build
