Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1967-1972 Chevrolet & GMC Pickups Parts Board > Blazer and Suburban Stuff
Old 01-13-2015, 08:41 PM   #1
DLTruck1973
1971 K20 Suburban parts F/S
Here are the K20 Suburban parts from our pick up thread. Please ask any questions you may have. I can take photos of any parts needed.
To avoid possible confusion, we ask that you try to respond in the thread(s) for parts listed with in the thread.
All prices are plus shipping.
Shipping via UPS, USPS, and freight truck.
Payment via Paypal, MO, and cards over phone.
PHOTO 1
Rear bumper brackets RH and LH...25.00 each
Lower gate hinges with bolts worn bushings...10.00 each rebuilt 45.00 pair
(2) Lower gate strikers mounts to body side for latches w/bolts and shims...12.50 SOLD
Lower gate latches...12.50 each
Upper gate supports (holds up hatch)...15.00 each
Lower gate straps...12.50 each with bolts
Tail light housing...10.00
Back up light housing...7.50
Tail light lens minor fade on top...15.00
Back up light lens...7.50
Gas cap minor ding...5.00
Ign cylinder, door cyl's., and hatch bottom/cyl....40.00 SOLD
PHOTO 2
Front door panels LH ruff, RH has tear metal looks ok...40.00 pair
Rear door panels both need re-glued to metal some small tears...45.00 pair
Rear compartment forward panel (left) very decent for age...25.00
Rear compartment panel, right needs edges re-glued. Has speaker hole. speaker hole cut out included... 25.00
Rear compartment RH filler at spare...20.00 SOLD
Arm rest for front doors (two) sun baked/faded...10.00 each
Sun visors great color has old school clip marks...10.00 each SOLD
Sill plate for rear door some rust on bottom side. Top would clean up for DQ...20.00
Roof bows...on hold SOLD
Stationary small glass with rubber...17.50 each
Window rear regulator RH very nice...35.00
Window rear regulator LH very nice...35.00
Primary dome light with pig tail. This is a Suburban only piece...7.00
(3) access covers for rear gate...5.00 each SOLD
(4) rubber plugs for barn doors hinges...20.00 SOLD
(25) hinge and gate hardware access plugs...20.00 SOLD
Chrome bezel trim for gate push button...25.00 SOLD
Mounting plate for lower gate push button...15.00
Latch for upper gate, mounts in lower gate...12.50
Fuel filler neck with hoses...35.00
Also in separate photo is additional rear compartment panels off a 1972. Card board on all is wavy.
PHOTO 3
Rear compartment panel (right) some split edges need re-glued...25.00
Rear compartment panel (left) rear few tears...30.00
Rear compartment panel, (left) forward minor cut...25.00
Thank you for the interest.
DLTruck1973 is offline   Reply With Quote
Old 01-13-2015, 09:16 PM   #2
Boe3
Re: 1971 K20 Suburban parts F/S
I would be interested in the following parts: photo 1 - (2) lower gate strikers with shims and bolts, (3) access covers for rear gate, (4) rubber plugs for barn door hinges, (25) hinge and gate hardware access plugs. Photo 2 - rear compartment rh filler at spare, (2) sun visors. Let me know total with shipping and if paypal works. Thanks, Rich.
Boe3 is offline   Reply With Quote
Old 01-13-2015, 09:21 PM   #3
green723dr
green723dr's Avatar
I will take (3) access covers for rear gate...5.00 each
shipped to 77510 if Boe3 passes
Thanks, Mickey
green723dr is offline   Reply With Quote
Old 01-13-2015, 10:30 PM   #4
DLTruck1973
Rich,
I will get you a total tomorrow. Can I get your zip code for a shipping quote?
Thank you for the interest,
Thomas
Old 01-13-2015, 10:32 PM   #5
DLTruck1973
Thanks, Mickey
Hi Mickey,
You are second in line for all of the above if Boe3 passes. I may have some more access plugs but will have to check.
Thomas
Old 01-13-2015, 10:38 PM   #6
green723dr
green723dr's Avatar
Thanks Thomas
Old 01-13-2015, 11:31 PM   #7
TBONE1964
Cluster King
TBONE1964's Avatar
Subscribed
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com
I am also a dealer for Counterpart for gauge cluster parts only.
Also see my facebook page, CG&C
TBONE1964 is offline   Reply With Quote
Old 01-14-2015, 06:22 AM   #8
Boe3
60641
Old 01-14-2015, 02:17 PM   #9
DLTruck1973
Everything totaled up with shipping is $133.50 paypal is fine. PM me for information and your address.
Let me know if interested and I will get you taken care of.
Thank you,
Thomas
Old 01-15-2015, 11:05 AM   #10
waylonbud
Would you by chance have a key for the ignition and door lock cylinders. If you do I would take them shipped to 37303. Thanks
waylonbud is offline   Reply With Quote
Old 01-15-2015, 01:00 PM   #11
DLTruck1973
I can help you with that. Ignition tumbler, door lock cylinders with matching key,
$37.50 shipped to your door. Let me know
Thank you,
Thomas
Old 01-15-2015, 01:50 PM   #12
waylonbud
Hi Thomas, it was getting close to the end of my break time so i was typing fast. Do you have a key for the set you have listed with ign. tumbler, door locks and the hatch cyl. Sorry for being confusing and repeatitive.
Thank you
Old 01-15-2015, 02:21 PM   #13
DLTruck1973
Thank you
No problem. That does change things a little and I will have to get back with you. Hold tight and I will make sure.
Thank you,
Thomas
Old 01-16-2015, 05:37 PM   #14
DLTruck1973
Thank you
OK,
I have everything for the Suburban, ign tumbler, doors (left and right) and rear hatch button.
$40.00 plus shipping of $5.25 for a total of $45.25
Let me know,
Thank you,
Thomas
Old 01-16-2015, 08:13 PM   #15
72MARIO
72MARIO's Avatar
Interested in the rear dome light. Does it go above the 2nd row seat ? How does it tie into the front overhead dome light ?
Mario
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 01-16-2015, 08:33 PM   #16
DLTruck1973
Mario
Hi Mario,
Yes the dome light does go above the second row seat. It has a separate harness that runs up the windshield pillar and then back overhead to the dome light. The rear dome light has a very short pigtail on it un like the pick up style dome lights.
Now the question is do I have the harness to hook the rear dome light up. I believe the answer is yes but I need to put my hands on it to be sure and what the condition is.
I may have to get back with you on Monday for that.
Thomas
Old 01-16-2015, 08:48 PM   #17
72MARIO
72MARIO's Avatar
Please let me know if you can track down all the parts for the second dome light. Thanks, Mario
2005 TAHOE DD
Old 01-16-2015, 08:56 PM   #18
87Skier
87Skier's Avatar
Any chance you have the mounting brackets for the rear seat? Thank you!
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205
1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears
1996 Chevy Suburban K1500 350/4L60E
87Skier is offline   Reply With Quote
Old 01-16-2015, 08:58 PM   #19
DLTruck1973
I will check on Monday for you.
Have a good weekend,
Thomas
Old 01-16-2015, 08:59 PM   #20
DLTruck1973
Thank you and have a good weekend,
Thomas
Old 01-17-2015, 02:51 PM   #21
waylonbud
I will take the Suburban ign., door, hatch button lock set and key. Please send payment info.
Thanks.
Old 01-17-2015, 03:02 PM   #22
DLTruck1973
Thanks.
PM on the way with payment information.
Thank you,
Thomas
Old 01-17-2015, 11:29 PM   #23
waylonbud
Paypal has been sent.
Thank you.
Old 01-17-2015, 11:32 PM   #24
DLTruck1973
Thank you.
Payment received. Thank you very much. Parts will ship out on Monday.
Thomas
Old 01-19-2015, 01:43 PM   #25
DLTruck1973
Sorry no seat brackets at this time.
Thomas
