Old 01-18-2015, 06:16 PM   #1
tjsblazer
tjsblazer's Avatar
Question Fuel tank strap, U Bolt dimensions ?
Guys, I'm looking for some help with measurements of the U bolt on the Lh side of the frame that the tank straps bolt to. Mine broke when I was taking it out. I planned on fabbing a new one but now I can't find it. Can someone please measure their's. I need to know:
1) What is the length between the U or center to center
2) What is the overall length of the U bolt arms
3) What is the length of the thread part or the arms
Thanks for help on this. Below is a couple of borrowed pics of the part I'm talking about.
Jeff.
'72 Blazer K5
"Camshaft opinions are like belly buttons; everyone has one and no two are alike"
My Blazer Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=626752
My Engine Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=637336
tjsblazer is offline   Reply With Quote
Old 01-18-2015, 07:22 PM   #2
CrewCab59
CrewCab59's Avatar
Re: Fuel tank strap, U Bolt dimensions ?
I just had mine out today , give me time for dinner and I will get the info for you.
Scott
1972 Custom Deluxe 20 4x4 burb
1971 GMC SWB CST 4x4
1972 GMC k20 4x4 (X- brush truck )
1971 Chevy CST Blazer 4x4
1971 Chevy C/10
1970 Cab Chassis C30 157"
1971 Cab Chassis Custom 30 Deluxe 157" 292/4spd ( Napco Replica )
1988 Chevy V30 4x4 wrecker challenger 4812
CrewCab59 is offline   Reply With Quote
Old 01-18-2015, 07:25 PM   #3
SeventyOne
Here's what I made. In the end I went with a stronger design. If one of these welds breaks the tank could fall out. instead I took 1/8" thick steel, 1" by ~8" and drilled 3/8" holes the correct distance apart and welded the bolt heads to the plate. this way if the welds break the bolt will still hold the straps in. Make sense?
This is from total distance across including threads
SeventyOne is offline   Reply With Quote
Old 01-18-2015, 08:10 PM   #4
CrewCab59
CrewCab59's Avatar
I already have my tank installed so this isnt 100% but should get you started
7 3/8" center to center
2 1/2" Threaded section
3 1/2" top of bar to bottom of threads.
Scott
1971 Chevy C/10
Old 01-18-2015, 09:18 PM   #5
tjsblazer
tjsblazer's Avatar
Thanks for the help. This is enough that I can get something fabbed up. Is the thread 3/8 " size?
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 01-19-2015, 12:53 PM   #6
SeventyOne
3/8" thread, yes. Post pics when it's done!
Old 01-20-2015, 07:29 PM   #7
1rippen6
Here are some more pictures
1rippen6 is offline   Reply With Quote
Old 01-20-2015, 07:30 PM   #8
1rippen6
I have two different u-bolts and both one leg is just slightly longer than the other
Old 01-24-2015, 05:59 PM   #9
tjsblazer
tjsblazer's Avatar
Interesting. Do you remember when installed which way it goes? Longer front or back?
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 01-24-2015, 06:02 PM   #10
1rippen6
No I don't but I really don't think it matters. It was probably just the process they used to bend the rod and not worried too much about the offset but that is just my thought.
Old 01-24-2015, 06:05 PM   #11
tjsblazer
tjsblazer's Avatar
Ok thanks. I just picked up some 3/8 steel rod today. Hopefully this week I'll have some time to bend it and cut the threads. I'll post a pic when it is all done but I just plan on making it look stock.
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 01-24-2015, 06:06 PM   #12
1rippen6
Ok just let me know if you need better dimensions or photos
Old 01-24-2015, 06:10 PM   #13
tjsblazer
tjsblazer's Avatar
Thanks but I think you covered it. The spread looks like 7.5" ctr to ctr. I measured the tank and 7.5 is also the ctr to ctr on the strap depressions.
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 04-08-2015, 12:37 AM   #14
tjsblazer
tjsblazer's Avatar
Finally got around to doing this. I got a piece of 3/8" cold rolled rod. Bent it as required and then cut the threads. As close to factory as I could get it. Just gave it a quick media blast to remove the steel oil so I can paint or powder it. Thanks again for everyone's help on this.
[IMG][/IMG]
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 04-08-2015, 06:36 AM   #15
1972 Jimmy
1972 Jimmy's Avatar
Wow! That looks really good! What did you use to bend the rod to get such a nice radius?
Eric
1972 Jimmy is offline   Reply With Quote
Old 08-11-2020, 10:49 PM   #16
72blazerblue
72blazerblue's Avatar
I know its a long shot, but does anyone on the board reproduce these?
1967 SWB C-10
1972 Blazer 4x4
2011 Silverado
72blazerblue is offline   Reply With Quote
Old 08-11-2020, 10:56 PM   #17
1rippen6
Not that I'm aware of but I may have one that has been repaired.
