Old 01-20-2015, 09:59 PM   #26
Re: old style locking hubs
Looks nice in body color. your hubs look to be in great condition. Selectro made other style hubs,too. and, here are a couple more Selectros sold under other names...like Dualmatic!
Old 01-20-2015, 11:46 PM   #27
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Old School Selectros...now owned by Special-K. I had to have OEM Spicers
Old 01-20-2015, 11:49 PM   #28
landy
I've got the same color and style of Selectros on my '72 Blazer.
landy is offline   Reply With Quote
Old 01-21-2015, 09:41 AM   #29
That truck warranted OEM bumper to bumper. Thanks for the opportunity to own them. Might even use them one day!
Let's not leave out the cream of the crop of the time...Warn Loc-O-Matics. I ran these on my first 4wd. I tore up a couple hubs before I realized Warn's instructions were incomplete. They instruct to manually lock for heavy loads and compression breaking, but should have included any serious off road driving. It made sense to me after the fact to lock-in any time I went 4 wheelin'. It's any situation where added stresses occur. I had large tires, then there was the deep thick mud. With big tires they were only good for a quick aid, like rear tires spinning when backing up a gravel driveway. Maybe snow covered roads,too. But over 32" tires were a new thing the hadn't planned on. They held up fine locked in. The OEM automatic hubs would have been great all around hubs if GM had made them this way. Basically, if you roached a hub it's because you were too lazy to get out and lock-in. But, you gained the convenience of automatic
Old 01-21-2015, 11:50 AM   #30
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
Im not convinced anything is better than the spicers yet. Has there ever been a spicer thats failed due to something other than someone putting pliers on the knob? Just because the selectos don,t use plastic doesnt automatically mean they.re better quality. Maybe they are, i havent reaearched them or have experience with them. Was the machining and metal hardness or contact area as good or better than the spicers? Since the strength of steel can vary from 36 ksi to 180ksi depending on alloy and heat treatment, im looking for more than just an appearance difference. If there are reports of spicers stripping out and selectros or others not, Im all ears.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 01-22-2015, 11:28 AM   #31
That's fine, think how you'd like. I'm only responsible for my opinion. I do know that Warn makes hubs with plastic dials or you can get the better ones in all metal. I'm sure whatever grade of steel they use in hubs is appropriate for the application. plastic was new to the auto industry in '69 and has come a long way since. Maybe the Spicers only break when you use pliers, but the metal ones don't. Sure, it's your own stupid fault for not properly maintaining your stuff, but why be punished for it? The fact is, when you need the hubs locked in you need your hubs locked in and nothing else matters at that moment. The fact is, people should maintain a lot of things on vehicles that most don't. I'm happy with everything about a stock truck, including the hubs. I
Here's one more picture I have on my computer:
Old 01-22-2015, 08:54 PM   #32
jeffahart
jeffahart's Avatar
Whats the use of arguing the strength of the original Spicers? If you were going to buy hubs today would you be able to get the spicers? If you had to buy hubs right now today then it looks like the Yukon hubs are the next best thing. And Yukon may even be better.
White K20
jeffahart is offline   Reply With Quote
Old 01-22-2015, 11:15 PM   #33
Vintage Windmills
Vintage 4x4s
Thats just it, if we can tease out strength differences here, it may guide us to spend more or less effort and money to find OEM vs vintage aftermarket versus the new stuff.
Old 01-22-2015, 11:36 PM   #34
ryanroo
ryanroo's Avatar
i have witnessed a stock spicer fail a few times on the d44s. shears the weld on the locking gear.
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 01-22-2015, 11:40 PM   #35
Tell us more about Yukons. I've never heard of them. I know Warn offers Premiums. I've never had a set off hubs I'd consider not good enough. When I kept tearing up those Loc-O-Matics I didn't want to spend another $150 +/- (in '78) I bought a $49 set of no names from JC Whitney and ran them till '82 when I got rid of the truck. I was running 37/14.50s, the truck had a built 440, and those were my hard wheelin' days. Those had plastic dials.
Old 01-23-2015, 12:00 AM   #36
j.kirn
Originally Posted by OrrieG View Post
My dad always ran these on his jeeps in the 50's and 60's, we used them hard and never had a hub failure. He was buying military surplus so it may have been what the govt. spec'd. I was not ambitious enough to search and see if they are still made or were even available for GM hubs. You flipped the levers, turned them 180 degrees and flipped them back into the slot to engage and disengage.
I have a set of these they are tough
j.kirn is offline   Reply With Quote
Old 01-23-2015, 12:04 AM   #37
jeffahart
jeffahart's Avatar
Yukon hubs are all steel with chromoly internals. I have been looking at them to replace my standard warns. I never owned before but was going to put on the 44 to replace my warn premiums which looked real bad. But now still want some. But I only note what I'm saying based on research. But I like what I've read and what I see.
On a quick note. I was the one that fried the passenger side spicer on my truck back in 89(I think, maybe 90). I fried it with the spindle by overheating. That's when I sold my truck, undrivable to my friend. He put on the warrens. Never been a fan of warrens either.
White K20
Old 01-23-2015, 12:08 AM   #38
jeffahart
jeffahart's Avatar
Here's a Yukon link
http://www.yukongear.com/ProductDeta...x?ProdID=12616
White K20
Old 01-23-2015, 12:12 AM   #39
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Here's a Warn on my 72 GMC...Lock-O-Matic?
EDIT: Oops - I see I left them locked
Old 01-23-2015, 12:36 AM   #40
landy
Those aren't Lock-o-Matics, but nice quality old Warn hubs.
Old 01-23-2015, 12:55 AM   #41
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Thanks. The dial is a brass finish and I can see remnants of red paint...yet to be replaced by OEM Spicers
Old 01-23-2015, 01:20 AM   #42
landy
I've got the same old style Warns with brass dial on my '71 GMC K1500.
Old 01-23-2015, 09:43 AM   #43
They would say Loc-O-Matic if they were. Just to be clear, I'm posting with early K/20 hubs in mind, but I guess this is all years. that said, I was going to mention Superwinches as new replacements, but they don't list the early hubs. They are nice hubs
Old 01-28-2015, 06:39 PM   #44
bhc41051
bhc41051's Avatar
Another re-brand of the Selectros
bhc41051 is offline   Reply With Quote
Old 01-29-2015, 09:20 AM   #45
Cool! SAE for short...clever!
Old 02-05-2015, 09:20 AM   #46
jaros44sr
jaros44sr's Avatar
Thanks Tim on the tip of using oil outside of the bearing, did nt know that
Just replaced my warn locking hubs with OEM Spicer last week. Along the way i learned a few things, like the 6 bolts around the locking hub should be torqued to 35 IN./LBS.
20150117_102129
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 02-05-2015, 09:37 AM   #47
Beautiful!
Old 02-05-2015, 12:25 PM   #48
jaros44sr
jaros44sr's Avatar
Beautiful!
Thanks Tim.....bought them off the board a couple years ago, blue are outta my reach, but the yellow are still obtainable.
I had Warn on, but found out all the guts are differant, so i had to go back to the parts forum
I like the collection you ve acquired, someday, i might go down that road.....did nt realize there were that many
SAFETY FIRST
AS usual, off topic
Jim
Old 02-07-2015, 12:57 PM   #49
I seem to have lost my camera right after Christmas, or I would take my blue N.O.S. K/20 knob & keepers out of their boxes and get a picture for this thread
Old 02-07-2015, 12:59 PM   #50
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Tease!!
