Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 01-26-2015, 05:26 PM   #1
hotrod 80
mini truck racer
hotrod 80's Avatar
Wide band or data logger
Looking into one of these . Maybe a LM-2 from innovate ? Any input or experiences ?
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 01-26-2015, 05:31 PM   #2
Super73
Super73's Avatar
Re: Wide band or data logger
I have thrown two lm-2's in the trash. I have been using AEM since with out complaints.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 01-26-2015, 06:20 PM   #3
hotrod 80
mini truck racer
hotrod 80's Avatar
Are these just gauges or are they loggers . I also looked at the FAST analog style gauge . Mainly needing to monitor A/F ratios coming up .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 01-26-2015, 06:29 PM   #4
Wasted Income
Boosted Member
Wasted Income's Avatar
I'm with Super72...Innovate stuff is GARBAGE.
I also had good luck with AEM, and with the NTK/Holley EFI combo I'm running now.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2016 Ford Explorer Sport - Twin Turbskis
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 01-26-2015, 07:13 PM   #5
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Have a couple of Innovates as well, 1 only keeps cal if the moon is just right.
The higher end not-really-portable one works well, but its cumbersome as HELL to use. (its the size of a car phone with like 5 cables coming out of it).
Had an AEM onboard wideband on my SRT4 worked great, and I have an Autometer onboard my truck right now.
With HP tuners and my existing wideband, I can log to a laptop or just use the gauge as normal.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 01-26-2015, 08:58 PM   #6
71Dragtruck
71Dragtruck's Avatar
I run the FAST dual O2 setup with record and playback capabilities, have never had a problem with it.
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
Old 01-27-2015, 05:38 PM   #7
Super73
Super73's Avatar
I have a modotek 2stage n20 controller (made by Daytona sensors) it has the ability to datalog things like afr, rpm, speed, week control a shift light etc. Daytona also makes wideband equipment.
Old 01-27-2015, 07:53 PM   #8
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Hehe if you got the money, why not? Full RacePak
too rich for my blood
Old 01-27-2015, 09:51 PM   #9
hotrod 80
mini truck racer
hotrod 80's Avatar
I honestly thought about the racepack stuff , But my truck has the stock harness in it . With the dash your talking about a total rewire . Maybe next winter . I have a lonely Wally and need an Ironman next to it LOL .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 01-28-2015, 01:22 AM   #10
Marv D
Registered Truck Offender
Marv D's Avatar
I'm getting ready to pull all the electronics from the truck,, including a Edelbrock Quickdata with 2 Innovate wideband O2's out of the truck.
You want to datalog,,, I can fix you up.
Right now I'm logging
Engine RPM
coolant temp
oil temp
EGT in #1 and #2
O2 on each bank
Driveshaft RPM
oil pressure
fuel pressure
I disabled the G meters in favor of monitoring Transbrake on/of (to key the data to a time slip)
and throttle stop on/of
As I remember there is 16 channels. If your really interested email; me and I'll send all the info
BUT,, be aware... you HAVE TO HAVE a old craptop with a 9Pin comm port. I have not found one of the usb-9pin adapters 'yet' that works. Seems the MSD and Quickdata has some security crap that kills the USB adapters
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 01-28-2015, 02:20 AM   #11
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
You can run a version of the RacePak dash display off of just an OBD link. The benefit of it being modular is you can start small.
Old 01-28-2015, 01:16 PM   #12
hotrod 80
mini truck racer
hotrod 80's Avatar
Engine RPM
coolant temp
oil temp
EGT in #1 and #2
O2 on each bank
Driveshaft RPM
oil pressure
fuel pressure
No , i dont really need to data log . Dont need the hassles or distractions .
Thinking that a Dyno session is the route for me . I was just wanting to log for the changes and then pull it all off .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 02-04-2015, 09:01 AM   #13
urmyboyblue
The AEM failsafe wideband is what I have and it data logs.
urmyboyblue is offline   Reply With Quote
Old 02-04-2015, 10:59 AM   #14
hotrod 80
mini truck racer
hotrod 80's Avatar
Actually this seems to be a good one . It keeps coming up .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
