Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 01-17-2015, 11:57 PM   #151
SeventyOne
Re: The "In over my head" build thread
Been keeping busy on some small tasks with the end goal of undercoating and getting the body back on the frame by Spring.
So with that in mind I started finishing things off on the Chassis that is essentially 95% done. I had my stock tank boiled out and lined because I was not happy at all with poly plastic tank - it's for sale if anyone is interested
Also no one reproduces the rubber isolators that go under the tank straps and the tank flange so I've got some 1/8" sheet rubber coming and I will copy the original rubbers.
Then I need to get the fuel lines finished off. Hard lines are in, just the rubber hose connections need to be put on.
Then I turned back to getting the body ready for undercoating. I cut out the all the rust spots on the bed floor and will be patching in scavenged '68 long bed patches soon.
Pics of the holes I cut in the floor - 5 spots in total were cut out. This is my first attempt at rust repair but I'm excited to learn. What's the worst that can happen?
Rear tail gate area - both sides are like this.
Crossmember was toast also but I will patch that also.
3 of the 4 wheel tub corners look like this, but this one was the worst one.
I'll prep the patches soon and get these checked off my list.
I am also stealing this "punch list" idea from the infamous "Low Buck Junkyard Build" - So here goes:
TUB WORK
  • Repair wheel tub / bed floor rust
  • Repair drilled hole in firewall by PO
  • Cut larger firewall fuse panel hole for AAW kit
  • Dress body bolt areas (Left over tack welds)
  • Clean & Prep underside of Tub
  • Spray some kind of rust converter in areas not accessible to be prep'd and primed
  • Spray Epoxy Primer/Undercoat/Bedline
CHASSIS WORK
  • Cut and install tank rubber isolators
  • Hook up all gas lines
  • Install Transmission cooler lines
  • Install new starter bolts
  • Torque engine mount bolts
  • Install front axle breather
  • Install Thermostat
  • Install Radiator hose clamps
  • Install BTO TV cable setup
SeventyOne is offline   Reply With Quote
Old 01-20-2015, 01:58 AM   #152
72K5CSTDarkOlive
72K5CSTDarkOlive's Avatar
Thanks for your help today.. I'm pretty sure I'm going to buy a welder now even though I'm not quite sure how much I'll actually use it
Love the title of your build thread.. I believe I'm right there with you
My Build Thread 72 K5 http://67-72chevytrucks.com/vboard/s...d.php?t=628612
Build version 2.0: 72 K5
6.0 LQ9, 4L80e, NP205
http://67-72chevytrucks.com/vboard/s...d.php?t=793192
1972 CST K5 Blazer Dark Olive
72K5CSTDarkOlive is offline   Reply With Quote
Old 01-30-2015, 09:10 PM   #153
SeventyOne
Will hopefully get more time tomorrow to work on the K5.
Last few weekends I got a bit further on the bed patching. I also re-installed my original gas tank after the radiator shop was done with it. I made a set of 1/8" rubber isolators for the tank flange and straps using the originals as templates. Turned out really nice I think.
Found starter bolts that were the correct 4 5/16" length for my starter, got radiator hoses and clamps installed, the BTO TV Made EZ kit installed, transmission cooler lines are almost in...lots more to do though.
Here's an updated punch list:
TUB WORK
  • Patch PO drilled hole in firewall
  • Cut firewall fuse panel hole for AAW kit
  • Oven cleaner underside of Tub
  • Pressure wash tub
  • Prep underside bare metal
  • Paint/Undercoat/bedline
CHASSIS WORK
  • Finish install of transmission cooler lines
  • Install Thermostat (I read I should drill small holes)
  • Cut down and Install power steering return line hose
  • Test starter engagement and shim as needed and torque bolts
  • Intall plug wire loom and cut down plug wires for cleaner look
  • Modify old distributor into oil priming tool
  • Modify Holley throttle return bracket to fit on Edelbrock Carb
  • Clean up and paint orig. distributor hold down
  • Install distributor stud and hold down
  • Install oil dipstick
  • Install transmission dipstick
  • Install PVC valve and hose to carb
Old 02-03-2015, 01:57 AM   #154
SeventyOne
Did a little work saturday on the plug wiring. Got these brackets from R&S. I think they'll work just fine.
Also been doing a bunch of research on SBC timing and decided to change out the springs, vacuum canister, and vacuum limit plate on my GM HEI distributor. Not much to look at it but it should help me get somewhere close to 14 deg. initial timing, 20 mechanical advance all in at 3200 rpm, then 12 degrees of vacuum advance. Then I can adjust from there.
That's it for now. Will try to get the plug wires shortened soon since some are way too long for a clean look. Then off to all other little tasks left for the engine.
Old 08-07-2017, 12:02 PM   #155
SeventyOne
8.7.17 - Turning the page
Hey everyone! After a long hiatus and a big life change I'm happy to say i'm moving forward with the K5 build.
This was my view on Saturday as the body was picked up and taken to be worked on. Same shop that Mike (@72K5CSTDarkOlive) used in his build.
I'll be sure and update with pics and progress along the way.
Stay tuned!
Old 08-08-2017, 08:32 AM   #156
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
That rotisserie looks familiar!
Tom Vogel is offline   Reply With Quote
Old 01-21-2018, 05:47 PM   #157
SeventyOne
Just a little update showing some rust repair:
At least the tailgate was nice
Underside is now lined and they're prepping to paint the firewall and jams before mounting back on the frame!
Old 01-21-2018, 07:19 PM   #158
72K5CSTDarkOlive
That shop looks awfully familiar
Old 01-22-2018, 05:37 PM   #159
SeventyOne
Yeah man they pumped out this killer dark olive K5 recently. I'm just riding the wake.
Old 01-24-2018, 07:55 PM   #160
Harold Holbrook
Thanks, For the pictures. I need all the help I could get.
Harold Holbrook is offline   Reply With Quote
Old 01-26-2018, 07:55 PM   #161
SeventyOne
1/26/18
I'm in genuine awe. Even though I've thought about this moment for 8+ years I can't believe it's happened, and I can't believe how close to the finish line I am.
Old 01-26-2018, 11:29 PM   #162
Spf79
Spf79's Avatar
Awesome! The color looks great!
I'm so envious!!!
Full top blazer or bust....
Spf79 is offline   Reply With Quote
Old 01-30-2018, 09:02 PM   #163
SeventyOne
1/30/2018 - A long time coming
I had to go back and look to the very first post I made in this thread. 2/4/2010 me and a small army took the body off the frame.
It took nearly 8 years - but holy crap does THIS make me excited!
Old 01-31-2018, 08:07 AM   #164
Lieferson
Lieferson's Avatar
Damn that looks good!!!
1970 1/2 ton 4x4 4spd Suburban
1972 K10 350/700R/205/ Sniper EFI Daily Driver Sold
1971 K5 on 35s Traded
1972 K5 3/4 ton PROJECT Sold
Lieferson is offline   Reply With Quote
Old 05-30-2018, 04:31 PM   #165
SeventyOne
Took a little longer than expected but...here she is!
Old 05-30-2018, 04:38 PM   #166
raggedjim
raggedjim's Avatar
That's gotta be a great feeling!
Nice work, Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
raggedjim is offline   Reply With Quote
Old 05-30-2018, 07:23 PM   #167
swamp rat
swamp rat's Avatar
Sweet!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 05-30-2018, 07:44 PM   #168
YoungPup1977
Nice truck, I have three blazers 2 4x4's and one 2wd....the 2wd is going to be painted red and white like a c10....love the red.... enjoy !!!!!!
YoungPup1977 is offline   Reply With Quote
Old 05-30-2018, 09:24 PM   #169
simicrintz
Very nice-congrats!!!
-Bruce
1971 K5 Blazer 4WD
simicrintz is offline   Reply With Quote
Old 05-30-2018, 10:56 PM   #170
Nestevec
Nestevec's Avatar
Wow
Nestevec is offline   Reply With Quote
Old 06-01-2018, 07:58 AM   #171
lks dcvn
lks dcvn's Avatar
looks great! 8 years to finish is way better than not finishing at all... Congrats.
lks dcvn is offline   Reply With Quote
Old 07-26-2018, 01:20 PM   #172
SeventyOne
Can a mod please move this to the builds section?
Old 07-29-2018, 08:59 PM   #173
jav418
Junior Member
I'd love to get the contact info of the shop in the bay area...Looks amazing
jav418 is offline   Reply With Quote
Old 07-29-2018, 09:18 PM   #174
SeventyOne
Talk to Manuel at BFS
https://www.bodyandframespecialists.com/
They also did Mike's dark olive K5 that looks flawless.
Old 07-29-2018, 10:06 PM   #175
SeventyOne
can't argue with their quality
