Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 02-01-2015, 10:16 PM   #1
gmachinz
detailed serpentine conversion kits F/S!
Okay fellas and gals-I am in the process of assembling 3 serpentine kits-I can supply them with or without accessories. I have 140A brackets options too as we'll as HD 4ga charging system kits to go with it. Here is a standard serpentine kit of mine installed on a friends 69 Camaro to give you an idea of how they look installed. If interested, PM me. Looking at $275 for pulleys, braces and brackets w/all hardware. I'll also supply accessories but it depends on your preference. Everything is blasted, etch primed and painted then cleared. My kits offer a very striking look while being a stock setup with no exotic parts to track down.
gmachinz is offline   Reply With Quote
Old 02-02-2015, 12:38 AM   #2
UKNOWME
UKNOWME's Avatar
Re: detailed serpentine conversion kits F/S!
Is that shipped? Do you include the part numbers for the accessories?
2018 Audi S5- wife's ride
1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511
1981 Chevy Silverado- in pieces
1964 Chevy c10
2017 Jeep Wrangler JKU
UKNOWME is offline   Reply With Quote
Old 02-02-2015, 02:09 AM   #3
gmachinz
Yes, $275 shipped for the hardware-this includes:
LH and RH brackets (for use with 105A alternator)
Support braces
Tensioner (new)
Water pump pulley
Power steering pulley
Crank pulley
All the correct hardware
Idler pulley (new)
Now, I can include with each kit the part numbers you'll need for the accessories-any parts store can cross reference for you. For $75 upgrade, you can swap the standard LH alternator bracket for a 140A HO alternator bracket while they last and/or I will include an adapter bracket kit (I manufacture these myself) that allows you to bolt on a 140A alternator on a stock serpentine bracket. The 140A upgrade requires a different thermostat housing and upper radiator hose which I would supply with that upgrade.
So, to summarize, $275 shipped to the lower 48 States gets everything listed above-$350 gets everything listed BUT you upgrade to a 140A alternator bracket system to run a HO alternator. I've done my homework and I can include part numbers for you to source for the kit you choose.
Old 02-02-2015, 02:15 AM   #4
gmachinz
The pics I posted show the optional (and very scarce!) 140A brackets-in the RH pic you see a standard serpentine bracket outfitted with my 140A bracket kit. If you want a HD 4ga charging system kit for use with either setup (highly suggested for the 140A kits) you'll want to PM me with details on your requirements since everybody may require a harness kit that's a bit different from another person. If anybody has ordered harnesses from me or have been following my posts, you'll know I build high quality kits with a bit of overkill in mind so whatever your needs are I've got a solution for them!
Old 02-02-2015, 11:33 PM   #5
jmedero
jmedero's Avatar
Any BBC kits?
68 BB burb build thread Scott's super slam front/rear
http://67-72chevytrucks.com/vboard/s...d.php?t=378084
jmedero is offline   Reply With Quote
Old 02-03-2015, 11:09 AM   #6
gmachinz
Not at this time-theyre very hard to keep on hand and tuff to even source.
