Old 02-01-2015, 02:33 AM   #1
Greasey Harley
Greasey Harley's Avatar
Drum brake drop spindles - Disk conversion?
One of my 68 c10's has Drum brakes and 2" drop spindles.
Is there a way to convert to 6 lug disk brakes using the drum spindles?
Greasey Harley is offline   Reply With Quote
Old 02-01-2015, 09:47 AM   #2
Mike C
Mike C's Avatar
Re: Drum brake drop spindles - Disk conversion?
No one makes a drum drop spindle to my knowledge. Pics of this setup please.
I think Speedway motors has a setup that uses the drum spindles but smaller passenger car brakes and the 4 3/4" bolt pattern.
The way to do this correctly is to replace the spindles and use truck brake parts. And yes, you can keep the 6 lug pattern if you want. I just converted my truck to 5 because the wheel choices are so much better. For me it was worth the trouble and expense.
Early Classic Enterprises has 6 lug disc conversion kits as well as 5. Good company to work with that makes good parts.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 02-01-2015, 04:45 PM   #3
Greasey Harley
Originally Posted by Mike C View Post
No one makes a drum drop spindle to my knowledge. Pics of this setup please. .....
Yeah, I guess, I could post a pic. Somebody does (or did) make them.
I would like to find a way to use them, as I already own them.
Old 02-01-2015, 04:46 PM   #4
mgchevyparts
mgchevyparts's Avatar
No such animal
1957 CHEVY 1/2 TON SHORT BED
1940 FORD 1/2 TON SHORT BED
mgchevyparts is offline   Reply With Quote
Old 02-01-2015, 04:58 PM   #5
Greasey Harley
Originally Posted by mgchevyparts View Post
No such animal
Beg to differ, amigo.
People have been customizing these trucks since 1967, You really think, nobody ever made drop spindles for drum brakes?
Well, somebody did.
I'll post some pics.
Still wondering if I can use them for something.
Old 02-01-2015, 07:36 PM   #6
Mike C
Mike C's Avatar
I've been around these trucks a long time and haven't seen one. Please post pics. I've seen some home-built spindles (cut and welded) but no production ones.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 02-01-2015, 09:04 PM   #7
dirtyjim
dirtyjim's Avatar
actually scarebird makes a kit that adapts the 88 up light duty 3/4 ton 6 lug rotors and calipers to the stock drum spindle. the kit sells for around $200 not including the rotors, calipers and hoses. I looked into it before I bought cpp drop spindles and 6 lug rotors
1967 C10 lwb two tone, 305 & rat fink style floor shifted 700r4, 20" steelies
2004 2500HD utility bed aka Brutus
dirtyjim is offline   Reply With Quote
Old 02-02-2015, 08:32 PM   #8
Greasey Harley
Thanks, I'll look into that
Old 02-02-2015, 08:39 PM   #9
Greasey Harley
I know these "don't exist" ...but, here they are.
Old 02-02-2015, 09:06 PM   #10
Mike C
Mike C's Avatar
Do you have a clearer closeup shot? I've seen some before, but they were all cut and welded and I can't see any details in that one.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 02-02-2015, 09:22 PM   #11
Greasey Harley
these were the best pics I could get. I didn't feel like laying in the mud. I assure you, these are manufactured, not hacked and welded.
Maybe, they were made in the 70's or 80's?, I don't know.
But THEY DO EXIST
Maybe, since they're [apparently] the only pair in existence, I'll donate them to the Smithsonian.
Old 02-02-2015, 10:18 PM   #12
low&slow
Greasy Harley - great to see another Idaho member. As for the spindles, you can donate them to me lol.
low&slow is offline   Reply With Quote
Old 02-02-2015, 11:41 PM   #13
mgchevyparts
Interesting. We do need a clear picture. If they're not welded but cast one piece some small shop must have made a small amount. No one has ever made reference to those that I'm aware of. And they don't exist in any one's current production or availability. You may have one of a very, very few ever made.
As far as your 6 lug desire, you should be able to bolt up a bracket kit that fits drum spindles, or buy the readily available drop spindles and use the special made 6 lug rotors instead of the 5 lug version.
If you can post a clear picture of those. The drop is the distance from where the upper anchor bolt should be to where it's located now, looks like it might be closer to 3"?
