Old 01-28-2015, 11:33 PM   #1
marvgarr68
marvgarr68's Avatar
77 gmc c35 dually 4-53t detroit
New thread for my new project. The truck is a 77 crew cab c35 gmc dually camper special 10,000 gvw. It has a 79 brazillian 4-53t detroit diesel 4 valve swapped in. It has a NP 540 main transmission and a 5831 3 spd spicer aux trans. It also has a dana 70hd rear end, hydraboost brakes also. I will post pics of what is done so far. It was propane injected but the tank was braking the bed (120 gal tank) I have since removed the injection. For those of you that have seen my other build this is total different nothing is painted or show quality. This is a factory conversion back in 87 and I'm keeping the same wear it has on it. That said it will not be thrown together just weathered.
1976 k20, 350 built, 44/14 axles
1968 c10 6.5 turbo diesel,t5 trans
1977 gmc c3500 dually, crew, 4-53t, 5&3 trans
http://67-72chevytrucks.com/vboard/s...d.php?t=591188
marvgarr68 is offline   Reply With Quote
Old 01-29-2015, 01:56 AM   #2
jbclassix
Junk Yartist
jbclassix's Avatar
Re: 77 gmc c35 dually 4-53t detroit
Where! Where! Where! I love 2 stroke Driptroits!
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 01-29-2015, 02:12 PM   #3
marvgarr68
marvgarr68's Avatar
Coming soon.
Old 01-29-2015, 04:41 PM   #4
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Sounds like a cool project. Someday I want to put an inline 6-71 in something. A long while ago, I put an 8v-92 with a 10 speed in a military truck chassis, and stuck an 86 K30 crew cab drw body on it. That was a big mean truck.
Ryan
1969 Chevy milk truck
Old 02-02-2015, 10:23 PM   #5
marvgarr68
marvgarr68's Avatar
Here are a few teaser pics. My internet has been down for the last 3 days so haven't been able to post pics.
Old 02-04-2015, 01:38 AM   #6
mosesburb
I had a V-8
mosesburb's Avatar
I like this. A lot.
1972 K20 Suburban, 5.9L Cummins, Banks Power Pack, NV4500HD, NP205, H.A.D., D60/14FF ARB Link To Build: HERE.
mosesburb is offline   Reply With Quote
Old 02-04-2015, 02:34 AM   #7
jbclassix
Junk Yartist
jbclassix's Avatar
Wow this is a really well optioned truck too! Looking forward to more on this! I worked on a 6V73 today. Brought me back to the old days. I'd love to run across an old 4-53. I'd love it more if it was a turbo like this one too!
-Jeremy
Rebuilding an NP205
Old 02-05-2015, 12:21 AM   #8
marvgarr68
marvgarr68's Avatar
You are correct lots of options. It has functioning AC and had cruise control but I removed it. It had the Bendix vacuum pump I removed it also I will use an electric one for the hvac controls. It had the biggest muffler on it and a noise reduction air cleaner also. I have replumbed the fuel system the right way. I removed all the fuel tanks except the drivers tank. I modified a bbc fan shroud to shield the fan and am putting in a bbc radiator. It had a small rad rigged in with c channel. I raised the aux trans as far up as it can go it was 3 inches from the ground when I got it. Later I will make a new rear cross member for it but for now I just used square tubing. Right now I am fixing all the cut up wiring and removing what does not need to be there. I think so far I have shed about 1800 lbs off it. The propane injection tank was 80% full and 125 gal that alone is a lot of weight. I will get some more pics tomorrow.
Old 02-05-2015, 12:25 AM   #9
marvgarr68
marvgarr68's Avatar
O yea this is about the best Detroit I have seen so far and I have been around them a long time. It doesn't leak, starts right up, and has the highest oil pressure I have ever seen one have.
Old 02-05-2015, 05:32 PM   #10
Dieselwrencher
You can't beat that at all!
Ryan
Old 02-09-2015, 10:08 PM   #11
marvgarr68
marvgarr68's Avatar
Here are some more pics just about done. I just have to finish the exhaust and a couple little items.
Old 02-09-2015, 10:10 PM   #12
marvgarr68
marvgarr68's Avatar
More pics.
Old 02-09-2015, 10:11 PM   #13
Dieselwrencher
It looks nice in there. It looks like you're having some nice sunny weather there too?
Ryan
Old 02-09-2015, 10:39 PM   #14
jbclassix
Junk Yartist
jbclassix's Avatar
That aux box is down there isn't it!
-Jeremy
Rebuilding an NP205
Old 02-09-2015, 10:46 PM   #15
marvgarr68
marvgarr68's Avatar
Thanks. Yes it has warmed up makes it nice to get out and do some work.
Old 02-09-2015, 10:51 PM   #16
marvgarr68
marvgarr68's Avatar
It hangs a little low it was worse it was just 3in from the ground. I have it as high as it will go. I will make a new rear cross member later. It is even with the oil pan so should be ok. Not going to be rock crawling.
Old 02-10-2015, 12:48 AM   #17
mosesburb
I had a V-8
mosesburb's Avatar
The more I see, the more I like it. You must post a video once it runs.
Old 02-10-2015, 09:02 PM   #18
marvgarr68
marvgarr68's Avatar
I am going to post a video once I get some tires.
Old 02-11-2015, 09:50 PM   #19
1972RedNeck
1972RedNeck's Avatar
Subscribed
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 03-10-2015, 10:06 PM   #20
marvgarr68
marvgarr68's Avatar
Here are some more pics I have been driving it daily runs great.
Old 03-10-2015, 10:08 PM   #21
marvgarr68
marvgarr68's Avatar
Some more.
Old 03-10-2015, 11:31 PM   #22
Dieselwrencher
Very nice! I bet you get some looks driving it around town.
Ryan
Old 03-11-2015, 12:13 AM   #23
jbclassix
Junk Yartist
jbclassix's Avatar
Curious to know what kind of mileage you're getting out of 212 cubic inches of 2 stroke diesel. I know the DD's weren't really known for being fuel friendly.
-Jeremy
Rebuilding an NP205
Old 03-11-2015, 09:44 PM   #24
marvgarr68
marvgarr68's Avatar
Lots of looks when its up high in the rpm. I was getting about 17 mpg but I found a fuel leak so that's fixed. I drive 30 miles a day I filled up on sun and I still have a full tank. Its a 15 gal tank I am guessing 20's. The rpms are at 1900 at 65.
Old 03-12-2015, 08:07 AM   #25
burnin oil
I love that aux box. They always are down low. When you moved it up it didn't mess the driveline angle up to much did it? Not a lot of guys even know what they are anymore. I have a 6x4 in my Dodge 5500. People always look at it weird with the 2 levers sticking up. Anymore most people get lost seeing 3 pedals.
burnin oil is offline   Reply With Quote
