Old 01-15-2015, 08:39 PM   #26
green72s
green72s's Avatar
Re: "Brass Monkey".....Installing 4/6" ECE Drop Kit
Super nice looking truck! I'll be doing a 2.5/4" ECE drop on mine, with similar size wheels and tires. It'll be interesting to compare their stance when they're done.
green72s is offline   Reply With Quote
Old 01-15-2015, 10:10 PM   #27
mammothhunter
mammothhunter's Avatar
BEAUTIFUL TRUCK! I plan to do the same drop kit on my truck in the future as well.
Looking forward to seeing the final results on yours, good luck.
Current:
1970 C-10 350 long bed "The Mammoth"
1957 Belair 2dr HT, 283, Muncie M-21
Past:1931 Ford Model A PU, 1928 Ford Model A Business Coupe, 1949 Willys-Overland PU, 1953 Willys PU
mammothhunter is offline   Reply With Quote
Old 01-15-2015, 10:37 PM   #28
TexasLS1
TexasLS1's Avatar
I'm not sure about the springs, I didn't think it would matter but I'm an amateur. I have the evil competitor's springs to install, but can't see a difference in direction. Mine are marked CPP on the lower coil tho so I plan to install with the letters right-side-up.
Hopefully someone will chime in to confirm so you can keep moving forward....
TexasLS1 is offline   Reply With Quote
Old 01-15-2015, 11:08 PM   #29
Hart_Rod
Hart_Rod's Avatar
It doesn't matter about the springs. Just put them both the same way.
Hart_Rod is offline   Reply With Quote
Old 01-16-2015, 08:45 AM   #30
Coursey
Coursey's Avatar
Thanks.
I am painting the retainers today at work and getting new bolts. Hopefully get them in tonight.
Now if my back ordered lower spring mounts would show up then I can finish up the rear.
Coursey is offline   Reply With Quote
Old 01-16-2015, 09:07 AM   #31
Hart_Rod
Hart_Rod's Avatar
Originally Posted by Coursey View Post
Thanks.
I can't remember who, but someone makes some billet spring retainers for our trucks that were pretty cool.
EDIT: Found them, http://67-72chevytrucks.com/vboard/s...ring+retainers
Old 02-01-2015, 02:02 PM   #32
Coursey
Coursey's Avatar
Which way is up on the sway bar?
Old 02-01-2015, 02:23 PM   #33
Mike C
Mike C's Avatar
Like the bottom pic is how mine is.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 02-01-2015, 03:08 PM   #34
OregonNed
OregonNed's Avatar
I'm just subscribing to this thread so I don't get fined (and it is totally awesome!)
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 02-01-2015, 04:42 PM   #35
jocko
jocko's Avatar
Great thread and good pics - thanks for sharing your process. Wow - originally an olive interior - can't imagine, but proves the original buyer could get whatever they wanted in those days. Very cool. Truck looks gorgeous! Can't wait to see the final pics and I'm not even a big drop fan(!) Know it's gonna look awesome - this is a beautiful truck.
Old 02-01-2015, 06:25 PM   #36
Coursey
Coursey's Avatar
I was surprised to here back from ECE on a sunday. But this is the correct way to install the sway bar.
Old 02-02-2015, 05:49 PM   #37
c10Dream'n
c10Dream'n's Avatar
Sooooo cool. The color is a beauty.
c10Dream'n is offline   Reply With Quote
Old 02-02-2015, 05:52 PM   #38
Coursey
Coursey's Avatar
Should i keep the rally wheels with a smaller tire?
Or go to a 20" TT2 wheel?
Old 02-02-2015, 05:59 PM   #39
c10Dream'n
c10Dream'n's Avatar
TT2's get my vote.
Old 02-04-2015, 08:20 AM   #40
Coursey
Coursey's Avatar
Before:
After:
Old 02-04-2015, 08:22 AM   #41
Coursey
Coursey's Avatar
I only have1/4"-1/2" clearance on the front tires. Defiantly have to get a smaller tire, which also should gain anther 1"+ of drop.
Old 02-04-2015, 08:25 AM   #42
darkhorse970
darkhorse970's Avatar
Your truck looks great!
Keith
SOLD - 1963 C10 Short Fleet
350/700R4
4/6 drop
1967 GMC Super Custom - Short Fleet
COPO concept w/427 BBC
T-400 w/Doug Nash overdrive
4/6 Drop, Buddy Buckets, etc...
Frame Off (In Progress)
I call it "Vulgar Display of Power"
1980 Silverado
Original paint
49k Original miles
4/6 drop
Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941
darkhorse970 is offline   Reply With Quote
Old 02-04-2015, 10:01 AM   #43
Ekliptix
Ekliptix's Avatar
Well done.
Ekliptix is offline   Reply With Quote
Old 02-05-2015, 08:13 AM   #44
bbcmudtruck
Are your rear springs ECE's 6" springs?
bbcmudtruck is offline   Reply With Quote
Old 02-05-2015, 08:15 AM   #45
Coursey
Coursey's Avatar
Originally Posted by bbcmudtruck View Post
are your rear springs ece's 6" springs?
yes
Old 02-05-2015, 09:07 AM   #46
Advanced Design
Advanced Design's Avatar
The truck looks very good with the drop! No C notch on the frame was necessary?
Advanced Design is offline   Reply With Quote
Old 02-05-2015, 09:21 AM   #47
Coursey
Coursey's Avatar
I have not drove it yet to see. The front tires are way to close to inner fenders to drive and the exhaust is hitting the rear end. Got to get smaller tires and re-route some pipes.
The rear end is 2.25" from the frame rail. It is close but i will see how it works out before I do a C-notch.
Old 02-05-2015, 09:52 AM   #48
Hart_Rod
Hart_Rod's Avatar
You might as well order one.........
Old 02-05-2015, 10:09 AM   #49
Mike C
Mike C's Avatar
Truck looks awesome.
My leaf spring truck with a flip came down 7". I removed the factory bump stops as well as the steel pad that is on a leaf axle. (Never owned a coil truck other than a c20 Sub so not sure what they look like.) I put the DJM urethane bumps on the frame above the axle. They hit occasionally but not often enough to c-notch it.
On your fronts, I'd look at a wheel with a different width/offset in addition to a narrower tire maybe? I have 27" tall tire on the front of mine (235 55 17) and with about 500 miles under my belt I have zero tire rubbing anywhere front or rear. And rears are 29" tall (275 55 17).
Taller tires are one of the things IMO that really help the look and stance of these trucks lowered.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 02-05-2015, 10:18 AM   #50
Coursey
Coursey's Avatar
ECE recommended using a 245/60/15 on the front and a 275/60/15 on the rear. The wheels are 15x8.
Any thoughts on this?
It currently has 255/70/15 all around
