LS Swap Shifters
Was just wondering what you guys have been using for shifters when going from a column shift to an automatic on the floor or from a 4 speed on the floor to a auto on the floor. Just bought a 5.3 with a 4l60e attached and will be going to an auto on the floor,and just trying to get some ideas of what you guys have been using for these swaps. Please post pictures of your setups. Thanks
meowMEOWmeowMEOW
Re: LS Swap Shifters
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
Boosted Member
I'm running the TCI Outlaw shifter. I'm really happy with it. I use the two red buttons for tap shifting the 4L80E.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
Old member
Mine is more of a stock shifter. It's a S-10 floor shifter for a 4l80E so it works great. I cut the front part off even with the cup holder's and made the box around the base.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
