01-18-2015, 03:54 PM | #776 |
Re: 69 GMC "Ol' Blue"
I doubt that, I have twin 18 year old girls, they are way smarter than we think.
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
01-18-2015, 04:03 PM | #777 |
Haha...then I guess I'll have to find another excuse Maybe I get this truck done and start on a car for her
01-18-2015, 11:05 PM | #778 | |
Brett 67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594 72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.) 72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614 YouTube: https://www.youtube.com/@6dee7-7dee2 |
01-18-2015, 11:49 PM | #779 |
Must be able to mod some kind of single shifter, you know like a boomarang, ok kidding on the boomarang but always a way to bend something then weld it to the base of the original type.
01-19-2015, 12:18 AM | #780 | |
Haha...boomerang....I like it I think you're right on this one. I'm going to work on doing that this upcoming weekend. |
01-20-2015, 12:16 PM | #781 |
Good progress Mike - even if the progress is learning what's going to work or not for that shifter. May be just camera angle, but that overdrive(?) shifter looks like it is going to be hard to access behind the TC shifter. Have you stuck a seat (or box) in there to sit on and see if they'll be in good positions?
Rick 78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel 71 GMC C25 350/TH400 - Project Angie 59 Chevy SWB Stepside (next in line? Not sure now ) 2001 GMC Sierra K2500 |
01-23-2015, 10:42 PM | #782 |
I am going to end up moving it back to its original position and fixing the TCase shifter. I hope so anyway
01-23-2015, 11:02 PM | #783 |
Acetylene torch and a bench vise will fix whatever ails ya Good luck with it!
01-23-2015, 11:15 PM | #784 |
You betcha!!! Thanks!
01-26-2015, 10:18 PM | #785 |
This weekend I was able to move back to the original position. It's actually going to work out well. I do need to tweak the 4wd lever a bit, but it's going to work well.
01-26-2015, 11:31 PM | #786 |
So you will still have 3 shifters or 2.
01-27-2015, 11:47 AM | #787 |
Good job! Looks like that got the TC shifter both lower and further forward and out of the way. Plus the mount looks more stable than before.
01-27-2015, 10:08 PM | #788 |
And the Hi-Lo lever will clear the TC lever ok? will being in 1st clear as well?
This is gonna be an interesting ride!
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
01-29-2015, 11:00 PM | #789 | ||
It will have 3. I can't wait
I really can't wait to drive this thing! |
01-30-2015, 12:55 PM | #790 |
If all else fails you can notch the seat. This made it interesting when we had 3 going for a ride!
01-31-2015, 10:49 AM | #791 |
That's a beautiful car Brett! I really don't want to mess with the seat, but you never know. Seems like everything I've been trying to do to avoid that has added years to this build
01-31-2015, 04:39 PM | #792 |
Lol.... 3 shifters all the way Mike! Looks good man
02-01-2015, 12:45 PM | #793 |
Thanks Molberg! It's nowhere near your quality of build, but it's definitely been fun
02-01-2015, 10:48 PM | #794 |
Ok, so this is all getting really old
The lever is going to need a some more work. |
02-01-2015, 11:47 PM | #795 |
Can you make that bracket just a little shorter and lean it forward just a little?
02-02-2015, 06:25 PM | #796 |
I think keeping some room between the 3 shifters is best. It appears from your pics that the seat is hitting when it is in the forward position? Also assuming it cannot be shifted in that position? That's kind of why I posted the pic of the 55 Pro Street car (thanks for the compliment, seat is in the rear position). That had an extreme seat notch in it for a Nash 5 speed with a Long shifter. Your notch would not need to be as extreme I don't think? Another plus is you would not be using the 4x shifter all the time. As long as you can select your range with the seat in the forward most position you have kept all the functionality yes?
02-06-2015, 11:59 PM | #797 | ||
02-23-2015, 01:44 PM | #798 | |
03-01-2015, 12:01 AM | #799 |
I never did get back to working on the truck. I've had some busy weeks, and this weekend I helped a friend adjust his valves in his Accord. But, I'm hoping to get some time tomorrow.
03-03-2015, 11:36 AM | #800 |
So here are some more pics for thought? The lower part is shaped like you said do you wanna try it? Pull the headrests, recover and she'd be a beauty. This is the seat somebody put in our old motorhome in front of the pass-thru.
