Old 02-03-2015, 08:28 PM   #1251
dwcardfan
dwcardfan's Avatar
Re: Donz '65 SWB Stepper Budget Build...
dwcardfan is offline   Reply With Quote
Old 02-03-2015, 09:34 PM   #1252
bj383ss
bj383ss's Avatar
Looking good Don!
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955
bj383ss is offline   Reply With Quote
Old 02-03-2015, 11:17 PM   #1253
clemdaddy
clemdaddy's Avatar
way to go don... nice detail and you're blowing through it. will be a roller before ya know it.
clemdaddy is offline   Reply With Quote
Old 02-03-2015, 11:33 PM   #1254
Ta2Don
Ta2Don's Avatar
Thanks Guyz!!!
If the weather guys and gals are close to right about this coming weekend's forecast... I should have a roller… That's the plan nonetheless...
DON
Proverbs 27:17
US Air Force Retarded errr Retired
My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920
My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266
My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD
Ta2Don is offline   Reply With Quote
Old 02-03-2015, 11:54 PM   #1255
Jeff La
Great work Don. Getting closer all the time.
Jeff La is offline   Reply With Quote
Old 02-04-2015, 03:44 AM   #1256
Grizz1963
Grizz1963's Avatar
Highly impressive progress Don.
I see JoJo checking out the progress too.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline   Reply With Quote
Old 02-04-2015, 06:58 AM   #1257
Bomp
Bomp's Avatar
Checkin in and lovin the progress!!!
Bomp is offline   Reply With Quote
Old 02-04-2015, 03:48 PM   #1258
Ta2Don
Ta2Don's Avatar
Thanks for checking in...
Gotta get some upper and lower Rear Spring Mounting Bolts and hardware as the Rust monster has used the past 50 years to slowly gnaw at these bolts...
Untitled by ta2don, on Flickr
Aiming to get this transformed into a roller this weekend...
DON
Proverbs 27:17
Old 02-08-2015, 09:30 PM   #1259
Ta2Don
Ta2Don's Avatar
Started out today with a small list of Honey-Do's...
Some springtime pruning and clean-up started, more to come tomorrow...
Before, during and after the Honey-do's I cleaned and painted the rear-end
Then painted the Upper and Lower Spring mounts…
Bolted up the Trailing Arms and rolled the Rear-end in place…
Track Bar was up next…
Rolled the frame and Rear-End out into the Sun…67F today...
Moved the Front Xmember into place and installed…
Final job of the day involved putting the P/S Box in place…
till next time...
DON
Proverbs 27:17
Old 02-08-2015, 09:43 PM   #1260
rusty76
rusty76's Avatar
Looking good!
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 02-08-2015, 09:44 PM   #1261
Bomp
Bomp's Avatar
All that hard work is starting to pay off.
Looking reeeal nice.
Old 02-08-2015, 10:00 PM   #1262
dwcardfan
dwcardfan's Avatar
Very nice brother!!!! It won't be long you will have that beast on the road.
Old 02-09-2015, 12:52 AM   #1263
Ta2Don
Ta2Don's Avatar
Thanks Guyz...
Had a bit of a setback...
Seems in my rush to get the steering box mounted, I measured something wrong… When I started to find the right placement for the center link, I found that no matter where I place it the pitman arm is a bit low...
After another trip to look at the old bent frame, it seems I need to raise the rear of the box about a quarter of an inch… That should eliminate the Tie Rod rubbing the Lower control arm issue that I found after getting the box and adapter plate bolted and welded in place...
Note to self… Slow down and check everything before making sparks and melting metal…
The Saga continues...
DON
Proverbs 27:17
Old 02-09-2015, 09:00 AM   #1264
clemdaddy
clemdaddy's Avatar
a good deal of progress this weekend Don. you got that roller going and it looks sweet. hope you have a great week...
Old 02-09-2015, 11:37 AM   #1265
jlsanborn
jlsanborn's Avatar
Great progress, looks great!
'77 K30 3+3 - "The Crummy"
http://67-72chevytrucks.com/vboard/s...d.php?t=640134
'67 C10 L/SWB - Soon to be daily driver!
http://67-72chevytrucks.com/vboard/s...d.php?t=471776
jlsanborn is offline   Reply With Quote
Old 02-09-2015, 12:32 PM   #1266
Paul Y
Don,
Looking good but PLEASE stop using cinder blocks as axle stands!!!
I have the scars to prove what happens when they collapse.....
P.
Paul Y is offline   Reply With Quote
Old 02-09-2015, 01:48 PM   #1267
CRGRS 66
CRGRS 66's Avatar
67F!!!! Spring Pruning!!!! we had 2" of snow last night... just a light dusting really
Progress looks great Don, I second the motion on cinder blocks.
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline   Reply With Quote
Old 02-10-2015, 02:13 PM   #1268
Ta2Don
Ta2Don's Avatar
Thanks for Looking in and also the input on the cinder blocks…
Only used those while I was getting the Steering box mounted...
Resting a sore shoulder from moving a wood burning fireplace out of a dilapidated house while trying to stay above the rotten floor...
Grabbed the mail this morning and was pleasantly surprised with a tube from Grizz in the UK...
Thanks Rian…
The yellow Boddingtons tap handle will be a shifter knob in a ratrod I will build for myself in the future…
The Bacardi bat bottle topper will go on the existing ratrod as a shifter topper…
Mrs. Boss already claimed the bracelets as well as the beanie...
The tube will be re-used to send something Rian's way...
DON
Proverbs 27:17
Old 02-10-2015, 09:31 PM   #1269
Ta2Don
Ta2Don's Avatar
Not much done today… I used the Bacardi Bat Bottle Topper and the small Sugar Skull as a Shifter extension for my Rat project…
IMG_1513 by ta2don, on Flickr
After the Shifter project, I pulled the Odometer out of the Gauge Instrument Cluster I recently scored and rolled it back to all Zeros...
The next step for the cluster is to swap the white faced speedo plate and apply the white face stickers to the 4 gauges… I had already done the white face treatment to the original cluster… I'm also going to research which Tach will be the easiest to adapt to the Right end of the gauge cluster… any tips will be appreciated...
DON
Proverbs 27:17
Old 02-11-2015, 06:05 PM   #1270
Grizz1963
Grizz1963's Avatar
Pleasure Don.
As long as I can create havoc in your life, I am a happy man.
Just checked in commented on your Ratrod project too.
Thought I would leave more crappy ideas for you to pursue ( I have the local scrap yard guy looking for a decent donor for me)
Wheelbarrow tub, "soap box cart"
How good would that look on the back of the Ratrod, or even your Stepper.??
Old 02-11-2015, 10:40 PM   #1271
Ta2Don
Ta2Don's Avatar
Saw a similar pic on FB and I have a derelict wheelbarrow here on the farm...
DON
Proverbs 27:17
Old 02-12-2015, 11:49 AM   #1272
Ta2Don
Ta2Don's Avatar
Just need to paint the metal plate that rests behind the cluster glass…
DON
Proverbs 27:17
Old 02-12-2015, 11:53 AM   #1273
dwcardfan
dwcardfan's Avatar
That cluster is looking sweet!
Old 02-13-2015, 10:25 AM   #1274
Ta2Don
Ta2Don's Avatar
Thanx Brotha!
…after chatting with Grizz, following the posting of the latest cluster pic, I may leave the metal plate black… Here is a pic of my original cluster in the white that I had intended to do… maybe too much white...
Decisions, decisions...
DON
Proverbs 27:17
Old 02-13-2015, 04:26 PM   #1275
CRGRS 66
CRGRS 66's Avatar
It does look a little overpowering all white, maybe try lighting it up at night see if you like it...
Craigerrr
65 swb, c10, step side, tattoo
