02-16-2015, 02:01 PM | #1 |
Re: Restoring Rusty - ENGINE TORQUES
let me run some of these ENGINE TORQUES by ya'll and see if you can verify them before I go snappin bolts, the table in the Manual is a bit confusing as it shows specs for the 250, 292, 350, and 454 motards
Oil Pump - 65 lb. ft. (really sounds like a lot) Main Bearing Cap - 70 lb. ft. Oil Pan - 80 lb. in. (1/4-20 bolts) ('member this one is in inches dummy) Oil Pan - 65 lb. in. (5/16-18 bolts) (so which one do I got?) Flywheel - 60 lb. ft. (7/16-20 bolt) Clutch Pressure Plate - 35 lb. ft. Flywheel Housing Cover - 80 lb in. (I hate it when they give you this in inches) |
02-16-2015, 02:26 PM | #2 | |
Main Bearing Cap - 70 lb. ft. Oil Pan - 12 lb ft (1/4-20 bolts) Oil Pan - 18 lb ft (5/16-18 bolts) You have both. all 4 corners are 5/16 bolts Flywheel - 60 lb. ft. (7/16-20 bolt) I use lock-tite here Clutch Pressure Plate - 35 lb. ft. I use lock-tite here Flywheel Housing - 25 lb ft flywheel cover (tin) - 12 to 15 lb ft |
02-16-2015, 02:58 PM | #3 |
Re: Restoring Rusty
My book shows the oil pan bolts as:
1/4 - 80 in-lbs (6.7 ft-lbs) 5/16 - 165 in-lbs (13.8 ft-lbs) Don't over torque these, because it distorts the sheet metal and opens up gaps between the bolts, which of course cause leaks. Greg
Greg 64 GMC Suburban - 283, NV3500, 14 bolt 77 C10 swb - 292, SM465, 12 bolt |
02-16-2015, 06:39 PM | #4 |
[QUOTE=Gregski;7051146]
Oil Pan - 80 lb. in. (1/4-20 bolts) ('member this one is in inches dummy) Oil Pan - 65 lb. in. (5/16-18 bolts) (so which one do I got?) An easy way to size the diameter of bolts is to fit the threads of the bolt into open end wrenches. The 1/4" bolts threaded area will fit nicely in a 1/4" inch wrench, 5/16" bolt threaded area in a 5/16" wrench and so on.
-400/400 1979 K25 350/SM465/205/44HD/14FF 1985 K20 400/400/208/10/14 1987 V10 TBI350/700R4/208/10/10 '85 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=643968 |
02-16-2015, 11:18 PM | #5 | |
[quote=400/400;7051594]
