Old 02-16-2015, 08:45 PM   #101
zicc1835
zicc1835's Avatar
Re: My 4/6" ECE lowering install thread - 72 Shorty
Originally Posted by zicc1835 View Post
interesting that this thread got reserected today ...because i was talking to a freind TODAY about installing my ECE kit actually i bought a bag set up recently ( from another board member)so in the rear at least I'm gonna use bags instead of the 6 inch drop springs any advice on this would be appreciated. Can someone also tell me do the top ECE shock relocater brackets bolt into the rivet wholes that the originals where in....i should mention i bought my kit from another board member about 2 years ago and have not even opened those boxes to look for directions
ill take some close ups this week but i got the rear lowering kit in minus the springs (used the bags) done with little effort took all day i took the rear and trailing arms out cleaned re bushed arms painted I'm real happy with the way its come out haven't driven it yet too much snow and cold and just plane $hitty weather in North East thanks for the tips
zicc1835 is offline   Reply With Quote
Old 02-17-2015, 06:07 PM   #102
hdff
hdff's Avatar
Originally Posted by Ekliptix View Post
The alignment of the panhard bar was easy. I installed it, measured the distance from the rear drum to the fender on each side, it wasn't even so I adjusted the panhard bar via the threads that make up its ends until the rear axle was centered.
For shocks I'm using the ones included in the ECE kit, KYB shocks. They are ok but if they had an upgrade option for the shocks, I'd get them.
From the way it looks the panhard has to be unbolted to adjust it how did you move the truck over for the adjustment ?
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach
"Wanda"
Don't argue with idiots, People watching may not be able to tell the difference...
There's someone in my head........But it's not me......
cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394
hdff is offline   Reply With Quote
Old 02-17-2015, 06:30 PM   #103
Boog
laying low
Boog's Avatar
You can use a comealong or ratchet strap to move it over.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 02-17-2015, 06:50 PM   #104
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Call Stan at ECE. He has a "no tool" method I used to center everything.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline   Reply With Quote
Old 02-17-2015, 07:07 PM   #105
leddzepp
Moderator
leddzepp's Avatar
Use a trac bar that has swivels at both ends. Bolt it in and twist to adjust. Nothing could be simpler
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 02-17-2015, 07:29 PM   #106
Ekliptix
Ekliptix's Avatar
I just unbolted one end (the lower end) turned it a couple threads, tapped the rear axel over slightly to line up with the panhard bar bolt hole and rebolted it on, then remeasured for center. For anyone who says they can adjust the panhard bar without removing it from the lower bolt mount, I don't know how this is possible, but it only took a few tries using the description above.
Ekliptix is offline   Reply With Quote
Old 02-17-2015, 09:23 PM   #107
zicc1835
zicc1835's Avatar
Old 02-17-2015, 09:33 PM   #108
Crushkrew
Crushkrew's Avatar
Ekliptix. ...did you end up installing the 1/2 blocks on rear?
Stance looks great....hoping to do my son's truck next weekend....
Crushkrew is offline   Reply With Quote
Old 02-22-2015, 01:09 PM   #109
Ekliptix
Ekliptix's Avatar
I did not until I measured the right side and it was slightly higher then the left side, so I installed a 1/2" block on the right to even it out, courtesy of member original-71.
Old 02-23-2015, 09:08 PM   #110
hdff
hdff's Avatar
Can anyone tell me what size the nuts on the u bolts are. I tried a 1" and a 1 1/8 " wrench and neither fit so I need to Go shopping for the right size tomorrow
"Wanda"
Old 02-23-2015, 09:19 PM   #111
jmking9
jmking9's Avatar
Just take the nut with you.
1970 SWB Build
jmking9 is offline   Reply With Quote
Old 02-23-2015, 09:25 PM   #112
hdff
hdff's Avatar
I need a wrench/impact socket to get it off the truck.
"Wanda"
Old 02-23-2015, 09:27 PM   #113
magwakeenercew2jh
I think jmking9 meant to just take the *back* part of the truck shopping with you.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 02-23-2015, 10:12 PM   #114
Lee H
Lee H's Avatar
Ekliptix, nice looking Jeep. Can you tell me about the lift and tire size, thanks. Lee.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 02-23-2015, 11:13 PM   #115
jmking9
jmking9's Avatar
Whoops! I think I misunderstood the situation (obviously)
It's probably a 1 1/16"
1970 SWB Build
Old 02-24-2015, 12:11 AM   #116
magwakeenercew2jh
Just read your build thread. If anyone reading this has not checked out that build thread, *do it*.
One of the best trucks.... and best build threads on the Forum.
And, all owner built.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 02-24-2015, 01:39 AM   #117
Ekliptix
Ekliptix's Avatar
Sorry, I don't know, the ECE instructions don't say and I'm not at home to check. If I recall, it was a 33mm socket or something weird.
Rubicon Express 4.5" lift (I think, or 3.5"). 33" BGFs. It's a 6 speed manual and the LJ chassis (2 door, long wheelbase).
Old 02-24-2015, 02:00 AM   #118
magwakeenercew2jh
Loved my Jeep, too. Put a ton of money in her *after* this pic.
Then sold at a substantial loss.
Typical of me.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 02-24-2015, 02:14 AM   #119
frankslagoon
The 70 is out back and I'm crawlin under tonight, but the 63 has 1 1/16 socket nuts. probably the same.
frankslagoon is offline   Reply With Quote
Old 02-24-2015, 09:42 AM   #120
Lee H
Lee H's Avatar
Thanks, killer stance. I'm going for a 2 door Rubicon this summer. I've done a lot of research on lifts and tire size. Looks like I'm leaning toward 2 1/2 metal cloak or teraflex with 33 inch tires. Will also more than likely go for the life time warranty.
Old 02-24-2015, 10:13 AM   #121
Coursey
Coursey's Avatar
I believe it was 1 1/16"
Coursey is offline   Reply With Quote
Old 02-24-2015, 03:57 PM   #122
stomper
Junior Member
stomper's Avatar
Originally Posted by Classic Heartbeat View Post
It kind of looks like to me that the raised line in his pad is created by the stock groove in his rotor. If his rotor were gouged bad enough to make a mark like that, it would be too bad to turn. The pads look good otherwise. I would put it back together as is, just depress the caliper so it will go back onto the rotor. I wouldn't even change the pads. They have lots of life left in them. WES
20 years ago a guy at NAPA said I needed new rotors because there was a huge gouge in both of mine... That didn't seem right to me. I learned later these stock grooves indicate life left on the rotors.
"I was patina when patina wasn't cool."
1973 Cheyenne SWB Gold White Fleetsides/Saddle
stomper is offline   Reply With Quote
Old 02-24-2015, 06:14 PM   #123
WarMonger
WarMonger's Avatar
Zici1835, how low is your gas tank to the ground when the bags are air'd and down? I dont have bags, but my truck is lowered. I have like 7" ground clearance. That has me a little worried. I think I will try to weld a skid plate so I have a little insurance on the truck.
WarMonger is offline   Reply With Quote
Old 02-26-2015, 11:09 PM   #124
zicc1835
zicc1835's Avatar
ill measure it Friday or Saturday just got home tonight from a business trip
Old 03-01-2015, 10:30 PM   #125
zicc1835
zicc1835's Avatar
all the way down on bump stops
