01-15-2015, 11:33 PM | #51 | |
Re: I was bored, so I made a cold start video!
Good I hope you don't have to go manifold vacuum I just don't like to do it but it is a legit fix for dieseling. So, what happened in regards to your hesitation? Did you check the accel pump linkage on the carb? |
01-15-2015, 11:47 PM | #52 | |
Next thing to do is run new wires to my HEI and choke this weekend. Then install my fuel pressure regulator and set my psi to 5.5. I'm hoping that will fix my occasional flooding issues. It only does it after the truck sits for more that 20 - 30 minutes after being at full operating temperature. Dude once again, you are the man and have helped me a ton!!!
1972 Chevrolet C20 Cheyenne Custom Camper LWB - 350 / 330 HP GM Crate - TH350 / Mild Shift Kit - Dark Blue / Medium Blue - Paint Code 559 |
02-19-2015, 12:15 AM | #53 |
Mechanicalman....
I have learned a wealth of knowledge from you.....am setting up the same thing in a 68 C10..... 1972BlueC20.....I'm out in Katy.....after I'm done, I'll contact you and compare some notes. Thanks guys!!!! |
