Old 02-05-2015, 11:01 AM   #51
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
Re: "Brass Monkey".....Installing 4/6" ECE Drop Kit
Originally Posted by Coursey View Post
ECE recommended using a 245/60/15 on the front and a 275/60/15 on the rear. The wheels are 15x8.
Any thoughts on this?
It currently has 255/70/15 all around
That should help a good bit, but if you could swap your front wheels for 15x7 it will help pull the tire away from where the inner fender rolls out to the fender lip. Keep in mind using those sizes will give you a little "rake" as the 245 is about 1.4" shorter than the 275. Just my .02¢.
I am in the middle of a frame off build using PB parts, LS1 etc... and reading your thread and has me wishing I had found a truck like yours and done exactly what you are doing. You have a good one hold on to it.
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 02-05-2015, 03:25 PM   #52
Mike C
Mike C's Avatar
I think a 225 65 on a 7" rim would be near ideal. Not sure if that tire exists though.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 02-05-2015, 03:35 PM   #53
Coursey
Coursey's Avatar
Nice truck, One day i hope to go the PB/LS route. But may not be with this truck.
I pulled the BFG size charts.
Would i be better off with a 255/60 on the rear with the 245/60on the front?
This would minimize the tire rake to a 1/4" differece in lieu of a .7" difference with the 275/245 combo.
Coursey is offline   Reply With Quote
Old 02-05-2015, 03:52 PM   #54
C10_ustacould
I think that is personal preference, I like a little rake but you may want to sit level. It's up to you.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 02-05-2015, 03:56 PM   #55
Mike C
Mike C's Avatar
I have 29" tires on the back of my truck and 27" on the front. That is a little noticeable rake. Those small #'s you talk won't matter a bit.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 02-05-2015, 04:21 PM   #56
Coursey
Coursey's Avatar
It looks to me that the truck has about the right amount of rake now, But it also has not settled out yet.
I don't really want to add another 3/4" of rake to it.
I was thinking that with the 4/6 drop it would have been more leveled out initially.
Old 02-05-2015, 05:56 PM   #57
C10_ustacould
I had a 28" front tire and 29" rear tire with a 5.5/7 drop before I took my truck apart and it sat almost dead level. The secret for not rubbing in the front is tire size and off-set (backspace).
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 02-05-2015, 06:04 PM   #58
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
I agree with ECE . A 245/60 15 is only 26.46 inches tall where as the 255/70 is 29.04 tall. A 245 tire is 9.64 inches wide and a 255 is 10.03 wide which is .39 wider. You are running 8 inch wide rims which are perfect for 255/70's. In you went to a 245/60 on a 7 inch wide rim your truck should have any rubbing problems as your tire would be 1.39 inches narrower and 2.58 inches lower. If you want the rake look then the 275/15's on the back with 245's up front will give you that. If you want it level run the 245's on all 4 corners and the 2 inch front to back drop difference should just about level out the truck. I believe there is a natural 3 to 31/2 front to back natural height difference on a stock height truck.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 02-05-2015, 07:38 PM   #59
Malamute
Malamute's Avatar
Looks great! Makes me wish mine was closer to being finished.
Malamute is offline   Reply With Quote
Old 02-19-2015, 04:03 PM   #60
Coursey
Coursey's Avatar
New tires are on. Just waiting for this 12" snow to get off the roads so I can get to the alignment shop.
Old 02-19-2015, 04:27 PM   #61
Boog
laying low
Boog's Avatar
That looks a lot better. Plenty of tire clearance I bet. Monkey looks good. ��
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 02-19-2015, 04:28 PM   #62
C10_ustacould
It's a sweet ride, it would be hard to not be able to drive it. Hope the weather clears up for you all!
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 02-19-2015, 04:32 PM   #63
Coursey
Coursey's Avatar
Spring cant get here quick enough!
Old 02-19-2015, 04:49 PM   #64
Hart_Rod
Hart_Rod's Avatar
Looks good. Did it have a sway bar or did you add one?
Hart_Rod is offline   Reply With Quote
Old 02-19-2015, 04:52 PM   #65
Coursey
Coursey's Avatar
I added the ECE front sway bar.
Old 02-19-2015, 04:53 PM   #66
Hart_Rod
Hart_Rod's Avatar
Kewl. It should handle well.
Old 02-19-2015, 04:57 PM   #67
Coursey
Coursey's Avatar
I cant wait to see. I have some nice banked backroad curves going through open fields around my house.
Old 02-19-2015, 05:29 PM   #68
c10Dream'n
c10Dream'n's Avatar
amazing what an altitude adjustment will do. Looking good.
c10Dream'n is offline   Reply With Quote
Old 02-19-2015, 05:42 PM   #69
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Very nice! Stance looks perfect.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 02-19-2015, 06:17 PM   #70
jdw
What size tires did you end up going with? Truck looks great!
jdw is offline   Reply With Quote
Old 02-19-2015, 07:04 PM   #71
nlped
nlped's Avatar
Truck looks killer! I love the 61 Biscayne too. I'd take either one
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 02-19-2015, 07:52 PM   #72
Coursey
Coursey's Avatar
245/60/15
275/60/15
BFG Radial TA
15x8 wheels
Old 02-19-2015, 10:40 PM   #73
Advanced Design
Advanced Design's Avatar
Looks good Coursey. Nice thread, thanks for sharing!
Yeah...more snow coming.
Advanced Design is offline   Reply With Quote
Old 03-03-2015, 09:13 AM   #74
Coursey
Coursey's Avatar
Finally after 2 weeks of ice I was able to get it loaded on the trailer. Now they are calling for 6-10" of more ice and snow!
I don't know if i will ever get this truck to the alignment shop!
Old 03-03-2015, 09:48 AM   #75
Advanced Design
Winter has really come on hard here at the end. Nice trailer! Truck looks good. Is that your shop? Really nice. And of course I like the tow rig too.
