07-12-2010, 10:37 PM | #76 |
Strongman Garage
Re: 68 GMC 4x4 Suburban build up
[QUOTE=70BLAZERX2;4082353]I just put the dana 60 dually front and a 14bolt dually rear under a 69 K/20 frame and built this truck.
The front end was a bolt in. Nice truck man!
Kalle 68 GMC Suburban 1500 4x4 SOLD 69 Pontiac Lemans 99 Silverado 4.8 5 speed ECSB [ Facebook Instagram Subscribe on YOUTUBE |
07-13-2010, 03:02 PM | #77 |
Thank you..this ton dually 4x4 will hual 5,000 lbs of gravel and i even made it a dump bed..A few trips to tracker supply..and it was done..Now i need to paint it.
Nice burb... |
07-16-2010, 04:35 PM | #78 |
Glad to see you are still giving it heck!! I bought that K30 and pulled the drivetrain about a week or two ago and will get the axles next. Anyone want a nice rust free 81 K30, come get it or it'll get crushed!! I am concerned about the front lift? I am sceeerd I'll need a ladder to get in it?! Looking good!!
07-16-2010, 06:27 PM | #79 |
This is the stock 1969 K/20 top main leaf,and stock 1987 K/30 front springs ,less the top one and look how high i am sitting..It looks great..
Attachment 608739[/QUOTE] |
01-05-2011, 02:16 PM | #80 |
Junk Yartist
any updates?
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
01-05-2011, 05:56 PM | #81 |
mine with 5,320 lbs of gravel..The front 87 sway bar ,i used old shackle for rear leafs ..and bolted it to stock 69 crossmember..rides great.
Would like to see updates too. Last edited by 70BLAZERX2; 01-05-2011 at 05:57 PM. |
01-17-2011, 02:33 AM | #82 |
i like it,same thing i want to do to my 56
02-13-2011, 12:27 AM | #83 |
cool build i like the buckets! you need to weld a bracket to the back so the arm rest/seat back doesnt flip all the way back... dont know if you thought about it or not...
04-15-2011, 02:42 AM | #84 |
Looks like yours is almost a twin to my recently purchased 68 Chevy 4X4 burb.
Nice truck!
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps. 68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread Last edited by Mt Man Chad; 04-15-2011 at 02:43 AM. |
10-23-2011, 02:30 PM | #85 | |
Strongman Garage
Sweet! Got any pics? TTT to keep me accountable.....
08-29-2014, 01:36 PM | #86 |
Strongman Garage
Life has been crazy busy with competing as a strongman, getting married, starting a business etc but I am going this afternoon to pick up my baby and bring her home from my moms ranch! Time to get serious
08-31-2014, 05:05 PM | #87 |
Strongman Garage
Got it loaded up and just about in the driveway... That might not seem like too big of a deal but it was parked on the side of a huge hill no brakes, no winch, giant burb... Got it done though! Feels good to have it home... Now to get the 454/th400/np205 over here and get this thing going...
10-19-2014, 12:43 AM | #88 |
Strongman Garage
got the 454 tbi/th400/np205 to the house now... Not sure on the direction I want to go with building it. keep the tbi? throw on a carb? get aluminium heads, etc and build it up really nice? choices....
12-10-2014, 02:33 PM | #89 |
Well if you want a solid runner with good torque that runs on it's side. Keep the TBI. If you want to make some power, heads, cam, intake and a carb.
12-10-2014, 02:42 PM | #90 | |
Strongman Garage
It will be awhile before I need to decide anyway though. I got the captnfab parts to put the hydroboost setup on and will do so next week when I recover from surgery
02-17-2015, 10:26 PM | #91 |
Bump
Mine: 72 c20 Chevy suburban, 02 5.3 w/4l60e , factory ac and 50gal tank. 70 k10 Chevy burb, 04 5.3 w/4l60e np241, with dual 30gal saddle tanks and rear 30 gal tank Dads: 67 c10 step side(project) 72 c10 GMC burb 350/400, with 67 Chevy front clip(grocery getter) Ours: 67 c30 tow truck 70 c10 long bed 383stroker w/digital gauges(work truck) |
02-20-2015, 05:12 PM | #92 |
Strongman Garage
Been trying to track down a 14bolt full floater that isn't $600
Put a power brake booster on it and been tightening up some loose ends as I am going to get it running/driving as is with the current 327 Also noticed the hard brake line is busted so I am ordering a all new set of stainless lines and extended stainless steel lines from Inline Tube next week and replacing the sending unit in the gas tank. Something that concerns me is the clutch won't return maybe the pressure plate is stuck from sitting? All the return springs, etc are hooked up
02-20-2015, 05:47 PM | #93 | |
The Older Generation
On the clutch do you mean that the pedal is on the floor? The pressure plate doesn't normally stick unless it goes over center. The clutch disk is what sticks from sitting and in that case it just won't release when you push the pedal down. The pedal still works as it should. LockDoc
02-21-2015, 07:15 PM | #94 | |
Strongman Garage
Thanks!
02-21-2015, 09:18 PM | #95 | |
Does it actually release though? Can you have someone roll the truck with the trans in gear and the clutch pushed in? Are you sure all of the linkage is connected? It sounds like the linkage might be disconnected somewhere. LockDoc
02-22-2015, 04:20 PM | #96 |
What?
Kalle, I have a 14 bolt FF that is already set up for a '68 burb.
I'd make you a deal on it if you want to make a trip down to SoCal.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
02-22-2015, 04:23 PM | #97 |
Strongman Garage
What gear ratio and where in SoCal? I will probably take you up on that! We visit family in San Diego a few times a year
02-22-2015, 04:25 PM | #98 | |
Strongman Garage
It was disconnected and I found where and reconnected it. I will have to look into it more and deal with getting the brakes working first
02-22-2015, 04:25 PM | #99 |
What?
I don't know the gear ratio, but I could pull the cover off and figure out.
I am in the Temecula area just off Winchester Rd on I-15.
02-22-2015, 04:37 PM | #100 | |
Strongman Garage
Thanks!
