02-23-2015, 10:42 PM | #76 |
Re: My suburban's Twisted Little Sister
Well Friday went well and we finished the rear frame turn downs. Today however did not go as well. First the air compressor blew a head gasket then my mig welder screwed up. The wire keeps getting jammed inside the nozzle. We did manage to tack the reenforcing plates over the joints
Dale ---------------- My suburban's Twisted Little Sister http://67-72chevytrucks.com/vboard/s...d.php?t=655167 |
02-23-2015, 11:11 PM | #77 |
Nice! I had a rough shop day Saturday with the air compressor going down and the heat went out too.
02-24-2015, 01:24 AM | #78 | |
02-25-2015, 10:00 PM | #79 | ||
We got the compressor rebuilt but the mig welder is still down. So today we decided to flip the frame over to weld the bottom. Used the engine hoist to remove the front and rear suspension. Then picked the frame up and flipped it over
02-25-2015, 11:39 PM | #80 | |
02-26-2015, 08:58 PM | #81 | |
We spent all day welding so I have no new pictures
03-02-2015, 09:12 PM | #82 |
Well since the frame is nearly finished and the temperature finally managed to break into the 20's we decided to bring the truck into the shop and let the snow and ice melt
03-02-2015, 09:24 PM | #83 |
The passenger side is fairly strait The drivers side has a dent in the door and one in the rear quarter. The rear doors have some dents in the lower gate
03-02-2015, 10:11 PM | #84 |
Rust in the quarters. Rust in the kick panels. Rust in the vent housings. Rust in the rockers and floor. The door bottoms aren't so bad
03-03-2015, 12:18 AM | #85 |
1961 crewcab
the bonus is that the rear floor isn't rusty-since its wood!
your rust repair looks about as bad as mine was on my 64 sub...( some shots of it here: http://67-72chevytrucks.com/vboard/s...=448681&page=3 ) are you going to just get some repro rockers and fab up a new floor?
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
03-03-2015, 09:27 AM | #86 |
I like the color on the Burb. Rust repair will keep you busy a day or two.
03-04-2015, 09:11 PM | #87 |
Took a couple better pictures of the rusty rockers and floor. We got the truck stripped and a bunch of parts piled up.
03-04-2015, 09:41 PM | #88 |
03-04-2015, 09:42 PM | #89 |
Location: Grand Rapids, Michigan, otherwise known as Beer City U.S.A.
Dude!
Looking like a bit of work in the future in order to make that all-good!!!!
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=512904 |
03-04-2015, 10:27 PM | #90 | ||
We started to weld in some bracing. We used 2" because it was laying around Tomorrow we will put in some X braces We marked out two cut lines to move the door frame back 16"
03-04-2015, 10:43 PM | #91 |
Come and have a look or let me know what you need.
lots of work but lots of fun too
03-04-2015, 11:47 PM | #92 |
1961 crewcab
hmmm... now its getting interesting... corvette wheelbase? 98 inches or so?
03-05-2015, 12:18 AM | #93 |
Nice project! Subscribed.
03-05-2015, 01:34 AM | #94 |
subscribed too
03-05-2015, 01:46 AM | #95 |
US Army Veteran
Subscribed. Trying to visualized what you are doing with the frame. In some photos, it looks like the skeleton of a dinosaur, in others I envision what it must have been like working with John DeLorean in a garage!
Suspense is killing me!
1972 C10 Highlander - The making of a daily driver |
03-05-2015, 03:37 AM | #96 |
Love this build.
That pic of the snow and ice when you pulled it into the shop, should be captioned "Who needs to wait for summer?"
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. |
03-05-2015, 08:29 PM | #97 | |||
Thanks and welcome welcome Quote:
Welded the X braces in front and back. Then we made a pointer to find the axle center line. We spent a lot of time laying out cut lines. They are a little hard to see in the photos
03-05-2015, 08:42 PM | #98 |
One more picture of the cut lines. Then we used tape to show where the cuts will be made. Rear door frame moves back 16" wheel well moves forward 9 3/4" the back of the truck moves forward 19". We finished the day drilling spot welds so we can remove the roof.
03-05-2015, 09:03 PM | #99 |
HOLD THE PHONE!!!! i know your not making a coupe' burban??? if your are im coming up there to drool, and pick ur left over parts...
03-05-2015, 09:47 PM | #100 |
V12? Cool!...somehow I missed the V12 part of the build.
