01-17-2015, 09:24 PM | #76 |
Re: 1977 K10 Silverado Longbox
Get better dude. The flu sucks. Been there done that.......
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
01-19-2015, 10:31 AM | #77 |
Thanks guys! Feeling better and got some stuff done this weekend. My new problem is how to clean out my axle tubes. Full of rust and looks like ****! I don't really want to sandblast so i'm looking at other options.. any suggestions? Here's everything torn down.
01-19-2015, 10:33 AM | #78 |
01-19-2015, 10:35 AM | #79 |
01-19-2015, 05:38 PM | #80 |
Wonder if you could use something like a dingle ball deal that you could put on a drill and spin in the axles to clean them? Or some sort of wire brush on a long rod? I have no idea short of taking it to be hot tanked or something. Least you got something done this weekend. It sure was nice outside.
01-19-2015, 07:24 PM | #81 |
To clean out axle tubes, I screwed a fender washer to a dowel and scrap them out the best I can.
-400/400 1979 K25 350/SM465/205/44HD/14FF 1985 K20 400/400/208/10/14 1987 V10 TBI350/700R4/208/10/10 '85 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=643968 |
01-20-2015, 09:58 AM | #82 |
So here's what I opted for. Drilled out a 3" wire wheel and bolted on a long piece of threaded rod. Worked like a champ for only about $10. I'll get some more pics up when I get it cleaned up with new bearings and guts back in.
01-20-2015, 05:46 PM | #83 |
Smart cookie.
02-03-2015, 08:47 PM | #84 |
subscribed. where did you get the rubber for the fuel tank filler necks? I cant seem to find, would napa or carquest have them?
1985 GMC K2500. 350/TH400/208. 4:10's. stock. 1987 Chevy V30. 454/TH400/205 4:10's. Stock SOLD. |
02-04-2015, 01:55 PM | #85 |
No not an exact match. You have to use a fuel grade not radiator hose. You may be able to match it up if you have a real good clerk.. shm!
I got mine from LMC. Cheapest I found. http://www.lmctruck.com/icatalog/cc/full.aspx?Page=49 |
02-09-2015, 10:20 AM | #86 |
Good weather = progress!
02-09-2015, 10:24 AM | #87 |
02-09-2015, 10:25 AM | #88 |
Also got the new Timken bearings pressed on and races knocked in.
02-09-2015, 06:07 PM | #89 |
Really was nice weather this past weekend wasn't it? I wished I could have enjoyed it more. Looks like you got a lot done.
02-20-2015, 12:28 PM | #90 |
Damn this cold weather!! Guys i skipped out on a bunch of pics but got the rear end P coated and all built back together. I had to slap it all together so I could get around in the snow. All new hardware, new rear leafs, new stainless steel brake lines from the union back. Gas tank completely redone with new sending unit, hoses and hardware. Also threw on two Thrush Turbo muffs and boy do I like em'! Seems like I gained an inch or two with the new rear springs. I got them from Auto Spring Co. in Winston-Salem, NC. Same amount in the pack just fresh with no sag I suppose. Time to do the front because Ive got a serious rake going on!
02-20-2015, 06:13 PM | #91 |
Stupid cold. Been in it all week. I'm ready for the weekend. Good job on getting things done.
02-20-2015, 11:40 PM | #92 |
Second Chance Program
Sure looks good!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt. 77 C20 crew cab Silverado. 396/th400. In work. |
02-21-2015, 12:36 AM | #93 |
Nice work!!!
02-21-2015, 03:18 AM | #94 |
Nice work!
1983 GMC SWB - 350, TH-400 2002 Camaro SS - 408 9sec street car 2000 Trans Am - H/C/I 2014 Chevy Z71 |
02-26-2015, 04:12 PM | #95 |
I was gifted with the sweet smell of antifreeze in the cab a few days ago... New heater core and put in a new speaker while I was in the dash area. The original Harrison was to blame. Boy was that a ***** job to do especially if you have an A/C car. I went ahead and ripped out all the A/C lines and compressor. I'll start to get that in order and replaced before it gets to spring. We got about 6" of snow last night so I get a shot of her in the drive.
02-26-2015, 04:14 PM | #96 |
and more..
02-26-2015, 06:09 PM | #97 |
Looking good in the snow. We got 6 inches as well.
02-26-2015, 11:34 PM | #98 |
How do you like the speaker?
02-27-2015, 12:10 PM | #99 |
To be honest y5mgisi, I found my radio was the culprit when I hooked it all up. No sound coming out.. Besides this is the stereo model speaker and my radio is a mono unit. I guess I will be venturing down the road of stereos in c/k conversions next!
02-27-2015, 03:13 PM | #100 |
It has to sound better than the stock one that was there. Especially since the old one was wore out.
