Old 03-02-2015, 07:53 PM   #1
KyleSeal
KyleSeal's Avatar
New Ball Joint Install Questions
Been searching for a little and couldn't quite find an answer so I guess I'll go ahead and pose a question.
I'm replacing all my ball joints on my '70 2wd C10, stock drums up front so stock style LBJ & UBJ.
How do I press these onto the spindle? Do I just torque the castle nut to spec and they go into place? I know they are tapered in, so how do I get them completely 'seated' I guess you could say.
First time working on IFS & ball joints, so I'm very new to this.
Also - how do I grease the lower ball joint (since there's no grease port)? Do I just cover the ball joint in grease and add the rubber boot?
Sorry for so many questions, I just know how important good ball joint installation is and wanted to make sure I do this once, not multiple times fixing my carelessness..
"Sometimes I do serve as a good bad example. Glad to be of service."
My Build Thread (1967 C10, lowered, EFI, daily truck): http://67-72chevytrucks.com/vboard/s...d.php?t=830809
KyleSeal is offline   Reply With Quote
Old 03-02-2015, 07:56 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: New Ball Joint Install Questions
I suggest searching Youtube for videos.
There are a ton of them that explain the entire process.
Keith
Convert to disc brakes.
Old 03-02-2015, 07:58 PM   #3
big bad orange
big bad orange's Avatar
now I did this on my 72 so not sure if it is the same for your 70. The top ones bolted in and your torque to spec. The bottom ones I hammered out then to get in I rented a press from advance.
just like that old Johnny Cash song. "One piece at a time and I am go na make an old C10 mine a look at all your faces when I drive through your town"
big bad orange is offline   Reply With Quote
1/2 ton, 1970, ball joints, c10
