Old 03-04-2015, 11:26 PM   #1126
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Re: The Story Of A Cummins Suburban (Lots Of Pics)
Did they pre heat the axle housing prior welding that truss on there and what did they weld it with? Also way back when, did you replace all 4 rs9000 shocks or just the front ones and how have you been liking them since you adjusted them? I'm thinking about buying some. Andddd have you put any thought into adding hydro assist steering? I've really been thinking about doing it on one... of my projects and I almost ordered the ram already.
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 03-06-2015, 11:36 PM   #1127
mosesburb
I had a V-8
mosesburb's Avatar
Don't know if they preheated the housing. They used a very large MIG welder. I have RS9000's at all four corners. I think the front ones are 9000x maybe?? They are bigger than the rears. I'm thinking that I could gain more control with better shocks. On undulating trails/roads, the handling gets a bit interesting at times. No thought whatsoever on hydro steering. I'm only running 33's, so it is not needed.
1972 K20 Suburban, 5.9L Cummins, Banks Power Pack, NV4500HD, NP205, H.A.D., D60/14FF ARB Link To Build: HERE.
mosesburb is offline   Reply With Quote
Old 03-07-2015, 04:40 AM   #1128
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
I might steal that truss "design", it's very simple but effective. Would you recommend those shocks, I thought they were supposed to be pretty good? With the hydro assist I just like the idea of the one finger steering even when the tire is against a rock, and I'll be running 37" tires.
Tony
Old 03-07-2015, 12:58 PM   #1129
notchbackgta
Did they use nickel wire? Steel wire doesn't really stick to cast iron and will pop off from what I've seen online
notchbackgta is offline   Reply With Quote
Old 03-07-2015, 05:49 PM   #1130
ryanroo
ryanroo's Avatar
When done correctly er70-s2 is OK for welding cast. there are better options but ou can make a weld that will hold and be fine, especially in the case outlined here with regular steel filler.
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 03-17-2015, 12:53 AM   #1131
mosesburb
I had a V-8
mosesburb's Avatar
I'd look for some better shocks if I were shopping. These are *ok* for the price, but for a little more a better quality shock could be had.
Not sure what they used for filler.
If Roo says it's good, then I have complete confidence in it.
Old 03-17-2015, 12:58 AM   #1132
mosesburb
I had a V-8
mosesburb's Avatar
This was the next trip after the Crown King run that my fan clutch failed on and Lance's battery went on its own adventure. We decided to head up to the Workman Creek area. We ran the area a couple years ago and thought it would be a good run again, so with a few adjustments to the plan, we were off.
One of the changes was the direction of travel. We decided since it was hot out to run it backward so as to get into elevation and cooler temperatures quicker. My buddy Lance's Suburban does not have air conditioning yet and with his wife in the truck, getting to cooler temps as quickly as possible would be a good thing.
Seriously, watch out for them:
Neat bridge on the Apache Trail in the Superstitions. If you look under it you can see an old abutment on the left side:
At the end of the Apache Trail we are greeted by Roosevelt Dam:
We turned onto the road heading to our destination when Lance came across the radio with something that sounded like "skateboards". I hit him back with a "what??" I didn't get a response from him, but in a moment was greeted by this sight:
These guys were coming down the hill at a velocity best measured in Mach units. Damn near took the lead nut-job out. There was four or five on boards and a Prius following with a camera filming the stupidity. Never have encountered that before...
We went up Workman Creek and stopped at one of the radioactive day-use areas to have some lunch. It was a nice quiet area with plenty of shade. Gratuitous truck pic from lunch:
Interesting bug hanging out on the bottom of the chair:
One interesting thing about having the trucks out in the wilderness is seeing how bugs react to them. My orange truck is a virtual beacon to bugs, bees and wasps. It is kind of neat in a way. While sitting at lunch a butterfly was trying to get something off of Lance's side marker lens:
Gratuitous truck pic from up by the falls:
A view from up on the fire lookout tower:
All in all it was a nice trip. We came back the next day while Lance and his wife decided to camp in a little shaded area to head back in the morning before it got too hot out. They made it back and I think the trip moved making the AC functional up on the priority list a few notches.
Old 03-17-2015, 08:55 AM   #1133
hgs_notes
GEARHEAD
hgs_notes's Avatar
Looks like a good trip for a day or 2. Once I get the Jimmy back together, making a trip down your way will be a priority.
hgs_notes is offline   Reply With Quote
Old 03-17-2015, 09:36 AM   #1134
83GMCK2500
It had been so long since I have read through this whole thread, is that a later 14FF with slide-off drums that I see? Roughly '93-'00, isn't it? How close is the track width to your front?
I love all of the trip photos and adventures that you share, I always look forward to your updates in this thread.
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 03-17-2015, 11:42 AM   #1135
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
More awesomeness!
Tony
Old 03-17-2015, 03:07 PM   #1136
roushinator
roushinator's Avatar
Awesome build and awesome adventures!
Ryan...
1972 C10 Stepside With 2014 Camaro 6.2L/6l80e drivetrain
http://67-72chevytrucks.com/vboard/s...11#post5532411
roushinator is offline   Reply With Quote
Old 03-17-2015, 10:21 PM   #1137
mosesburb
I had a V-8
mosesburb's Avatar
All kinds of good stuff to see around here.
It is out of a '96 or '97 van. Yes on the slide off drums. It is approximately the same track width as the front D60 because the vans use a wider housing than do the trucks.
Cool!!
More awesomeness!
Thanks!!
Thanks!!
Old 03-18-2015, 06:20 PM   #1138
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Nice trip once again! WTF kind of bug is that? A holstein beetle?
Ryan
1969 Chevy milk truck
Old 03-19-2015, 12:28 AM   #1139
mosesburb
I had a V-8
mosesburb's Avatar
That's funny, I was thinking the same thing on the type of bug. I don't want to try and milk it though...
Old 03-19-2015, 02:17 AM   #1140
Dieselwrencher
No doubt!
Ryan
Old 04-09-2015, 01:32 AM   #1141
1leglance
Nick....oh Nick...
You are soooo far behind on this thread. I might actually have to start posting in my own thread with updates just to get pics of your rig on the board
Hint...dead cows on the way to cool mine ruins
Other trip with more mines and really cool monuments...
1leglance is offline   Reply With Quote
Old 04-09-2015, 01:43 AM   #1142
mosesburb
I had a V-8
mosesburb's Avatar
Originally Posted by 1leglance View Post
Nick....oh Nick...
Might not be a bad idea since you haven't posted in yours for over five months.
I seem to have many things competing for my "free" time and the threads seem to lose the battle most often.
Old 04-09-2015, 09:11 AM   #1143
ryanroo
ryanroo's Avatar
two awesome burbs. the wiring project must have been a success!
72 K20 12v build
Old 04-10-2015, 01:24 AM   #1144
mosesburb
I had a V-8
mosesburb's Avatar
One is pretty awesome, the other is just a whole lot less janke than when I started on it.
The wiring is all done except for some roof mounted accessory lighting circuits and solar panel wiring. It is all stubbed to the ceiling at the rear of the interior, just have to finish that when the owner leaves his private jets in the hangar and gets it back over here. Wiring is one thing I have done more of than I would care to admit, but of all that I have done, I have never figured out a way to do it quickly, but still do it right so it ends up taking forrrrrrrreverrrrrrrrrr. Ugh.
Old 04-10-2015, 11:06 AM   #1145
ryanroo
ryanroo's Avatar
i smell what you are stomping around in. oh brother do i. not fast, not cheap.
72 K20 12v build
Old 04-10-2015, 11:28 AM   #1146
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
Ain’t that the truth! I have yet to see a single picture from the White Rim trip we did with Lance in 2011 when he still had the troopy.
DirtyLarry is offline   Reply With Quote
Old 04-11-2015, 01:09 AM   #1147
1leglance
Hey I thought we were picking on Nick in his own thread
Ok so maybe I am a bit slow on posting my own stuff...but that is because it is so much fun to poop in my friend's build threads....like maybe a white burb I know about Larry
Old 04-11-2015, 02:28 AM   #1148
mosesburb
I had a V-8
mosesburb's Avatar
Yeah, nothing like spending a TON of money on product so you can spend a TON of time installing it.
That still really doesn't covey just how much time and money is actually involved.
Old 04-15-2015, 08:44 AM   #1149
ERASER5
ERASER5's Avatar
In all your trips to the middle of nowhere, have you ever come across any concrete arrows? These are large arrow shaped concrete pads made to direct old time airmail planes flying over, well, the middle of nowhere. I saw some pictures on the net and thought they were interesting.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 04-15-2015, 01:30 PM   #1150
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
I saw that on Facebook a couple of weeks ago as well, pretty cool.
Tony
