Old 01-28-2004, 07:54 PM   #1
72step
72step's Avatar
Question Ford 9 inch question
I have a chance to buy a 9" rear off a late 70's ford f150. Would that be an ideal rear for my 72? Would I have to change the axles out to match my bolt pattern???Thanks in advance
72step is offline   Reply With Quote
Old 01-28-2004, 08:21 PM   #2
fast14
fast14's Avatar
I think most nine inch truck axles had 5 on 5 1/2 bolt patterns if i remember right. You can take the axles to a machine shop and they can weld up the old bolt pattern hols and smooth the face back down on a lathe and redrill the axles to your bolt pattern.
Just a little crazy
1970 chevy full size half ton, soon to be one ton running gear, 350 turbo, 205 case, 355c.i.
fast14 is offline   Reply With Quote
Old 01-28-2004, 09:28 PM   #3
67dragtruck
67dragtruck's Avatar
measure it
I think I would measure that lug pattern. A lot of ford 9" rears are actually 5x5. Don't know about the 70' f150. If you are unsure how to measure it PM me and I'll tell you how.
Tom
67dragtruck is offline   Reply With Quote
Old 01-28-2004, 09:41 PM   #4
67Fleetsidedream
Wiseass secured himself a BAN
67Fleetsidedream's Avatar
12 bolt rearends are just as strong. Why change?
67Fleetsidedream is offline   Reply With Quote
Old 01-28-2004, 11:25 PM   #5
junkyardjohn
junkyardjohn's Avatar
SURE .... I CAN'T IMAGINE WHY 99% OF DRAG RACERS USE FORD 9" AXELS??? THEY PROBABLY JUST DON'T KNOW ANY BETTER. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 01-28-2004, 11:30 PM   #6
dinnut
dinnut's Avatar
if youre going to race and such, ford 9inches are alot better and stronger.
from what ive heard, most 9 inches are 5x5
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 01-28-2004, 11:35 PM   #7
fast14
fast14's Avatar
You guys are probably right. The only stock nine inch i've ever messed with was a 5 on 5 1/2 and everyone was saying that that was a common bolt pattern. Thanks for correcting me. I use an aftermarket nine inch in my racecar now. As far as strength, the 9 inch usually is stronger plus if you break an axle in a nine inch it won't come out of the housing, the only was the wheel will come off is if you break it at the outside flange.
Just a little crazy
Old 01-29-2004, 02:42 AM   #8
PrimeredThunder
Back from the Dead
PrimeredThunder's Avatar
I asked my neighbor about why most racers uses Ford 9" rears. He said he used them back in the day because you could swap out a set of gears really fast if you had to. Or you could have two sets, lower gears for in-town driving and a set of highway mileage gears? Just my $0.02
The only Carb that matters to me is the one under my hood!
Salem, Oregon
PrimeredThunder is offline   Reply With Quote
Old 01-29-2004, 02:57 AM   #9
John Fabris
TOTY 2006
John Fabris's Avatar
Go get a ford 9 inch from a 70-75 Lincoln Continental. Look for the one with rear disc brakes, and it will have a lug nut pattern of 5 on 5. Gearing is most likely 3.00:1. That can be changed.
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 01-29-2004, 03:04 AM   #10
lost wages
lost wages's Avatar
i used the same kinda rear axle your looking at, they are a 5x5.5 pattern. I had to narrow mine and i also had moser axles made for it, i redrilled my own drums.
lost wages is offline   Reply With Quote
Old 01-29-2004, 03:38 AM   #11
1972C10
1972C10's Avatar
The late 70s 9 inch will have 5 on 5 1/2 and the axle from backer plate to backer plate will be like 60 inches its a tad wider than the chevy rear ends
9"s are great for the fact you can have two hog heads one wil full spool and super low gears for racing and one with a locker or posi for driving with decent gears.
Parts are cheap for them they really have alot goin for them
Might try to locate a 28 spline 9 inch there the perfect width for chevy trucks.
1972C10 is offline   Reply With Quote
Old 02-02-2004, 07:07 AM   #12
Javy
Javy's Avatar
A Ford 9" takes 5-8 more horsepower to drive than a 10 or 12 bolt
Chevy rear end !!!!!!
Javy is offline   Reply With Quote
Old 02-03-2004, 12:32 AM   #13
1972C10
1972C10's Avatar
Ive never heard that one before What would cause it to use more horsepower?
Old 02-03-2004, 12:38 AM   #14
69c10stepside
Large Member
69c10stepside's Avatar
pinion angle is what causes it..
1989 GMC C1500 ECSB
1972 Gmc Jimmy
1972 Chevy C10 SWB Sold
69c10stepside is offline   Reply With Quote
Old 02-03-2004, 01:43 AM   #15
onelow69
onelow69's Avatar
That is true about the Chevy rears, they take less horse power to use than the Ford 9in. Thats why most nascars use 9in housings and customs made 12 bolt center pumkins drops outs. Moser makes the center pumkins I beleive.
69 Chevy Truck, 350, 400trans, Lowered 3.5/6, Disc brake conv, All early classic stuff. 62 Chevy Nova 350, 700R4, 2400stall, F9in, 3.70gear, AlburnPosi, Chevelle Disc Brakes, ect.
onelow69 is offline   Reply With Quote
Old 02-03-2004, 02:03 AM   #16
1972C10
1972C10's Avatar
Ive seen them 12 bolt chunks in summit or jegs them things were high dollar
