Old 01-06-2015, 01:33 AM   #1
Chevys10dr
Chevys10dr's Avatar
4/7 Drop Tire size and bs
I have been looking and searching but couldn't find anything.
I have a 71 SWB with a Ridetech coilover setup which gives me a 4/7 static drop. It has a 12 bolt rear end. What is the max tire/rim size can I use, without rubbing or tubbing out. I read that you can go up to s 315 would fit but cant find anything on the backspacing specs. If anyone have a similar setup please post tire size and backspacing.
Thanks in advance.
Chevys10dr is offline   Reply With Quote
Old 01-06-2015, 02:17 PM   #2
c10Dream'n
c10Dream'n's Avatar
Re: 4/7 Drop Tire size and bs
I have an ECE 4/6 kit with a 1"block for the rear making it a 4/7. I have 17 x 8 American Racing TTII's with 255/55/17 on all four corners. I have no rubbing issues front or rear. The rear is c-notched.
c10Dream'n is offline   Reply With Quote
Old 01-06-2015, 11:53 PM   #3
Chevys10dr
Chevys10dr's Avatar
What backspace did you use? I like the idea of the 255 on front but was hoping to use 235 70/15 on front and 275 60/15 on the rear.
Old 01-07-2015, 09:59 AM   #4
c10Dream'n
c10Dream'n's Avatar
unfortunately I don't know the backspace. the truck had the wheels on it already when I bought it. sorry I couldn't help you out there.
Old 01-07-2015, 11:34 AM   #5
michael bustamante
michael bustamante's Avatar
im using 295-60-15 in the rears with 15x10 rims. 4.5" backspace
1967custom
michael bustamante is offline   Reply With Quote
Old 01-07-2015, 09:39 PM   #6
Chevys10dr
Chevys10dr's Avatar
No worries C10Dream'n just I have the same issue on my current setup.
Michael Thanks I was thinking that the 4.5 or 5 would be the bet fit.
Old 01-08-2015, 12:55 AM   #7
HSRACER
HSRACER's Avatar
These were 17 inch billet specialties 10 inch wide wheels with 5 inch back spacing and 295 70 tires on the back. Can't remember the front tire size but the wheels were 8 inch wide 17s
HSRACER
Slammed 53 5 window
Blown/Bagged 54 Pickup
Patinaed 67 LS stepside
Supercharged 67 Nova
Bagged 69 Suburban Turbo'ed 5.3 LS
HSRACER is offline   Reply With Quote
Old 01-08-2015, 01:16 AM   #8
Chevys10dr
Chevys10dr's Avatar
Both trucks look good.
Thanks to all that replied.
Old 01-08-2015, 07:42 PM   #9
Mike C
Mike C's Avatar
My truck is a stepside so a little less room in the wheel well, but I have 275 55 17 on 17 x 9 wheels with 5" backspacing. They fit well on the truck but I have the rear end blown apart so I haven't driven it yet, but with a fleetside you should have a TON of room for a much bigger tire than the 275. I have a leafspring truck with axle flip so about 6 1/2" lowering.
edit: the reason the rear is apart is I swapped in a '71-'72 wider axle because the 5" backspacing would not work with that wheel/tire combo on a stepside otherwise.
On the front I have 2 1/2" spindles, 2" springs and 235 55 17 on 17 x 8 with 4 1/2" backspacing.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 01-08-2015, 10:05 PM   #10
johnmiller66
Active Member
Mine has a ECE 4/6. 255/50/18 on the front and 295/40/20 on the rear. There is plenty of room for more tire on the back. I want a little taller tire on the rear to match up the sidewalls a little better. Sorry I can't remember the backspace.
johnmiller66 is offline   Reply With Quote
Old 01-08-2015, 10:27 PM   #11
Rod Run
Rod Run's Avatar
I am also enjoying the feedback in this thread because I am building a step side and want to use 17" wheels and plenty of you giving feedback are also using the same diameter wheels
______________________
www.northeastrodrun.com
Rod Run is offline   Reply With Quote
Old 03-08-2015, 08:46 PM   #12
Chevys10dr
Chevys10dr's Avatar
Anyone else? Decided to run 17x9 on back with 275/50 17 5" backspace.
But the front I am going with 17 x 8 255/50 17, Would the 4.5" work?
I did read that a few did go with that B.S but unsure what their drop is.
Old 03-08-2015, 09:04 PM   #13
aod92
aod92's Avatar
Chevys10dr can you post a pic of your truck with the ridetech set up? I have the same kit but still far away from installing it. Thanks
aod92 is offline   Reply With Quote
Old 03-08-2015, 09:05 PM   #14
SactoJim
SactoJim's Avatar
Here's Mine.....prob just a little lower than a 4/6
18's all around with 9.5's in back with 4.5" bs and 8's up front with 4.25" bs
72 Cheyenne SWB Fleet
Nut & bolt frame off in progress...99.9999%
- supercharged 383
- 4 wheel discs
- relocated fuel tank
My Build Thread
SactoJim is offline   Reply With Quote
Old 03-08-2015, 09:12 PM   #15
Chevys10dr
Chevys10dr's Avatar
Here is the best pic I have, its currently sitting on the wheel well. Its winter can't get out to finish. Cant wait til it warms up a bit.
Name:  Wood Buffalo-20140817-00125.jpg
Old 03-08-2015, 09:50 PM   #16
Chevys10dr
Chevys10dr's Avatar
BTW these are not the 255/50 17.
Old 03-09-2015, 07:13 AM   #17
Mike C
Mike C's Avatar
Here's a pic of my truck. Once again, a stepside which limits tire size. 275 55 17 on 17x9 with 5" bs in the rear. 235 55 17 on th 17x8 4.5" bs front.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 01-27-2019, 08:51 PM   #18
jgmc
What size tires?
jgmc is offline   Reply With Quote
