Old 03-19-2015, 03:52 PM   #51
smbrouss70
smbrouss70's Avatar
Re: Looking for 1970 St. Louis VINs for Chevy Trucks built Jan/Feb/Mar '70
I have another 2wd Blazer tub that is pretty messed up and I looked at the VIN tag the other day and it's VIN is CE180S146997. I wish I had the original doors for it since it is so close to your VIN, but they were long gone before I found it.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 03-19-2015, 04:33 PM   #52
IronCanine
I'm trying....
IronCanine's Avatar
Originally Posted by briank View Post
It is actually 101000.....thats not the 1st one built is it. I only have a droid and cant figure how to post since I got rid of my computer. I can text the picture to you if you pm your number and you can post it.
I don't know how you would know for sure, but it is conceivable to me that they could have started at 101000. Does anyone have a lower numbered or August built 1970 model truck/Blazer?...if not....maybe you have the first 2wd Blazer built in St. Louis.
...Keith please chime in and tell me how I'm absurd to suggest he's got the first 2WD BLAZER OF ALL TIME!!!!!!!!
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076
1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352
1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290
1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555
"Sometimes I wonder if zander208 was even real..."
IronCanine is offline   Reply With Quote
Old 03-19-2015, 04:40 PM   #53
bruceman1968
bruceman1968's Avatar
Iron, it's just number 1000 to be assigned a build sequence number at St. Louis in the 1970 MY, and it happens to be a Blazer. 1970 MY build sequence numbers start at 100001, with the first number assigned, and go up from there.
CHEVY/GMC VIN DECODERS
bruceman1968 is offline   Reply With Quote
Old 03-19-2015, 04:44 PM   #54
IronCanine
I'm trying....
IronCanine's Avatar
I get that. My question is did they start at 101000 or 100000 at the beginning of the MY in St.Louis?
Old 03-19-2015, 04:54 PM   #55
IronCanine
I'm trying....
IronCanine's Avatar
I wish you did too...that would totally put an end to this thread.
Old 03-19-2015, 05:09 PM   #56
briank
Mines a 4wd, should have said that to begin with.
briank is offline   Reply With Quote
Old 03-19-2015, 05:14 PM   #57
IronCanine
I'm trying....
IronCanine's Avatar
Well Gee Whiz...you sure know how to let the air out of the balloon...
Old 03-19-2015, 05:31 PM   #58
bruceman1968
Iron, They started at 100001. The first truck built/assigned was number 100001, so his blazer is the 1000th truck/vehicle to be assigned a sequence number at St Louis in 1970 MY.
Old 03-19-2015, 05:46 PM   #59
Keith Seymore
Keith Seymore's Avatar
Agree.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 03-19-2015, 09:09 PM   #60
IronCanine
I'm trying....
IronCanine's Avatar
Originally Posted by Keith Seymore View Post
Agree.
K
Thanks guys. Round numbers are cool though aren't they. At least this ole thread heated up for a few minutes this afternoon. Nothing wrong with that.
....more VINs please
Old 03-19-2015, 09:36 PM   #61
bruceman1968
Yes, round numbers are cool, very cool. I have been checking numbers for you once a week. I haven't found anything that helps yet. But I did find a (0S) door sticker that was after 157xxx. 0S167532 5/70, No help, but sooner or later one of us will hit a number between 1389xx and 155xxx that will help. You have done a great job narrowing it down using your dash pad, gauge cluster, and transfer case. Have you checked the code on your rear axle. If original, it will have the month and day on it. Not definitive but it will add some info.
Old 03-19-2015, 10:46 PM   #62
factorystock
factorystock's Avatar
Would it be safe to assume 100011 would be the 11th truck built, on the very first day of production?
factorystock is offline   Reply With Quote
Old 03-19-2015, 10:55 PM   #63
bruceman1968
In short.. yes
Old 03-20-2015, 08:50 PM   #64
IronCanine
I'm trying....
IronCanine's Avatar
Thanks bruceman...I really appreciate that. Gosh this board is a helluva group of guys. My rear axle is the original 3.07 and was built on January 7th. Right in line with everything else...but in no way definitive....If it had been built in February, you might could call the ball...but it was built closer to St.Louis than the TC was....so could theoretically easily made it onto a January truck.
...kind of neat to think about trains coming from New York, New Hampshire and Michigan in late '69 and early '70 to build her. Pretty much the same thing UPS is doing for the old girl in '14 and '15.
Old 03-20-2015, 10:08 PM   #65
Keith Seymore
Almost.
Keep in mind if there were other nameplates with separate VIN sequences inserted in there that would push it back a job or two (so maybe number 13 or 14, allowing for a couple GMCs in there).
Additionally, it might take a full day to build the first truck only, as production problems are ironed out or material issues overcome. Then the next day goes better, and you continue to ramp up as things smooth out.
Probably not on the first day, but no way to know for sure unless you were there. Definitely very early, though.
K
1979-1986
1986 - 2019
Old 03-31-2015, 09:43 PM   #66
IronCanine
I'm trying....
IronCanine's Avatar
Numbers update:
September 102XXX
October
November 122XXX
December 1389XX
January
February
March 155XXX, 157XXX
April
May 167XXX
Still on the hunt for some January and February numbers...
Old 03-31-2015, 10:46 PM   #67
68shortwide
68shortwide's Avatar
Still havnt been able to check the parts truck or extra doors. Hopefully next weekend it comes home.
Jack
Personal Fleet: Family Fleet:
1955.5 Panel 1959 Apache
1968 ShortWide
1969 ShortStep
68shortwide is offline   Reply With Quote
Old 04-01-2015, 06:24 PM   #68
ChevyGuyX2
My Truck was MFD in June of 1970.
ChevyGuyX2 is offline   Reply With Quote
Old 04-01-2015, 07:56 PM   #69
IronCanine
I'm trying....
IronCanine's Avatar
What are the first three digits of your six digit serial #? We'll add it to the list.
Old 04-01-2015, 08:06 PM   #70
ChevyGuyX2
Originally Posted by ironcanine View Post
what are the first three digits of your six digit serial #? We'll add it to the list.
173.
Old 04-01-2015, 08:50 PM   #71
IronCanine
I'm trying....
IronCanine's Avatar
173.
Thanks.
Numbers update:
September 101XXX, 102XXX
October
November 122XXX
December 1389XX
January
February
April
May 167XXX
June 173XXX
Old 04-01-2015, 09:04 PM   #72
ChevyGuyX2
Originally Posted by IronCanine View Post
Thanks.
Numbers update:
September 102XXX
October
November 122XXX
December 1389XX
January
February
April
May 167XXX
June 173XXX
In September of 70 would be the start of the MFD for 71?
Old 04-01-2015, 09:14 PM   #73
IronCanine
I'm trying....
IronCanine's Avatar
Yep...maybe some August.
Old 04-01-2015, 09:20 PM   #74
ChevyGuyX2
I guess that makes my truck a late 1970. Then again they did make alot of these trucks.
Old 04-01-2015, 09:36 PM   #75
factorystock
Yes, however production of early '71's was cut drastically by the last big UAW strike, 400,000 workers walked off the job in Sept and Oct '70.
