#1276 |
Re: Restoring Rusty
For some reason I read that as "a can of wine". It's a Tuesday after all.
Actually I like that idea. For us dignified hooligans that want to join in with our friends, swilling booze, but have a refined palette!
2012 Chevy 2500HD, 6.0L, 6spd auto, 4x4, ECSB 1987 GMC V3500 Dump, 6.2L diesel, TH400 1983 GMC K2500 - awaiting its restoration and Cummins swap. |
#1277 |
Re: Restoring Rusty
You might want to check and make sure your brake lines in back are good. I had a bad brake hose up front once and it would lock up the front caliper. Thought it was the caliper but it was the hose. Live and learn. Well if you're in a funk take the day off and enjoy a cup of joe. It'll all clear out.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
#1278 | |
Re: Restoring Rusty
#1279 |
![]() Join Date: Aug 2014
Re: Restoring Rusty - Hood Hinges
figured I would show off my hood hinge exercisers aka the Pro Mark 3000 Plus while I build up the primer coats to sand down on the hood (in the background)
now I'll admit it I'm not strong enuff to manipulate those darn hinges by hand so I had to turn to Physics, anyway I lubed them up with some White Lightning Grease so I wanted to open and close them a few times to work that in |
#1280 |
Re: Restoring Rusty
for the life of me couldn't get the 4 amp fuse out of the black wire that runs from the bulk head connector box to the starter without breaking it in half and having both ends end up stuck in the black rubber fuse holder
add to that the fact that my Parts Houses carry (and I kid you not) 1, 2, 3, 5, 7.5, etc. fuses and not a 4 amp one, and I decided to punt on the mini glass tube style and replace it with a manly PINK flat blade one did the same for the black and white AMETER wire spliced those in with some wire crimpers and those blue chinese hancuff looking connectors |
#1281 |
Re: Restoring Rusty
Basic physics principle: w=fd
work=force x distance |
#1282 |
Re: Restoring Rusty
decided the fusible link has seen better days so snipped that out, need to go back to O'Reillys armed with a part number this time to get a replacement, I recon this 16 gauge one will do the trick
Dorman Conduct-Tite! - Fusible Link Wire Part # 85621 http://www.oreillyauto.com/site/c/de...0220&ppt=C0172 |
#1283 |
Re: Restoring Rusty
Learning the hardway that build primer is for filling tiny little scratches and not pitted metal from years of rust - for that you need to shmear the surface with bondo I recond, a job I refuse to do so primer + paint will have to do, hope to shoot the paint tomorrow
painting this heavy huge hood is proving to be a bear as I do the tango with it in and out in and out of the garage so I don't pass out from the fumes and or get sanded dust all over my pristine garage, LOL |
#1284 |
Re: Restoring Rusty
Glad to hear you're still banging away, Greg.
Greg 64 GMC Suburban - 283, NV3500, 14 bolt 77 C10 swb - 292, SM465, 12 bolt |
#1285 | |
Re: Restoring Rusty
![]() Great work....always wondering when greg is going to give us another update...lol |
#1286 |
Re: Restoring Rusty
#1287 |
Re: Restoring Rusty - Hood Braces
got more goodies from LMC truck this time it was the braces to get rid of the kink in the hood, cost about $20 bucks, friends said make your own, I figured what the heck I'll try these
so I primered them then painted them black last pick shows me installing them on the hood off the truck have not mounted the hood back on yet so I can't tell you if they work or not, will do so in a later post |
#1288 |
Re: Restoring Rusty - Painting The Hood
block sanded the hood of the car a bit in preparation for paint and figured this is as good as it is going to get
picked up 8 cans of paint for $130 bones, six perfect match glossy finish, and two with some flat clear mixed in since the truck is 40 years old and no longer glossy to use as clear coat daughter is out of town, so the swing set is mine |
#1289 |
Re: Restoring Rusty
I've been meaning to get some of those hood reinforcements. Mine's not bad at all, but there is a slight bow to it. Hinges can be a bear for sure unless they're looooobed.
- 1981 Sierra 454, NV4500 swap - 2006 Z06, 25k miles - 1973 Nova - Project CarNova Virus on Youtube |
#1290 |
Re: Restoring Rusty
ok so lets run through the hood painting or I should say stripping (jk) process
here it is wiped down with Denatured Alcohol ready for the first coat |
#1291 |
Re: Restoring Rusty - Hood: First Coat of Paint
first coat of paint on the hood, same as always one spray can = one coat
#1292 |
Re: Restoring Rusty - Hood: Second Coat of Paint
yes I did pick the windiest day of spring to paint
second coat, second can |
#1293 |
Re: Restoring Rusty - Hood: Third Coat of Paint
at this point I was seriously considering doing a Watermelon theme the tiger stripping was so bad, worst in my entire career, LOL
#1294 |
Re: Restoring Rusty - Hood: Fourth Coat of Paint
I recalled painting houses with my daddy when I was a boy and we learned that the best way to hide imperfections was with more imperfections, so I may have gone up and down on this fourth coat if not on the third one already instead of side to side
#1295 |
Re: Restoring Rusty - Hood: Fifth Coat of Paint
I may have shot the fifth coat of paint diagonally, again to get rid of the stripes / checkered board
#1296 |
Re: Restoring Rusty - Hood: Sixth Coat of Paint
six coat of paint went on diagonally opposite of the prior coat as if I was painting an X on the hood, hey you gotta do what you gotta do
this was the last coat of 4 oz of paint, you see the paint shop can only add about 4 ounces of actual paint into their aerosol cans which already contain some magical potion to mix it with this is what we are learning along the process, so about a cup of paint goes into an aerosol can, so I did 6 cups so far Last edited by Gregski; 03-28-2015 at 06:01 PM. |
#1297 |
Re: Restoring Rusty - Hood: Seventh Coat of Paint
ok, the last two cans are a bit different (the truck is no longer new so the paint has flattened out and lost it's shine)
the final two cans only contain 2 oz of actual paint mixed 1:1 with 2 oz of some flattening clear you can not buy flat clear in an aerosol can for automotive use, the stuff for your home is a different kind of paint, is what The Greg has been told so this shop is winging some one off formula for me |
#1298 |
Re: Restoring Rusty - Hood: Eighth Coat of Paint
OK, 8th and final coat of paint, same as the last one
2 oz of paint plus 2 oz of flat(ish) clear guys if you catch me telling you lies, please correct me, I am no authority on painting by any means, I am just sharing what I am learning and hoping to help some folks out bottom line, good paint aint cheap, good paint jobs aint cheap, and they are massive amounts of prep work to do it right, that's probably why they cost so much apologies for the shadows, naturally my paint job was interrupted by having to drive a kid across town to a function, I bet Foose can't paint a hood while playing taxi driver, LOL |
#1299 |
Re: Restoring Rusty
#1300 |
Re: Restoring Rusty
Hood looks pretty good to me, Greg! Could you get the front edge properly with it hanging in that orientation? I would have thought it would be easier to spin it 180 degrees. So now the hood will match Rusty's new front fender.
