03-21-2015, 02:07 PM | #1 |
6.5 turbo diesel into a 72 C20
Hi All
I'm in the planning stages on putting a 6.5 Turbo diesel into a 1972 GMC C20. I don't have either truck here but I'm looking for some advice. I have been reading mostly this forum, and I think I'm overloaded with info. This isn't going to be a project truck right now so I chose the 6.5 to go in asap on a budget with minimal mods. I like the option to put it back to the 350/350 for resale as the 6.5's don't seem to be attractive for buyers. If I had the time and money, i'd love a duramax, but that will have to wait. In the meantime, I'm looking at a 96 reg cab long box RWD for the for the engine and tranny. I'll need to take the parts off the 96 before the 72 gets here and I was just trying to determine what parts I should pull off the 96 before send it to the scrap yard? The second question I have is do I need to convert to a mechanical injection pump? I'm sure i'l have more questions, but I may need to reply on the forum to even figure out what they are. Thanks, Chris |
03-22-2015, 11:35 AM | #2 |
Re: 6.5 turbo diesel into a 72 C20
96 is obd2 a lot of hassle to swap and as far as tuning limited. If you go mechanical you cant use the trans because it is a 4l80e and it is computer controlled. I would just use the motor and change it to a mechanical pump as you are just looking for a easy swap. The 6.5 will bolt to any sbc trans be sure to use a 6.5 flex plate or flywheel. The same engine mounts for a sbc fit the 6.5.
1976 k20, 350 built, 44/14 axles 1968 c10 6.5 turbo diesel,t5 trans 1977 gmc c3500 dually, crew, 4-53t, 5&3 trans http://67-72chevytrucks.com/vboard/s...d.php?t=591188 |
03-24-2015, 07:44 PM | #3 |
o'blazer - Thanks for the chat, I may be able to pull this off afterall.
marvgarr68 - Thanks for the info, from the looks of my search results, the cost to make the 4l80e standalone is more than it worth. Now I just need to come up with a plan. But first I need to pick up the trucks. Chris |
03-24-2015, 07:49 PM | #4 |
You might be able to make the money back for the controller by selling off parts from the 96.
03-24-2015, 07:52 PM | #5 |
Good point but if I cut a deal with Tyler I won't feel bad about bugging him with stupid questions.
03-31-2015, 10:38 PM | #6 |
After reading the threads on 6.2 swaps it looks like I need SBC motor mounts and BBC towers/frame mounts. Of course there are 3 kinds, 67 to 71, 72, and 73 to 80something. Of course I have a 72 and they seem to be sought after. My question is what's the difference as a few posters have said either the 67 to 71 or the square body towers could be used with minor modifications.
Chris |
04-01-2015, 12:20 AM | #7 |
Have you read my build? I thought I covered that in it with pictures I will have to go through it and make sure.
04-01-2015, 12:21 AM | #8 |
I just noticed my build is missing from my sig. I will get that fixed.
I just got it fixed
04-01-2015, 05:12 AM | #9 |
That's a great build thread. When I first read it, I think I was just getting too much information and did not understand the modifications to the sbc stand. How's it holding up with time? I can understand why you wanted the engine lower with the sbc stands, but why didn't you want it moved forward? I would have thought that would help with clearance issues with the downpipe, and help to reduce heat transfer through the firewall?
04-02-2015, 02:29 AM | #10 |
I needed clearance between fan and radiator. In my build you can see the fan spacer which is less then 3/4" in length. The reason I had to run a spacer is so fan blades would clear the accessories. These motors are a little long. I have plenty of room behind engine and firewall. Down pipe is also fine even with a filter behind it. I have not got it on the road yet. I have only just started it for the first time a couple days ago. I can tell you it is very solid.
