Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 03-30-2015, 10:38 PM   #326
72K5CSTDarkOlive
72K5CSTDarkOlive's Avatar
Re: Attempting my first build 72 K5
Originally Posted by tjsblazer View Post
The new tank looks great. What was the finish on it before you painted it?
Thanks TJ. I liked the way color came out on it. It was raw steel. I ordered through Brothers Trucks.
My Build Thread 72 K5 http://67-72chevytrucks.com/vboard/s...d.php?t=628612
Build version 2.0: 72 K5
6.0 LQ9, 4L80e, NP205
http://67-72chevytrucks.com/vboard/s...d.php?t=793192
1972 CST K5 Blazer Dark Olive
72K5CSTDarkOlive is offline   Reply With Quote
Old 04-08-2015, 12:47 AM   #327
tjsblazer
tjsblazer's Avatar
Hey Mike, when you ran your new brake and fuel lines did you have all the frame x-members in or did you put the lines in first and then all the x-members ?
Jeff.
'72 Blazer K5
"Camshaft opinions are like belly buttons; everyone has one and no two are alike"
My Blazer Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=626752
My Engine Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=637336
tjsblazer is offline   Reply With Quote
Old 04-08-2015, 01:10 PM   #328
72K5CSTDarkOlive
I had all the X-Members in prior to installing the lines. I'm not sure if it matters, but one thing I might be worried about if I installed the lines first is if I accidentally bashed or smashed a line trying to get the X-members in... The Fuel and Brake line run a long the top/bottom of the Transmission X-member if that makes sense.
Check out my pictures before I tore it all down. This is a link to my drop box account with about 41 photos. I made annotation marks what line was what to help make it easier for any to use as reference.
https://www.dropbox.com/sh/wtwaauas8...Uy2NjZQQa?dl=0
Here are after pics
https://www.dropbox.com/sh/hayh08lia...U1vrvpX2a?dl=0
Old 04-08-2015, 06:21 PM   #329
1972 Jimmy
1972 Jimmy's Avatar
Here are after pics
Your build is looking Great! Awesome detail in the pics. This will help me out alot when putting mine back together.
Eric
1972 Jimmy is offline   Reply With Quote
Old 04-09-2015, 12:04 PM   #330
72K5CSTDarkOlive
Thanks Eric.
I'm not sure if this is 100% correct as it came from the factory. I used my old pics to reference putting it all back together. I think 72's might also have a slight difference with the rear brake line compared to the 69-71 models. Plus Jimmy's might be different, too so you might want to look into that. Before you make your final orders/purchases make sure you do just that little extra home work before finalizing your orders so you don't piss any money away.. Ask me how I know lol
Old 04-13-2015, 05:21 PM   #331
tjsblazer
tjsblazer's Avatar
Mike, one more question on your fuel tank neck swap. I took my new and old tank to the repair shop to swap necks as you did. The tank is probably from the same manufacturer as yours. It was a galvanized metal. Around the neck area where they had fastened it they had sprayed some grey paint on it.
I guess the new tank has the neck Brazed on where as the originals are just Soldered. The tank shop says they will have to heat the new tank around the braze fairly hot to remove it and are worried about warping. Is this how your tank removed the new neck, just by heating it up to remove the braze? Was there any issues with yours?
Thanks for any insight.
BTW, I followed your steps for fastening the front ball joints and knuckles. All good first time around. Thanks very much.
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 04-13-2015, 11:18 PM   #332
72K5CSTDarkOlive
The guy said he cut the old neck out with a small cutting wheel and same with the new one and then soldered it on the new tank. He didn't have to heat anything up. Then he sealed and lined the tank. Mine didn't have any gray pant on it. The entire tank was raw steel galvanized metal.
Where did you get your tank from?
Glad to hear the ball joint sequenced worked the first time you did it. I wish I could say the same
Old 04-14-2015, 11:14 AM   #333
tjsblazer
tjsblazer's Avatar
I got mine from Wes at Classic Heartbeat. Sounds like you had the neck cut off and swapped at the base as opposed to unbolting and removing the entire base. Might be the way to go.
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 04-14-2015, 10:50 PM   #334
72K5CSTDarkOlive
I'll ask him tomorrow if he cut it off at the base to confirm and I'm sure he did because the bolts wouldn't have looked new.
Old 04-14-2015, 10:55 PM   #335
tjsblazer
tjsblazer's Avatar
Thanks, I'd appreciate knowing.
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 04-14-2015, 10:58 PM   #336
72K5CSTDarkOlive
Made some more progress last weekend.
Installed the gas tank.. jeez that thing was PIA just figuring out what parts I needed and costly, too
Old 04-15-2015, 10:13 AM   #337
Dirt's72
Looking good! I'll send mine out to you when you're done. Can you weld?
Dirt's72 is offline   Reply With Quote
Old 04-16-2015, 01:08 PM   #338
72K5CSTDarkOlive
Thanks! I'm a one man shop.. so It might take a while. I just started welding and here's my first go at it ( don't laugh to hard)
The Passenger side inner fender was rotted pretty bad at the front.. It's literally impossible to find a used replacement in good shape. I bought a driver side and cut the front lip out to replace the front lip on my original one. The caveat is you just cant simply do a straight line cut and swap it because the outer edges and holes are not the same. You have to cut those off, too. Then weld them on the opposite side of replacement piece. You also have to plu he center hole and then drill a new hole about 1/2" to the right in order for it to line up. I don't know if any of this make sense to you, but I can tell you it's very time consuming.
Old 04-16-2015, 06:25 PM   #339
jaros44sr
jaros44sr's Avatar
Once you grind it down, no one will know. Great work on your build, glad you got past the fuel tank fiasco
Nice KTM
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 04-18-2015, 10:53 AM   #340
sockalaminski
Jaros44sr is right. It'll be fine once it's ground clean. Use a hard disc to knock off the high points and a sanding disc to smooth it out.
sockalaminski is offline   Reply With Quote
Old 04-21-2015, 03:18 PM   #341
72K5CSTDarkOlive
Am I missing something here?? The bottom of Transmission Tail shaft has two threaded holes.
Old 04-21-2015, 04:44 PM   #342
sockalaminski
Nope, you're all good. That's where the mount would be if it was in a 2wd.
Old 04-24-2015, 05:41 PM   #343
72K5CSTDarkOlive
Installed the engine yesterday. My dad's friend who is a mechanic came over to oversee and make sure I didn't screw anything up..We got the engine installed in less than 2 hours.
Old 04-24-2015, 05:44 PM   #344
72K5CSTDarkOlive
more pics
Old 04-24-2015, 05:47 PM   #345
72K5CSTDarkOlive
AND THEN
Wait For it
Wait for it
The pass side header is just barely touching the shackle.. I'll have to see if my original shackles are not as thick as the ORD ones. Would anyone know if a muffler shop could bend the header just enough to clear the shackle?
Name:  Header hitting shackle close up.jpg
Name:  Header hitting shackle.jpg
Old 04-24-2015, 06:44 PM   #346
DeadheadNM
Carpe manana
DeadheadNM's Avatar
#1 - Motor looks bad a$$
#2 - Bummer about the header
Old 04-24-2015, 07:09 PM   #347
IronCanine
I'm trying....
IronCanine's Avatar
Mike...that looks awesome. I hope you're gonna install 6-point harnesses, because that thing looks like it's screaming just sitting there cold. Great job!!
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076
1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352
1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290
1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555
"Sometimes I wonder if zander208 was even real..."
IronCanine is offline   Reply With Quote
Old 04-24-2015, 09:27 PM   #348
sockalaminski
Tough break on the header touching. That's why I hate headers so much. The drive train looks fantastic though. I think your quality blows mine away.
Old 04-24-2015, 09:45 PM   #349
72K5CSTDarkOlive
Thanks guys.. I'm happy with the look of the motor and all, but the headers are killing me and putting me behind schedule.. I need to have everything back together before we're ready to put the body back on the frame which is in about 6 weeks.
I can almost guarantee these headers are for 2wd only, even though it says 2wd and 4wd right here - http://www.dougthorley.com/prod-9.htm
When I ordered them I thought these were for 4WD specific. If I had read that it said 2wd or 4wd I think I would have held off and not pulled the trigger so quick.
I'm going to call them on Monday to find a resolution to this because A. I didn't modify my engine or transmission or height of the truck. It's all stock.
If they would just angle the end of the tube a 1/4" to the left it would be fine, but I guess that's to much for them to understand.
Old 04-24-2015, 09:51 PM   #350
72K5CSTDarkOlive
Other option I was thinking is cutting about 1-2" off the end of the collector and welding a new collector piece on there to make it clear
