#201 |
Re: My 1961 crew cab- XRMYCRU
That's impressive work. Looking forward to seeing this one on the road.
"Always try to make the best part you can with the skills you have. If it isn't good enough throw it away and make another. Every time you make a part your skill will increase and you'll make a better part than you were capable of making before." Lil John Buttera |
#202 |
1961 crewcab
point of no return #5!
I decided to replace the inner and outer upper windshield panels. there was a spot where a mouse nest had been and both pieces had pin holes all through them. after I got the windshield out and ran the wire brush on the grinder over the area, even more appeared, so I am glad I decided to replace this piece. I ended up using the panels off a 66 roof that I had cut off. some studying showed 4 spot welds in the pinch weld, and 1 (2 on the 61) on the sheet metal on each side. the 4 spots hold it to the "U" shaped brace, and the 1/2 are for the tab that comes off the top of the door jamb piece. there are no welds in the seam, but the little joiner clip between the rain gutter for the side to the front has about 3 spot welds on the bottom portion- it was pretty much impossible to remove this clip without destroying it.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
#203 |
1961 crewcab
I marked all the roof spots on the rain gutter from the bottom so that they would be easier to find on the top.
the patch panel is now ready.. I took this opportunity to drill out and mount the passenger visor as well. clamping it in and measuring... I pulled it in and out 3/4 times to get the inner panel trimmed and fitted, I cut the patch big, and the body small, and then marked the best fitting spots to trim, and then finally clamping the 2 panels together and cutting through both at the same time to get a nice uniform cut to weld up.
#204 |
1961 crewcab
all ready to go, I tacked it in a couple spots, and I will set the windshield back in the opening before I finalize the fit and weld it up.
** another reason for the inner panel replacement -vs- trying to save... you will notice where the coach builders cut out the headliner (with a torch!!), they left about 2 inches from the edge of the ridge, that gave them a spot to mount the cardboard inner headliner...well when I cut the headliner out of the orange cab I cut right on the edge and didn't leave the extra metal to mount the headliner... this new panel fixes that- **another note the outer upper windshield panel is the same 60-66, and will work- the patch panel that is being sold is only listed for 64-66, but it will work on all years. the inner panel is different, but only on the corners, where the different year windshields go in different directions... so if you trim inside the posts like I did the inner patch panel that they sell can be made to fit on all years as well.
#205 |
Wow.....wow.
#206 |
SAVING ONE TRUCK AT A TIME
![]() Join Date: Feb 2010
Progress is looking great.
53-suburban (99% done) 40-pick up (99.9% done) 12-cc lb dually D-max (dd) 61-crew cab D-max "PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT" 53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091 1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088 1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999 |
#207 |
1966 Crew Cab & 4X4 Fanatic
Great fab skills! Looks great, can't wait to see this once all the sheet metal is complete.
#208 |
1961 crewcab
grinding welds.... lots more of this to do!
#209 |
1961 crewcab
got the roof all fitted, had to get creative with the vise grips!
used some sockets, some nuts, and some other stuff that was laying around to fit in the gutter- I am going to have to stop by harbor freight and get 2 more boxed of these clamps... as it is now all clamped in it has stiffened up pretty nice, and for the most part it is all straight and smooth. this is about the 5th time I have had this piece all clamped up, we didn't roll it enough at the metal shop, so it was laying flat on the driver side. At first I didn't even think the piece would fit, but after I got it trimmed down , and used the oxygen bottle a couple times as a cheap substitute for a roller it is fitting pretty nice. so now I have to take it off one more time, I might roll it on the oxy bottle just a tiny bit more in a couple spots, then I have to prime in side and under the skin and get the drip rail all cleaned up so I can either weld or glue it down on the edges. ha! I had one of the kids helping with the clamps, and I noticed he tagged the window cover! ![]()
#210 |
Roof panel is looking good. wow lots of work getting that panel to align. Are you going to tig that in?
#211 |
Really admire the amount of work and fab on this project. Looking great!!!
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
#212 |
The 60-66 GMC/Pontiac guy....
One day...
I'll have a big cab too.. One day
![]() Building Genuine Pontiac Firepowered cars and trucks for several decades. ![]() Why Pontiac?? That's just me daring to be different. ![]() Projects.. 63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction. 440CID 2X4 Pontiac ![]() |
#213 |
Very Impressive. What are the small bits of square tubing / clamps? Not sure I have seen them before.
Again, very impressive build. |
#214 |
WOWSERS!!!
So amazing! I'm late, but I'm all in!
#215 |
+ or - .060 would make or break that roof panel , great work !!!
#216 | |
1961 crewcab
thanks for all the compliments!
it is coming along... not a lot done this week yet, I took the roof back apart, and now will do a few final tweaks on the metal to get the shape right, then I have to prep around the work area. I am going to glue the roof panel to the drip rails, this will cut down on the welding, but more importantly put another barrier between moisture and the inside-with the glued panel, and the seam sealer, it should be watertight. Quote:
her is a pic of one in action-
#217 |
That's gonna look good when you finish it
#218 |
This thread just got really interesting. I'd like to know what kind of "glue" that is you are using. I am all for water tight but glue the panel on? That surprised me.
#219 | |
1961 crewcab
![]() its is called lord fusor panel bond, 3m makes a similar product- here is a short video:https://youtu.be/LXRoiFXw2ms
#220 |
Hope I'm not too late.
Congrats and glad to see this one saved. Sub'd |
#221 | |
#222 |
1961 crewcab
me too, the guy I work with has done a # of them and did not have any problems not spotting them.
#223 |
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
First thread I've ever subscribed to. I've been missing out on a lot of progress.
substitute rear door hinge link http://www.snydersantiqueauto.com/door-hinge-28-9-truck G Van rear barn door hinge 73-90? Very close except for the bends.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 Last edited by aerotruk63; 04-29-2015 at 06:23 PM. |
#224 | |
1961 crewcab
still keeping my eye out for what the coach builders used... that model a hinge looks similar to a hinge that was used on a different style crew. been quiet over here: I got my crossmember taken apart and ready to pancake, pulled the short step bed off the donor truck, and pulled the lh fender and step off of that for rust repair... also got the frame stripped down and ready for modifications. for some reason on most 60-66 short steps that I have seen the rear wheel looks too far back in the fender. I set a tire up next to the wheel well and moved it forward a little until it looked right, it looked to be about 2 inches forward... after I got the bed unbolted I slid it back until the tire & wheel looked right in the opening, then I measured the difference on the mounting points, again I got 2 inches. so the crew is a 30 inch stretch, added to a swb truck, I get a 145 inch wheel base. the frame I am using is a 133 inch 1 ton model, so I should be able to slide the leaf springs back 10 inches and have it look just right. I will also slide the front crossmember forward 1 inch to compensate for the lowering, so the final wb. will be 144....
#225 |
1961 crewcab
productive day, spent it out at the yard (mine) gathering parts.
I had a whole group of parts picked out, but then I decided to use the 66 frame, so I had to use a different grille support, and bumper, and then since I had one, I decided on the 63-66 V8 radiator instead of the 61 6 cylinder one that I had. I got the whole front clip pulled and in pieces , luckily it was mostly all of one truck. then went on a walkabout to pull some little stuff, checked 10 trucks and finally found 1 (only 1!) battery tray; did the same for the front bumper and braces, and then sorted out 3 different hood 61 hood latches to find one that wasn't bent up or cracked. I kept having to prioritize which parts to use, I am saving 1 more good set of parts for my 65 2wd suburban, so for now that was getting all the second best stuff ![]() I got the left fender and step on my short step bed pulled and ready for rust repair (I'll be using a different fender, but even that one needs rust repair!)
