Old 04-16-2015, 04:19 PM   #1
flipper58
flipper58's Avatar
Need some help. WTHIT?
What the h... is that? By "that" I mean the the 2 holes and plugs in this firewall just to the left of the heater core cover. Both look improvised and one looks like a cork. Really. Any help would be appreciated.
And for the title of this thread, I used this old SNL skit for inspiration.
https://www.youtube.com/watch?v=RV7Qz640OeM
Thanks,
Phil
flipper58 is offline   Reply With Quote
Old 04-16-2015, 04:24 PM   #2
Sklptrljay
Sklptrljay's Avatar
Re: Need some help. WTHIT?
Really hard to see on my phone, but I'll guess they're plugs for an old aftermarket a/c.
1971 C/10 SWB, 15x8 Rallys, 4.5" X 7" static drop, C-notched, 350/350, 3.73 Posi. .........A 383 and Gear Vendors are on my bucket list.
1972 GMC 4X4 K1500 Survivor - Sold
No matter what problems life throws at you, your time on Earth can be incredibly fulfilling and rewarding.....if you just lower your expectations. -Phil Dunphy
Sklptrljay is offline   Reply With Quote
Old 04-16-2015, 04:36 PM   #3
7tee
7tee's Avatar
These are your heater core hook ups for the heater inside. The heater core may be bad and they've just plugged it off...
7tee is offline   Reply With Quote
Old 04-16-2015, 05:10 PM   #4
leftybass209
leftybass209's Avatar
Those are definitely part of a PO hack job, possibly to install an add-on A/C system. Either way, that cork is one way to plug a hole!
leftybass209 is offline   Reply With Quote
Old 04-16-2015, 05:22 PM   #5
SS Tim
SS Tim's Avatar
Former underdash A/C hose holes, very common.
SS Tim is offline   Reply With Quote
Old 04-16-2015, 06:28 PM   #6
justin4260
justin4260's Avatar
my truck has these holes (not plugged) and never had a/c?
justin4260 is offline   Reply With Quote
Old 04-16-2015, 06:37 PM   #7
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Need some help. WTHIT?
Those are where the factory heater hoses would go on a factory AC truck. If they are not being used then I would get them out and plug up the fire wall. A dealer add on AC would explain them also.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 04-17-2015, 11:12 AM   #8
flipper58
flipper58's Avatar
Thanks guys. As always, this forum has the answers. I'll work on upgrading the cork.
Phil
