04-06-2015, 07:50 PM | #151 |
Re: My suburban's Twisted Little Sister
Thanks reaper.
We got the two inch strip tacked in place to lower the wheel opening. We finally got the Easy Grind mig wire today so we can start welding the body panels back together later this week.
Dale ---------------- My suburban's Twisted Little Sister http://67-72chevytrucks.com/vboard/s...d.php?t=655167 |
04-09-2015, 03:29 PM | #152 |
We finished the welding on the two inch strip yesterday. Today we got started on the body panels. We started on the passenger side. The seam took some massaging to get it to line up. i guess the factory allowed some variation from front to back.
04-09-2015, 09:23 PM | #153 |
Lookin good!
1967 C10 Suburban 454/TH400/3.07's An Average Joe and His 'Burb: http://67-72chevytrucks.com/vboard/s...d.php?t=775843 |
04-09-2015, 09:36 PM | #154 |
Nice alignment on that panel. Will come out nice!
04-13-2015, 08:14 PM | #155 |
Thanks Joe
Thanks A.D. The General didn't build this thing exactly the same from front to back so we had to do some more work to make it line up. See today's pictures. We had to make a horizontal relief cut in both drivers and passenger sides
04-16-2015, 07:44 PM | #156 |
Here's the passenger side welded and cleaned up.
04-16-2015, 08:02 PM | #157 |
04-17-2015, 01:55 AM | #158 |
Your work continues to just have me grin and shake my head.
You guys really are so far up that curve. Amazing progress, and love the infills etc.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. |
04-19-2015, 10:57 AM | #159 |
Registered Loser
WOW! I wanna skip ahead and see this thing finished so bad but I also like seeing the progress on builds like this.
Amazing work!
((..)) ((0)) '63 GMC lwb, 383, th350, lays frame, genuine patina. The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267 '88 Astro cargo bagged, shaved, phantom grille. *SOLD* '50 Chevy 2 door sedan awaiting attention. 2014 Silverado Ext cab, 5.3, daily driver. |
04-20-2015, 08:23 PM | #160 | ||
Thanks pimpston.
Today we got the drivers side partly welded. Then we decided to fit the wheel well so we extended the wheel center line. Then test fit the wheel well and found it had to be trimmed to fit between the front and rear braces
04-20-2015, 08:27 PM | #161 | |
04-20-2015, 08:30 PM | #162 |
When got the wheel well closer we had to remove more of the inner panel front and back
04-20-2015, 08:33 PM | #163 |
Some final trimming and it fits fairly good
04-20-2015, 08:40 PM | #164 |
04-20-2015, 09:30 PM | #165 |
Nice work! I would like to be hanging out having fun in the shop with you guys!
04-20-2015, 09:31 PM | #166 |
I will be building a fire wall but I don't think it would fit the theme of your suburban. But if you want to build something different I could help you make a roadster unibody truck out of your 'burb
04-20-2015, 09:39 PM | #167 |
With your skills we would be lucky to have you come hang out
04-22-2015, 08:42 PM | #168 |
Yesterday we finished the welding on the drivers side. Then we found that the inner fender was rubbing on the quarter panel so we cut a horizontal line on the inner fender. We used a hammer and dolly to fold the edges in a little then welded it back together.
04-22-2015, 08:52 PM | #169 |
not sure if you had plans for the roof yet, my vote is a rag slider!!!
04-22-2015, 09:21 PM | #170 |
I don't know yet but how about a plexiglass bubble like a George Barris custom
04-22-2015, 09:24 PM | #171 |
04-22-2015, 11:38 PM | #172 | |
1961 crewcab
+plus another cool one- the 63-67 'vette front looks made for it!
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
04-26-2015, 05:19 PM | #173 |
We got the drivers side wheel well modified for clearance. Then started on the lip of the wheel opening. We still have some more welding to do.
04-26-2015, 06:17 PM | #174 |
Wow!!! Keep on twist'n!!!
04-26-2015, 07:42 PM | #175 |
Registered Loser
Yeah, plus I haven't quite finished my time machine yet.
