Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 05-18-2015, 08:15 PM   #1
85_prairieboy
85_prairieboy's Avatar
Cherokee Front Springs
I decided to throw the dice and swapped my cut stock coils for a set of Cherokee springs. I am amazed by the difference in stored energy. I shouldn't be. The cherokee springs were 18.5 inches free length and squashed down to the perfect height. I used to be able to lift the bumper by hand an inch and now I can pull it up 5-6. I ran it last weekend with full exhaust, n/a and breathing all the hot air from under the hood and ran 13.1 @ 100 mph, the best i have ever done with out nitrous. I'm headed back to the track this weekend and am hoping for a shot of the front tires off the ground.
85 GMC toy Lowered, newer box swap, 350 .060 over with AFR 195s, forged pistons, TCI TH350
1.83 60' 13.14 @ 100 on motor
1.49 60' 11.52 @ 116 w/150 shot
1952 Chevy truck project
1980 Z28 Camaro
1967 Camaro drag car 10.60@126
85_prairieboy is offline   Reply With Quote
Old 05-18-2015, 10:33 PM   #2
Super73
Super73's Avatar
Re: Cherokee Front Springs
If you continue to use this spring and go faster, you will need a very good shock to control that spring. I am running in to that issue now and actually moving back to a shorter stiffer spring. My Rancho 9000's just can't keep the front end from coming up to fast.
I don't want to invest in the shock now as I would like to do a full mustang 2 conversion down the road. Spending $1k on shocks twice just does not make sense.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 05-18-2015, 11:26 PM   #3
85_prairieboy
When the front end rises too fast does it unload the rear tires after the initial hit? Currently I am getting some wheelspin when I first launch and then they hook up
1980 Z28 Camaro
Old 05-18-2015, 11:40 PM   #4
Super73
Super73's Avatar
Take a close look at the videos I posted in this thread http://67-72chevytrucks.com/vboard/s...d.php?t=670129
This was last weekend. You can see it lifts both fronts. When it is coming down, it unloads the rear tire about 10-15' out. If I had a shock that could slow the rise, it would definitely help.
The options I have are 1) try to add more add more power, which might carry the wheelie further and still have the issue or 2) slow the rise.
Old 05-18-2015, 11:53 PM   #5
85_prairieboy
Wow I see what you mean, I am going to try get some good video like that to see what is going on
1980 Z28 Camaro
Old 05-19-2015, 11:58 AM   #6
71Dragtruck
71Dragtruck's Avatar
What are you running for front shocks? I have a set of good QA1's that might fit your truck.
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
Old 05-19-2015, 01:32 PM   #7
Super73
Super73's Avatar
I have Rancho 9000's mounted in the stock 1963 location which is the back side of the control arm. I no longer have them mounted to the frame the way they were from the factory. I welded a couple ears that sit above the frame rail. I would be interested in them.
Old 05-19-2015, 03:42 PM   #8
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I used the 9-11" QA1 promastars on mine, with a similar setup and I'm pretty dang happy about the way it controls the front. If your tabs are higher, they may still work for you, but QA1 makes a step longer which are like 10.25-13 stroke which would make up the height difference if you needed to.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 05-19-2015, 08:09 PM   #9
Super73
Super73's Avatar
Thing is the Rancho does a fine job at 1.5ish 60's and slower. I have almost 8" of front suspension travel (shock sees roughly 4"). Combo works fine on motor, but on the bottle, it just had to much pretty foe l for the spring shock combo I have. I really need to go double adjustable with a real good shock.
Old 05-20-2015, 01:06 AM   #10
85_prairieboy
Old 05-20-2015, 01:10 AM   #11
85_prairieboy
Right now I have a set of Nitro drop shocks. Less than ideal. I'm going to see what happens this weekend with nitrous and if it's not good I might take you up on those 71Dragtruck
Old 05-20-2015, 01:25 AM   #12
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
The nitros are usually VERY stiff on compression and don't control lift much. In generally they leave soft and land hard, not really ideal.
Old 05-21-2015, 05:16 PM   #13
scatesracing
Machinist
scatesracing's Avatar
What year Cherokee springs are you guys using?
scatesracing is offline   Reply With Quote
Old 05-21-2015, 07:33 PM   #14
Super73
Super73's Avatar
Mine were early 90's V8 grand Cherokee
Old 05-21-2015, 11:24 PM   #15
scatesracing
Machinist
I picked up a pair out of an 03 grand Cherokee with the 4.0 I6. I hope they work.
Old 05-25-2015, 12:26 AM   #16
85_prairieboy
Yes mine were from an early 90's Grand Cherokee as well. There were 2 options and I chose the heavy duty set. $118 Canadian for a new set. I think my suspension is working ok for now. Hooked hard enough on an unprepped track to hit my head on the back window!
https://www.youtube.com/watch?v=emAKN8888zw
1980 Z28 Camaro
Old 05-25-2015, 03:05 AM   #17
Super73
Super73's Avatar
Definately transferred weight.
Old 08-18-2015, 02:18 PM   #18
skeeterbug
skeeterbug's Avatar
Dang my luck go figure..... I have a set of front and rear springs out of a yj that i used the rear springs for lowering springs back in the day before going coilover rear. I also have the Front/ rear springs i just took off my 2013 JKU 4-door from a lift kit i just installed on it, but no Cherokee springs....crap! I wonder what the spring rates on the cherokee,...JKU springs may work, i think ill try it. I will let yall know how they work out.
'71 LWB c10-"WORK" in progress
385 ci 4 bolt (4.040 bore), scat 6.0" forged h beams,scat forged crank 3.750, speed pro 5cc flat top, clevite bearings, .039 head gaskets,comp xr288hr 110* 288/294adv. 236/242@.50 555/576 lift, pbm hyd roller lifters, chad spiers 215cc imp. heads , comp 1.6 roler rockers, comp magnum push rods, edelbrock victor jr. single plane intake p&p (1206 gasket matched), quickfuel 750R DP , th 350 trans, 5.14 gear, 3000 stall
2012 best 1/8- 7.70 @ 87mph 1.70 60' (lil better)
2013 best 7.39
2014 best-7.38
New for 2013-strange rear coilovers, headman 1-3/4 headers, 5.13 r&p, .060 aluminum bed floor, 15x14 holeshots w/ 31x18.5 hoosier dot pro's, 15x4 holeshots w/ 26x5.5 m/t skinnies and 200+#'s in body weight loss & 6 point cage
skeeterbug is offline   Reply With Quote
Old 10-22-2015, 11:11 PM   #19
Ont67shortbox
will the Cherokee springs work with a BBC,or is the engine too heavy, I see everyone that tried this had a SBC,would like to heard about BBC experience
Ont67shortbox is offline   Reply With Quote
Old 10-23-2015, 01:28 AM   #20
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I resent that, don't lump the LS guys in with the GenI SBC riff-raff.
Old 10-23-2015, 12:03 PM   #21
Ont67shortbox
sorry, LS and SBC guys,no offence intended, just want to know if this is worth trying with a BB
Old 10-23-2015, 12:45 PM   #22
Super73
Super73's Avatar
Get the front end weighed and you will likely have your answer. But if I had to guess, I think it will be on the bump stops
