Old 05-29-2015, 01:48 AM   #1
EvanR
EvanR's Avatar
New Member/Couple questions
Found this form very useful over the years.
I've got a 72 k10 with a newish crate 350.
My water pump recently cracked into several pieces.
Need new water pump pulley and cant get it anywhere in town.
So i was thinking why not upgrade to serpentine belt.
Anyone have any good luck with these, gripes moans or complaints/Good brands.
Any advice would be greatly appreciated.
EvanR is offline   Reply With Quote
Old 05-29-2015, 06:31 AM   #2
hamjet
hamjet's Avatar
Re: New Member/Couple questions
Wow, what caused the pump to break like that. looks like all fresh break like something hit it hard. from what I see the pulley looks fine, is it defective on the bottom? Not sure on switching to serpentine, but it won't be cheap.. nice truck by the way.
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 05-29-2015, 06:48 AM   #3
7tee
7tee's Avatar
I'll have to say that I've never seen one like that but then I haven't seen everything. This had to be a bad casting. You could check on the past posting's for further info. on serpentine set ups...
7tee is offline   Reply With Quote
Old 05-29-2015, 07:03 AM   #4
EvanR
EvanR's Avatar
In total the fan cut through my lower radiator hose, hit somewhere and broke the rivets off a blade. The pulley got crushed in somehow and the belt wont fit in on one side.
Old 05-29-2015, 07:08 AM   #5
hugger6933
A serp setup from a S-10 or C/K series truck 90-94 is the best ticket for you and should also be the most economical. Some aftermarket set ups can run up to a couple thousand bucks. Jim
hugger6933 is offline   Reply With Quote
new member, serpentine belt
