Closed Thread
Old 05-29-2015, 05:34 PM   #2276
In The Ten Ring
Re: What did you do to your truck today? Chapter II
Originally Posted by DdowC20 View Post
That's funny Ten Ring, the po of my truck rattle can painted the truck and actually painted the bulbs in the tail light fixtures. And the covers. And the marker lights. And the rear window in spots. And also rattle canned the rebuilt motor. All of it. Including wires.
Wow.
No VWNate1, I have not worked in a junkyard.......I have no doubt that you are right, people do such idiotic things!
In The Ten Ring is offline
Old 05-29-2015, 06:14 PM   #2277
ole dollor
ole dollor's Avatar
Originally Posted by Lanman1972 View Post
I used the vinyl cutter that my daughter got for Christmas to make the letters for my tailgate. Thought I liked just white but this is way better!
Now that's just cool .... I like it a lot..
ole dollor is offline
Old 05-29-2015, 09:09 PM   #2278
In The Ten Ring
Not much today: gave away a set of wheel ramps in the garage to a friend, that helps clear up the space some and I had no use for those tools.
I bought a new can of NAPA Rust Treatment (love that stuff) and a puller to remove the wiper arms. Learned that yes, I must prime the oil in my engine before starting.
Old 05-30-2015, 06:59 PM   #2279
DarkFlounder
After a few months of looking, I finally find a 72 drivers door in a swap meet. And it's damn near perfect!
No rust, all metal straight, only have to deal with the speaker hole.
I might have overpaid a bit (Talked him down from the $200 marked to $150), but it's the correct year, damn near perfect, and I was tired of looking. Also tired of dealing with the sagging mangled door currently on the truck.
72 K2500 Sierra Longbed Wideside 350/TH350/NP205
66 Plymouth Barracuda 225 Slant6
DarkFlounder is offline
Old 05-30-2015, 08:55 PM   #2280
1971_CST_C10
Well, got new tires put on the truck today... finally got the right size I was after...
Darren.
1967 C10 Shortbox
1971 Monte Carlo SS buckets and console #'s car
1970 350 Monte Carlo bench seat
1970 El Camino SS
1971_CST_C10 is offline
Old 05-30-2015, 10:05 PM   #2281
In The Ten Ring
Good going on the door. I would have bought it too! Best of luck to you, getting the speaker hole fixed and that thing onto your truck.
I had a big day. I removed the inner and outer grill as one, since I couldn't figure out how to get the inner grill away from the outer. Yes I removed all the little bitty screws, none broke, although one's head rounded off BUT I have Vise Grips and I was not afraid to use them!
Since I couldn't get the inner grill off, I had to put every last one of my extensions together (20 inches! of them) to get room to rotate my ratchet. I knew buying up all those vintage 1/2 and 3/8 inch sets was a good idea!
OMG, the amount of rust in that passenger outer fender! The fender held together but it is getting replaced. The driver's side is OK but needs some attention, I may go on and replace it too.
Driver's side fender rust (bottom)
Passenger side fender rust (whole fender)
My extensions (I am buying a 1 piece LONG extension next chance I get)...I needed this to get my over from the grill bracket bolts to the opening for the radiator in the core support
I had to call "tech support" in the form of a junkyard owner I know for advice on getting the grill off.
Finally, I got the hood hinge bolts cleaned up (look brand new) and coated with NAPA Rust Treatment. I also started on another and larger electrolysis tank for the hood hinges and hood latch components.
Old 05-31-2015, 10:08 AM   #2282
cooperhw
cooperhw's Avatar
Had my bodyman over yesterday for another day of work. He shaped in the cab back (where I tied the new roof & cab together) and got it in primer. Trying to get the cab back together so I can get glass back in and sealed up to protect the original interior.
few pics of yesterdays progress;
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline
Old 05-31-2015, 10:42 AM   #2283
Boog
laying low
Boog's Avatar
Wayne I hope it was cooler there yesterday.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Boog is offline
Old 05-31-2015, 02:13 PM   #2284
re1
re1's Avatar
Slipped the motor and tranny back in the truck.
1972 Chevy C10 Custom Deluxe Highlander
1972 Chevy C10 Custom Deluxe Medium Green
re1 is offline
Old 05-31-2015, 04:35 PM   #2285
Crushkrew
Crushkrew's Avatar
Test drive!!!! My son's truck...never seen a 17 year old boy happier....
https://m.youtube.com/watch?v=4jO9VTtvAaY
71 C10: Crush10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=650510
Crushkrew is offline
Old 05-31-2015, 06:56 PM   #2286
Timg1
Adjusted carb, traced dual tank lines from tanks thought filters and switches to mechanical pump housing to carb. I found the return hose at mechanical pump had no clamps on it which allowed fuel to leak when I moved it a little. Hopefully this solves my problem of using 1/2 a tank to go 50 miles. If not, I'll be back at it next weekend.
Timg1 is offline
Old 05-31-2015, 08:45 PM   #2287
WIDESIDE72
WIDESIDE72's Avatar
I finally got all of my original gauges working in my 72 swb stepside! The a meter wasn't working, but I fixed it with a volt gauge conversion from tbone a while back. The temp gauge was the last one giving me fits. Turns out the temp sender was the wrong one. Never moved off cold. Installed sender and works like a charm. It wasn't cheap, but what cha gonna do?
http://www.ebay.com/itm/261580097652...%3AMEBIDX%3AIT
WIDESIDE72 is offline
Old 05-31-2015, 09:21 PM   #2288
Saclandman
Saclandman's Avatar
Got one of the angle strips cut off the bedside today. What a PITA that was. Spot welded on every 2-3 inches. Sawzall wasn't doing the job, so broke out the grinder and ground out the welds. Then bolted down a 4x8 sheet of 3/4" marine grade plywood for a temporary bed. Now my bed won't bounce around as a drive down the road.
Rich J.
1967 Chevy C20 Longbed Stepside w/283 and 4spdSOLD
2002 Chevy Tahoe 4X4 5.3L SOLD
2015 Chevy Silverado Crew 4X4 5.3L
Saclandman is offline
Old 05-31-2015, 10:30 PM   #2289
cooperhw
cooperhw's Avatar
103* today. Better than 105* yesterday.
cooperhw is offline
Old 05-31-2015, 10:59 PM   #2290
In The Ten Ring
Today was terrible. Mom got really sick and I nearly called in the ambulance. Suffice to say, I didn't get much done. I did however, after she was better, get the last of the hood hinge boots rust treated (NAPA) and the new 50 gallon electrolysis tank finished. I hope to try it out in 2 days, once the weather clears.
Old 05-31-2015, 11:25 PM   #2291
robgmaddux
Junior Member
robgmaddux's Avatar
My cab and front clip went from primer to paint today.
My build thread! http://67-72chevytrucks.com/vboard/s...d.php?t=665907
robgmaddux is offline
Old 06-01-2015, 03:48 AM   #2292
EvanR
EvanR's Avatar
Finished the installing of my Retrosund Model 2.
If it works, don't fix it.
EvanR is offline
Old 06-01-2015, 11:34 AM   #2293
zellway
zellway's Avatar
Good call on the radio! Love mine and soon all my rides will get them.
Erik
My 69 suburban http://67-72chevytrucks.com/vboard/s...d.php?t=530626
1970 C10 step Project Jiminy http://67-72chevytrucks.com/vboard/s...d.php?t=682647
RUST!? Thats just mother natures way of telling all of us.....MINE!!!!
zellway is offline
Old 06-01-2015, 01:55 PM   #2294
cooperhw
cooperhw's Avatar
MAN that dude is looking sweeeeeeeeeeeeeeet.
Later,
Wayne
cooperhw is offline
Old 06-01-2015, 02:02 PM   #2295
robgmaddux
Junior Member
robgmaddux's Avatar
Thanks feels good to get a little done
Old 06-01-2015, 02:35 PM   #2296
In The Ten Ring
Is that a manual choke knob to the left of the ignition?
Old 06-01-2015, 03:28 PM   #2297
VWNate1
VWNate1's Avatar
Talking Re: What did you do to your truck today? Chapter II
Working in Junk Yards , Used Car Lots and the lower Tier Service Stations gives one a whole 'nother perspective on things .
I remember in 1972 looking at an old Dodge ambulance (1950's M37) that had the engine painted then started up whilst still wet ~ the paint dried in little flags blown back wards by the fans prop wash .
Helluva thing .
They too painted the spark plugs , wires , carby etc. .
-Nate
Originally Posted by In The Ten Ring View Post
Wow.
VWNate1 is offline
Old 06-01-2015, 03:30 PM   #2298
StoningtonQB
StoningtonQB's Avatar
Finally got rid of my rubber fuel line, replaced it with stainless steel and added a regulator and inline gauge. Also finally replaced the parking brake cables and spider gears.
StoningtonQB is offline
Old 06-01-2015, 04:21 PM   #2299
VWNate1
VWNate1's Avatar
Question Cab Doors
Is there a difference between '67 ~ '72 doors ? .
I see lots of un rusted ones with HUGE speaker holes poorly cut and 75 holes for various mirrors in the Junk Yard all the time ....
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 06-02-2015, 01:02 AM   #2300
outdoorsman310
outdoorsman310's Avatar
what rear? i need to rebuild my ho52 and put a detroit locker in it but I am having trouble finding parts
outdoorsman310 is offline
Closed Thread
