Old 05-08-2015, 07:24 PM   #451
oldman3
oldman3's Avatar
Re: 55 Wagon Progress
Always glad to see your post, excellent work...Jim
oldman3 is offline   Reply With Quote
Old 05-14-2015, 10:54 PM   #452
MP&C
MP&C's Avatar
Thanks for taking time to post fellas.
More progress on the condenser mount... The flange fold marks are run through the tipping wheel to better show the bend location. I've found that when using the press brakes this helps to "feel" when the upper die is located properly, less guesswork with the eyeballs where it's harder to see in the press brake dies..
Clamped in place for a test fit..
The side folds add some stiffening as well as hide the bolt heads for the core support baffle plates.
Test fit of the condenser...
Radiator brackets got a nut welded in the bottom hole, the condenser mount will get nuts welded in place for the top 2 sets of holes, so everything will bolt in from the outside in..
Making the slots for the radiator brackets, used a cone shaped burr....
Found that this cutter had less chatter when the cutting edge was perpendicular to the hole opening...
Robert
MP&C is offline   Reply With Quote
Old 05-18-2015, 12:33 PM   #453
MP&C
MP&C's Avatar
Some more details to iron out on the condenser mount, the corners seemed to "roll" a bit, so some corner braces are in order..
Using 16 gauge cold rolled, holes drilled to provide an inside radius to help prevent stress cracking..
Plug welds to hold things together..
Bob Heine over on GJ suggested using a Corvette antenna as they use an escutcheon with a flush fit, so I had a Corvette part delivery over the weekend, size of the business end is rather larger than the aftermarket one we had. As this fit in the void behind the A pillar (see in background between cowl vent and A pillar) and also needs to dodge the hinges closing, this did cause some interference. Dan thought this was from a late 80's/early 90's..
The biggest issue with the universal power antenna we have is that the top of the fender is considerably rounded, and the antenna escutcheon is designed for flat. So we are also looking at the factory piece, to see if we could adapt (drill hole larger) to use with the power antenna.
Robert
Old 05-18-2015, 08:21 PM   #454
duallyjams
duallyjams's Avatar
modify and use the stock one
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 05-22-2015, 09:22 AM   #455
MP&C
MP&C's Avatar
More progress on the condenser, used some machine screws to attach to the bracket, and some AVK style rivet-nuts in the frame of the condenser to act as a captive nut.
Bolted in place...
Meanwhile Kyle ties up some loose ends, finishing the weld across the remaining "shaved" lead seam on the passenger quarter.. It does need some grinding on the underside of the weld still but we'll wait for the car to be on the rotisserie for easier access.
Fitment of the Driver's side tail light... this was even worse than the passenger side in fitment, and we did need to make a relief cut at the top, but after some massaging, it's getting close. A few more tweaks to get this done and then the headache of installing the motorized tail light pivot for fuel fill access..
Robert
Old 05-23-2015, 07:22 AM   #456
FarmerSid
FarmerSid's Avatar
Awesome as always.
1952 Canadian Chevy 1300
C4 IFS & D44 IRS
5.3 HO L33
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938
FarmerSid is offline   Reply With Quote
Old 06-01-2015, 09:55 PM   #457
MP&C
MP&C's Avatar
Thanks Sid!
Sorry for the slight hiatus, been in UK and just got back this past weekend. Time to catch up on what we had done before I left and what Kyle did while I was gone to take up my slack..
Part of our fitment issue with the passenger tail light was that we are installing the "hidden fuel fill" which required the removal of the brace welded in the opening. Next, when the old quarter was cut off and the new one installed, without the brace in place both pieces tended to wrap to the right, which can sort of be seen in the following picture, where its flush above the inside corner and rotates to the right upwards of that. The outer quarter was rotated in a similar fashion. We weren't having much luck in resolving the issue with the top weld seam remaining, so a relief cut was added, a restraint device employed to make use of some off dolly bumping to eliminate some of the right rotation. I didn't get a good picture of it, but you can see where the inner quarter comes in considerably upwards of the tail light right corner..
Anchor
Off-dolly bumping...
Then some shrinking was used to pull in the inner quarter, and a 16 ga plate used to hold things in place while the top seam was re-welded.
Kyle got the seam welded closed...
And temporary brace removed...
Much better, almost ready to tackle the "fuel door" pivot...
Robert
Old 06-02-2015, 10:13 AM   #458
knomadd
knomadd's Avatar
That's a lot of work to straighten a tail light opening. You're all very skilled and talented to be able to figure that out and make it happen. I'm impressed more and more when I read this thread. Keep up the good work.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 06-02-2015, 11:49 AM   #459
MP&C
MP&C's Avatar
It was going to be a challenge getting it to line up with using the hidden gas fill behind the tail light, so we wanted to get it fitting correctly to the sheet metal before starting that fiasco...
Robert
Old 06-07-2015, 10:50 PM   #460
MP&C
MP&C's Avatar
Got another care package in the mail... The new escutcheon for the antenna looks like it will work, the hole size matches the nut on the antenna and we'll just need to get rid of the flat spot/keyway in the hole. Only I don't think we'll be using this one. Between a recess under the chrome and visible scratches in it, this one's going back.
On to the next new pieces, hopefully these fit better, Reproduction headlight buckets..... wanted to test fit all the headlight and turn signal pieces before re-priming the fenders..
Decided to use some AVK rivet nuts over the u-clips..
Parts fitted..
Robert
Old 06-12-2015, 05:33 PM   #461
MP&C
MP&C's Avatar
Well this isn't much of an update, but since Kyle was busy media blasting some parts I had torch and hammer duty.. So to have a place to drop the torch quickly, bent this up:
When the top seam was welded we had a slight bulge just in from the tail light. So some dime sized spots were heated and then hammered with glancing blows to bring things down a bit.. The fit of the tail light is much better now, and we've started the fitup of the motor assembly's mounting plate. Should get that welded in tomorrow..
Robert
Old 06-12-2015, 06:03 PM   #462
Advanced Design
Advanced Design's Avatar
That torch holder looks pretty handy. I remember one of the guys selling a torch hanger that would shut off the gas when you hung it up, then would restart the gas and light the torch when you picked it back up. Just don't remember where.
Nice work on the tail light housing. Curious, have you kept track of how many hours on this one build so far?
Advanced Design is offline   Reply With Quote
Old 06-15-2015, 04:38 AM   #463
66Slabside
Love seeing your progress. Everyone has already said all that can be said about how amazing your skills are. You inspired me and taught me thru this thread so I went out to try to get a few dents out of my 66 Lincoln that I was going to have someone do for me. While my results aren't nearly as wonderful as your work I was able to get a pretty good sized crease out of my lower quarter panel in which I had little access to the back side. I don't have nearly the tools you do for body work but seeing your use of everyday things got my creative side going. Used my cheap hammers and a pry bar on the backside to get down into the lower quarter panel and watched in amazement as the dent started to disappear a bit at a time A little filler (approx. 1/16 to 1/8 at what was about a 5/8 inch crease) so I called it good for a beginner.
Thanks for sharing and getting me out of my comfort zone and into the wonderful word of metal shaping. When your in my position there's no where to go but up!!
66Slabside is offline   Reply With Quote
Old 06-16-2015, 10:32 PM   #464
MP&C
MP&C's Avatar
I've seen those as well.. As to the hours, I don't have a 100% accurate count, we didn't have the time clock in the shop for the first bit of work being done, and I do need to total up what I have so far to get an idea where we are..
Glad to be a bad influence...
Worked on the Rocky Hinge hidden fuel door this evening. The mounting plate we made is plug welded to the tail light opening..
Slight trimming needed.....
Then some 3M body molding adhesive tape is added to the top of the pivot bracket and the lens pressed in place. Here's the initial test...
https://youtu.be/oZ6JYr988dc
That worked fairly well, so it was clamped in place and a transfer punch used to mark the housing for drilling mounting holes..
Then the holes were slightly slotted using a dremel for side to side adjustability. Here's the results, from different views....
https://youtu.be/848V2PbuQJw
https://youtu.be/N_Qz0NZxh5g
https://youtu.be/PVeWQyb35j8
OK, now for the bad that we found with the kit... The original lamp housing must be removed for clearance, and a new (included) one gets installed below the original position. The new housing has those spring loaded contacts that some tend to bend over and short out, so I gave the wires a couple gentle tugs to see if the contacts deflected toward the outside shell...
Surprise, surprise, the contacts pulled clean off....
Note there is no copper inside the contacts, indicating these had a loose crimp...
Next, the operation of the motor function seemed to be intermittent. A recheck of the power connections showed no issues, so we pressed a bit harder on the switches toggle, and the function returned. Multiple repeat attempts were performed and the switch proved to be the culprit. It appears to be a cheapo switch that has intermittent contact function. So looks like we'll be replacing a couple of the parts for this kit... So much for everything you need in one package....
Robert
Old 06-18-2015, 11:11 AM   #465
Mr Chevorlet
Rusty Nuts
Mr Chevorlet's Avatar
What fantastic work, love looking at the pictures.
(Clever Missouri) Southwest
Larry
Mr Chevrolet
My Build, The Marathon Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=604414
Mr Chevorlet is offline   Reply With Quote
Old 06-19-2015, 10:41 PM   #466
MP&C
MP&C's Avatar
Thanks!
Recently I took delivery of a ball glove pounding pad, $39 on Amazon per a link posted by Johnny Arial on AllMetalShaping. It was very light, and where I did not give it a go with a sheet metal test sample, something in me wanted to see what was inside the bag. So here we go, can't leave well enough alone...
Looks like a high density felt pad...
My previous shot bag had become a casualty inside of a quarter panel when using it as a dolly... It found a sharp piece of metal which caused the tear... and I caused the cut so I could empty it out and pull it out of the cavity it was in.. It had approx. 50 lbs or better of lead shot in it at the time, and for some reason I didn't think about removal when I was dropping it in the hole.
So I had put in an order last night for another bus seat cover (Kevlar material) and took it today with all the pieces to Anthony's Upholstery. This one is a bit smaller, so also more manageable. I think I had about 1/3 of the 50 lbs left over, so may have to make another smaller shot bag..
Comparison, the old to the new one..
Something told me when that Amazon order was placed that this thing would have lead shot inside before all was said and done.. It does make a nice shot bag, and has a nice look.
Robert
Old 06-28-2015, 10:04 PM   #467
MP&C
MP&C's Avatar
More progress on the wagon, got some SPI epoxy sprayed, hopefully this will wet sand out and be ready for BC/CC.
Also got some primer on the sheetmetal for an 01 Dyna
Look Scott, the dent's gone...
Robert
Old 07-01-2015, 12:08 AM   #468
swamp rat
swamp rat's Avatar
Nice, are you gonna air brush next?? LOL!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 07-01-2015, 12:32 AM   #469
MP&C
MP&C's Avatar
No, this is just a repaint and new HD decals. I'd almost rather do some flames instead of fooling with getting the decals lined up..
Kyle learning the fine art of blocking....
Meanwhile, I was wet sanding the motorcycle parts...
This SPI epoxy sure is nice sanding!
Robert
Old 07-01-2015, 01:29 AM   #470
oldman3
oldman3's Avatar
Nice job on the sanding...Jim
Old 07-05-2015, 06:49 PM   #471
MP&C
MP&C's Avatar
Wet sanded with 600
SPI Epoxy seal coat
Dupont Cromax Black Diamond and clear
Robert
Old 07-05-2015, 07:41 PM   #472
Advanced Design
Wow, that looks really nice! Great job and love the color.
Old 07-05-2015, 08:36 PM   #473
oldman3
oldman3's Avatar
Robert, nice job looks super. When you use the epoxy as a sealer, is it the same or do you change it up, thinner, less pressure or???...Jim
Old 07-05-2015, 10:05 PM   #474
MP&C
MP&C's Avatar
Per their tech sheet the epoxy can be reduced 5 to 50% to use as a sealer..
Robert
Old 07-08-2015, 02:12 AM   #475
Grizz1963
Grizz1963's Avatar
Continue to enjoy your posts.
Thanks for sharing.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline   Reply With Quote
