05-26-2015, 11:06 AM | #1 |
Looking for a steering shaft spring
I am in need of the compression spring that snugs up against the lower bearing on the steering shaft on my 66 truck. I could also use another pinch clamp. My lower bearing failed and the shaft was not only eaten away but the spring broke. I am in the process of fixing the shaft, but I can't find a spring or clamp.
Any help with these would be greatly appreciated. |
05-26-2015, 04:29 PM | #2 | |
Re: Looking for a steering shaft spring
05-26-2015, 09:53 PM | #3 |
05-26-2015, 10:27 PM | #4 |
05-27-2015, 09:45 AM | #5 |
The picture shows the steering rod before being repaired. Yesterday I welded tup the worn area and today I am going to use a friend's lathe to turn the welded area down flush with the rest of the shaft.
05-27-2015, 04:50 PM | #6 |
Here is a picture of my steering rod completely repaired.
05-27-2015, 07:10 PM | #7 |
05-27-2015, 07:33 PM | #8 |
if you still need a spring and clamp I have both denny
05-29-2015, 04:15 PM | #9 |
this should work for ya!!!
05-29-2015, 08:10 PM | #10 |
05-29-2015, 08:30 PM | #11 |
Dude it was very hard get it off, took a whole 2 mins phew!!!
06-10-2015, 02:30 PM | #12 | |
Thanks again with your help on these parts. |
06-11-2015, 07:09 PM | #13 |
Im back, been dealing with real life stuff. your part is on its way!!!
06-12-2015, 09:18 AM | #14 |
06-12-2015, 05:07 PM | #15 |
