Old 06-12-2015, 12:45 PM   #1
RAMMER
RAMMER's Avatar
panel under wipers
Hi All
I have a 1967 chevy c10 pick up and i need to fit new washer jet and new tubes.
IT look like i have to remove the panel above to get to them?
IF that the case when you remove the bolts from the nuts do the nut stay on the panel or do they fall away.
Many Thanks
RAMMER is offline   Reply With Quote
Old 06-12-2015, 01:28 PM   #2
68panelman
68panelman's Avatar
Re: panel under wipers
There is only four bolts and 4-5 screws on top that run along the grill area. No nuts to fall unless you have PO podge work to deal with.
68panelman is offline   Reply With Quote
Old 06-12-2015, 05:42 PM   #3
RAMMER
RAMMER's Avatar
HI 68 panelman,
Thanks for getting back to me am hoping that how it is.
ITS alway a bit scary when your not to sure if you should turn that bolt one more turn.
IVE only just got back to the uk,and it the Chevy I've owned so it a all new ball game to me so it great to be able to get help from you guys.
IF i can work it out i will put some picture on for you of the truck.
CHEERS RAMMER
Old 06-12-2015, 10:57 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
Welcome to the board. As Panelman indicated you shouldn't have any trouble removing the cowl vent panel. You will have to remove the windshield wipers first....
LockDoc
Leon
Old 06-13-2015, 05:55 AM   #5
RAMMER
RAMMER's Avatar
LockDoc
Hi Lockdoc,
Thank you for your reply,
I wonder if you or panel man could help me with this one?
Has the washer bottle has gone to and I can't find the wiring
Where would the switch be mounted on
The dashboard ? Many thanks
Old 06-13-2015, 06:15 AM   #6
LockDoc
LockDoc's Avatar
Originally Posted by RAMMER View Post
Hi Lockdoc,
The washer switch is integrated with the windshield wiper switch. You push in on the wiper switch knob to activate the washer. When you push on the knob it activates the washer and turns the wipers on low speed. The windshield washer pump is built into the windshield wiper motor.
LockDoc
Leon
Old 06-13-2015, 06:25 AM   #7
RAMMER
RAMMER's Avatar
LockDoc
Old 06-13-2015, 06:36 AM   #8
RAMMER
RAMMER's Avatar
Thanks Lockdoc,
I have a look at that and see what I can find.
My be its only the bottle I've got to get?
Many thanks cheers
Old 06-13-2015, 10:33 AM   #9
LockDoc
LockDoc's Avatar
Thanks Lockdoc,
Many thanks cheers
Does your truck have the bracket for the washer bottle? Here is what the bottle looks like....
LockDoc
Leon
Old 06-13-2015, 11:07 AM   #10
MagmaJct
MagmaJct's Avatar
LockDoc
Just a quick hijack! Is that the original location for the washer bottle for the 71 C10? I ask because at some point long ago my C10 got a secondary battery tray mounted in that location.
The washer bottle is currently located above the driver's wheel well.
Regards,
Mike
I own 3 classic vehicles. 1971 LWB C10 Deluxe. 1974 VW Super Beetle. 1971 VW Fastback.
The C10 and the Super Beetle run, the Fastback is just not there yet!
Please visit my Super Beetle and Fastback profile on TheSamba.
MagmaJct is offline   Reply With Quote
Old 06-13-2015, 11:16 AM   #11
RAMMER
RAMMER's Avatar
HI LOCKDOC,
Thanks for the picture iv just had a look and it would seem
that where it was there no bracket just holes?.
I try the washers like you said,but i could not hear the washer
motor going.
I had to turn wipers on first before i could push nob in.
AM hoping to take panel of next week when it has stopped
raining here.
A big thank you cheers
Old 06-13-2015, 12:46 PM   #12
LockDoc
LockDoc's Avatar
Regards,
Mike
Hi Mike. Drivers side inner fender would be the correct location for the '71. Only the '67 and '68 trucks were mounted on the core support.
HI LOCKDOC,
Thanks for the picture iv just had a look and it would seem that where it was there no bracket just holes?.
I try the washers like you said,but i could not hear the washer motor going.
AM hoping to take panel of next week when it has stopped raining here.
Yes, there should be two holes one above the other....
If you can't find a bottle and bracket over there I will send you an extra one I have if you want to pay he postage on the package. The original pump may not work even after you get everything figured out.
If you don't need a stock bottle you could probably find one that would work off of another vehicle. A later one with the pump built into the bottle would work also.
LockDoc
Leon
Old 06-13-2015, 01:12 PM   #13
michael bustamante
michael bustamante's Avatar
ive owned three 67`s and on not one of them did the washer pump work. hopefully yours is a different story
1967custom
michael bustamante is offline   Reply With Quote
Old 06-14-2015, 05:26 AM   #14
RAMMER
RAMMER's Avatar
Smile Re: panel under wipers
HI LOCKDOC,
Thank you for the offer of the bottle,i can get the bottle and pump over here.
ITS great to know your all out there with a helping hand.
As this is the first chevy I've own am going to need a bit of help from time to time.
CHEERS AND A BIG THANKS FOR YOUR TIME AND HELP
Old 06-14-2015, 08:09 PM   #15
LockDoc
LockDoc's Avatar
I've had the same luck as you with the '67's Michael, although the one in the '70 I had worked and the one in my '68 CST junk yard find works.
HI LOCKDOC,
No problem on the help. If you have any more questions post them up....
LockDoc
Leon
